Gyroscope inaccurate on only 1 axis
I wrote some code that utilizes an ADXL345 accelerometer and a ITG3205 gyroscope to determine the angle relative to the horizon of my quadcopter. When the quad is sitting still, all is good. If I move it about somewhat roughly, the pitch angle will settle back to close to zero, as expected. But for some reason, the roll angle always ends up at a much higher value, anywhere from 9 to 90 degrees when it is again level. The code is the same in determining each angle respectively, so I am assuming that it is somehow accumulated drift from the gyroscope.
Any ideas? Help would be greatly appreciated. The code snippet doing these calculations is listed below.
void updateSensors(){
  getAccel();
  getGyro();
  getMag();
  calcAngle[0] = .90*gyroAngle[0]+(1-.90)*accAngle[0];                    //Complementary filter for calculating angle from both gyro and acc data
  calcAngle[1] = .90*gyroAngle[1]+(1-.90)*accAngle[1];
  Serial.print(" pitchAngle  "); Serial.print(accAngle[0]); Serial.print("  rollAngle  "); Serial.print(calcAngle[1]);
void getAccel(){
  if ((micros() - nta) >= 2500){                                         //Only update every 2500 microseconds, ~400 Hz rate
    int regAddress = 0x32;
    readFrom(accelDev, regAddress, 6, buffAcc);                          //Starting at the first data register, reades the bytes for x, y, z axis successively
    accX = ((((int)buffAcc[1]) << 8) | buffAcc[0]) + acc_offx;           //Shifts the first byte left 8 places and concatenates first byte with second to get 16-bit sensor value
    accY = ((((int)buffAcc[3]) << 8) | buffAcc[2]) + acc_offy;
    accZ = ((((int)buffAcc[5]) << 8) | buffAcc[4]) + acc_offz;
    faccX = accX * alpha + (faccX * (1.0 - alpha));                       //Low Pass Filter
    faccY = accY * alpha + (faccY * (1.0 - alpha));
    faccZ = accZ * alpha + (faccZ * (1.0 - alpha));
    accAngle[1] = -(atan2(faccX, faccZ))*radToDeg;                         //Y-axis angle, Roll
    accAngle[0] = (atan2(faccY, faccZ))*radToDeg;                          //X-axis angle, Pitch
    nta = micros();
void getGyro(){
  if ((micros() - ntg) >= 10000){                                                  //Only update every 10,000 microseconds, ~100 Hz rate
    int regAddress = 0x1B;
    readFrom(gyroDev, regAddress, 8, buffGyro);
    gyrox_temp = (((((int)buffGyro[2]) << 8) | buffGyro[3]) & 65528) + g_offx;    //Shifting the first byte 8 bits to the left and then concatenating the first and second bytes using a bit-wise OR operator ------ 65532
    gyroy_temp = (((((int)buffGyro[4]) << 8) | buffGyro[5]) & 65528) + g_offy;    //the concatenated values are then bit-wise ANDed with a binary value of "1111111111111100" that effectively turns the last 2 bits to zero
    gyroz_temp = (((((int)buffGyro[6]) << 8) | buffGyro[7]) & 65528) + g_offz;    //so that the noise can be ignored
    //temp = (((int)buffGyro[0]) << 8) | buffGyro[1];                             //Reading the data from the ITG3205 for temperature, not currently used
    double dt = (micros() - ntg)/1000000.00;                                      //To calculate the time since the last measurement
    gyroX = (double)gyrox_temp*dt/14.375;                                         //Per the data sheet, sensitivity scale factor per LSB/(deg/sec)
    gyroY = (double)gyroy_temp*dt/14.375;
    gyroZ = (double)gyroz_temp*dt/14.375;
    gyroMAF();
    gyroAngle[0] += gyroX_ave;
    gyroAngle[1] += gyroY_ave;
    gyroAngle[2] += gyroZ_ave;
    gyroMAFCounter++;
    if (gyroMAFCounter == (GYRO_MAF_NR - 1)) gyroMAFCounter = 0;
    ntg = micros();
  Serial.print("  gyrox_temp  "); Serial.print(gyrox_temp);Serial.print("  gyroy_temp  "); Serial.println(gyroy_temp);
