Thank you for the reply back.
I have managed to get the parts connected. And wrote editted the code down to something more simple:
// GxEPD_MultiDisplayExample : test example for e-Paper displays from Waveshare and from Dalian Good Display Inc.
// Created by Jean-Marc Zingg based on demo code from Good Display,
// available on http://www.good-display.com/download_list/downloadcategoryid=34&isMode=false.html
// The e-paper displays are available from:
// https://www.aliexpress.com/store/product/Wholesale-1-54inch-E-Ink-display-module-with-embedded-controller-200x200-Communicate-via-SPI-interface-Supports/216233_32824535312.html
// http://www.buy-lcd.com/index.php?route=product/product&path=2897_8363&product_id=35120
// or https://www.aliexpress.com/store/product/E001-1-54-inch-partial-refresh-Small-size-dot-matrix-e-paper-display/600281_32815089163.html
// Supporting Arduino Forum Topics:
// Waveshare e-paper displays with SPI: http://forum.arduino.cc/index.php?topic=487007.0
// Good Dispay ePaper for Arduino : https://forum.arduino.cc/index.php?topic=436411.0
// mapping suggestion from Waveshare 2.9inch e-Paper to Wemos D1 mini
// BUSY -> D2, RST -> D4, DC -> D3, CS -> D8, CLK -> D5, DIN -> D7, GND -> GND, 3.3V -> 3.3V
// mapping suggestion for ESP32, e.g. LOLIN32, see .../variants/.../pins_arduino.h for your board
// NOTE: there are variants with different pins for SPI ! CHECK SPI PINS OF YOUR BOARD
// BUSY -> 4, RST -> 16, DC -> 17, CS -> SS(5), CLK -> SCK(18), DIN -> MOSI(23), GND -> GND, 3.3V -> 3.3V
// mapping suggestion for AVR, UNO, NANO etc.
// BUSY -> 7, RST -> 9, DC -> 8, CS-> 10, CLK -> 13, DIN -> 11
// include library, include base class, make path known
#include <GxEPD.h>
// select the display classes to use
#include <GxGDEH029A1/GxGDEH029A1.h> // 2.9" b/w
// FreeFonts from Adafruit_GFX
#include <Fonts/FreeMonoBold9pt7b.h>
#include <Fonts/FreeMonoBold12pt7b.h>
#include <Fonts/FreeMonoBold18pt7b.h>
#include <Fonts/FreeMonoBold24pt7b.h>
#include <GxIO/GxIO_SPI/GxIO_SPI.h>
#include <GxIO/GxIO.h>
#if defined(ESP32)
// create GxIO_SPI instances for each display, each instance with different CS line;
// disable reset line to disable cross resets by multiple instances
// GxIO_SPI(SPIClass& spi, int8_t cs, int8_t dc, int8_t rst = -1, int8_t bl = -1);
GxIO_Class io1(SPI, 5, 14, -1); // CS = 5(SS), DC = 17, RST disabled
GxIO_Class io2(SPI, 0, 14, -1); // CS = 0, DC = 17, RST disabled
// create display class instances for each display, each instance with different BUSY line, or BUSY lines or-ed to one pin
// GxGDEP015OC1(GxIO& io, int8_t rst = D4, int8_t busy = D2);
// BUSY lines can be or-ed with diodes and pulldown resistor for displays with BUSY active HIGH
GxGDEH029A1 display1(io1, -1, 4); // BUSY = 4, or-ed
GxGDEH029A1 display2(io2, -1, 15); // BUSY = 4, or-ed
// BUSY lines can be or-ed with diodes and pulldown resistor for displays with BUSY active LOW
//GxGDEW042T2 display4(io4, -1, 15); // BUSY = 15, or-ed
#define RST_PIN 16
#endif
#if defined(_GxGDEH029A1_H_)
namespace BMxGDEH029A1
#include "GxGDEH029A1/BitmapExamples.h"
void showBitmapExample(GxEPD& display)
display.drawExampleBitmap(BitmapExample1, sizeof(BitmapExample1));
delay(2000);
display.drawExampleBitmap(BitmapExample2, sizeof(BitmapExample2));
delay(2000);
display.setRotation(0);
display.fillScreen(GxEPD_WHITE);
display.drawExampleBitmap(BitmapExample1, 0, 0, GxGDEH029A1_WIDTH, GxGDEH029A1_HEIGHT, GxEPD_BLACK);
display.update();
delay(2000);
#undef _BitmapWaveshare_H_
#undef _GxBitmapExamples_H_
#endif
Serial.println("setup");
// one common reset for all displays
pinMode(RST_PIN, OUTPUT);
digitalWrite(RST_PIN, LOW);
delay(20);
digitalWrite(RST_PIN, HIGH);
delay(20);
display1.init(115200); // enable diagnostic output on Serial
display2.init(115200); // enable diagnostic output on Serial
Serial.println("setup done");
Serial.println("BMxGDEH029A1::showBitmapExample(display1)");
BMxGDEH029A1::showBitmapExample(display1);
Serial.println("BMxGDEH029A1::showBitmapExample(display2)");
BMxGDEH029A1::showBitmapExample(display2);
Serial.println("showFont(display1, \"FreeMonoBold9pt7b\", &FreeMonoBold9pt7b)");
showFont(display1, "FreeMonoBold9pt7b", &FreeMonoBold9pt7b);
Serial.println("showFont(display2, \"FreeMonoBold9pt7b\", &FreeMonoBold9pt7b)");
showFont(display2, "FreeMonoBold9pt7b", &FreeMonoBold9pt7b);
delay(10000);
void showFont(GxEPD& display, const char name[], const GFXfont* f)
display.setTextColor(GxEPD_BLACK);
display.setFont(f);
display.setCursor(0, 0);
display.println();
display.println(name);
display.println(" !\"#$%&'()*+,-./");
display.println("0123456789:;<=>?");
display.println("@ABCDEFGHIJKLMNO");
display.println("PQRSTUVWXYZ[\\]^_");
#if defined(_GxGDEW0154Z04_H_) || defined(_GxGDEW0213Z16_H_) || defined(_GxGDEW029Z10_H_) || defined(_GxGDEW027C44_H_)
display.setTextColor(GxEPD_RED);
#endif
display.println("`abcdefghijklmno");
display.println("pqrstuvwxyz{|}~ ");
display.update();
delay(5000);
But I am having trouble with any images showing up on the e-ink displays. This link shows the setup needed for the board to work correctly.
https://v4.cecdn.yun300.cn/100001_1909185148/EN-ESP32-02.pdf
Here is a screenshot of the needed settings:
and here is my settings:
My issue is that I cannot get the programmer model AVRISP MkII
I have looked for resources on how to install the above model but to no luck.
I have tried the normal upload and this is the output I get but nothing works. So I am assumin gI need the programmer model to make the ESP32 board work?
Box
