GSM Shield problem - reset during registration
Dear community members,
I am working on a project that uses an Arduino Ethernet R3 combined with a Telefonica GPS/GPRS shield. The board is connected to a Linux laptop using a PL2303 based board (serial to USB). The arduino is powered with an external adapter delivering 7.5V at 1A.
I am struggling to get the SendSMS example working. I filled in the PIN and activated debugging of the GSM class. This gives me the following output:
SMS Messages Sender
AT%13%
0 9>AT%13%%13%%10%OK%13%%10%
AT+CPIN=3511%13%
9 44>AT+CPIN=3511%13%%13%%10%+CPIN: READY%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
44 75>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%SMS Messages Sender
SMS Messages Sender
SMS Messages Sender
AT%13%
AT+CPIN=3511%13%
AT+CGREG?%13%
SMS Messages Sender
SMS Messages Sender
The script appears to crash on the GSM.begin() function, while connecting to the network. It then resets and tries again.
I also tested the Telefonica shield on an Arduino UNO R2 and used the exact same code as with the Ethernet. This works perfectly and gives the following output:
SMS Messages Sender
AT%13%
AT+CPIN=3511%13%
AT+CGREG?%13%
AT+CGREG?%13%
75 106>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
106 9>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
9 40>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
40 71>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
71 102>AT+CGREG?%13%%13%%10%+CGREG: 0,1%13%%10%%13%%10%OK%13%%10%
AT+IFC=1,1%13%
102 5>AT+IFC=1,1%13%%13%%10%OK%13%%10%%13%%10%Call Ready%13%%10%
AT+CMGF=1%13%
5 21>AT+CMGF=1%13%%13%%10%OK%13%%10%
AT+CLIP=1%13%
21 37>AT+CLIP=1%13%%13%%10%OK%13%%10%
ATE0%13%
37 48>ATE0%13%%13%%10%OK%13%%10%
AT+COLP=1%13%
48 54>%13%%10%OK%13%%10%
GSM initialized
Enter a mobile number: 0464000000
Now, enter SMS content: SENDING
Message:
Hello word!
AT+CMGS="0464000000"%13%
54 58>%13%%10%>
Hello word!%26%%13%
54 76>%13%%10%> %13%%10%+CMGS: 5%13%%10%%13%%10%OK%13%%10%
COMPLETE!
And this is the code used on both boards:
#include <GSM.h>
#define PINNUMBER "3511"
// initialize the library instance
GSM gsmAccess(true); // include a 'true' parameter for debug enabled
GSM_SMS sms;
  // initialize serial communications
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.print("Enter a mobile number: ");
  char remoteNumber[20];  // telephone number to send sms
  readSerial(remoteNumber);
  Serial.println(remoteNumber);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNumber);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
int readSerial(char result[])
  int i = 0;
  while(1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if(inChar!='\r')
        result[i] = inChar;
        i++;
Can anyone explain this behavior? Why does is work on the regular Arduino UNO, but not on the Ethernet?
The ethernet stack and the gprs shield both consumes RAM memory which is very limited. Once there is no memory left, random issues occur often followed by a crash and reset. This would be my first bet in this case.
Google and check for code that tests for low RAM memory as memory problems are rather hard to find out on the Arduino.
We had to move a gprs application to the ATMega 1284 to be able to use some extra libraries for i2c and one-wire sensors.
I agree......
The Mega do´s have what i takes to bring some sketches to the next level.
There is another way though,
http://forum.arduino.cc/index.php?PHPSESSID=lq5274qjlrv8534btbvfpmqlv2&topic=176235.0
if((gsmAccess.begin(PINNUMBER, false)==GSM_READY) &
try it out, and report back if it still hangs in the restart funk. :slight_smile:
AndersHedberg:
This was very useful advice, thank you.
I noticed odd execution behavior when I included the GSM library into my program. After first reading these forums I thought it was faulty GSM drivers (there seems to be issues with the Arduino GSM lib). But then I came across your post and looked into RAM usage. I used the freeRAM function to diagnose a RAM usage problem. My application by itself consumed 1.5k RAM and the Arduino GSM SMS functions require just over 1k RAM. Because UNO R3 only has 2k available it was immediately obvious that the program was running out of RAM. Refactoring the program to use less RAM (reducing UART text and variable sizes) fixed the problem and the program now runs without any issues :slight_smile:
I had assumed the compiler checks the RAM usage and would warn if out of memory! But it does not, so I strongly recommend the freeRAM() function or similar when developing Arduino programs. [The compiler does indicate Flash ROM memory size.]
Thanks also to the Arduino community and contributors.
Cheers
Binaryweighted
