Hello there;
I am trying to make a lightsaber project with Arduino Nano ATmega328P processor.
I made all the connections in the schematic (except the led)
Then I loaded the necessary libraries and the code I gave in the attachment.
The sound should have been like the classic lightsaber sound, but ([- YouTube ) sounds like this link.
Also, the MPU6050 light is on, but when I shake it, the sound does not change.
The control button in the diagram below does not work either, but the mushroom led is on.
I am getting this type of error in the code. Errors are available below
It's my brother's birthday at the end of this month and I'm preparing it as a gift for him. Please help me.
Thank you and may the Force be with you!
Scheme:
Arduino code:
SUPER-DUPER COOL ARDUINO BASED MULTICOLOR SOUND PLAYING LIGHTSABER!
HARDWARE:
Addressable LED strip (WS2811) to get any blade color and smooth turn on effect
MicroSD card module to play some sounds
IMU MPU6050 (accel + gyro) to generate hum. Frequency depends on angle velocity of blade
OR measure angle speed and play some hum sounds from SD
CAPABILITIES:
Smooth turning on/off with lightsaber-like sound effect
Randomly pulsing color (you can turn it off)
Sounds:
MODE 1: generated hum. Frequency depends on angle velocity of blade
MODE 2: hum sound from SD card
Slow swing - long hum sound (randomly from 4 sounds)
Fast swing - short hum sound (randomly from 5 sounds)
Bright white flash when hitting
Play one of 16 hit sounds, when hit
Weak hit - short sound
Hard hit - long "bzzzghghhdh" sound
After power on blade shows current battery level from 0 to 100 percent
Battery safe mode:
Battery is drain BEFORE TURNING ON: GyverSaber will not turn on, button LED will PULSE a couple of times
Battery is drain AFTER TURNING ON: GyverSaber will be turned off automatically
CONTROL BUTTON:
HOLD - turn on / turn off GyverSaber
TRIPLE CLICK - change color (red - green - blue - yellow - pink - ice blue)
QUINARY CLICK - change sound mode (hum generation - hum playing)
Selected color and sound mode stored in EEPROM (non-volatile memory)
// ---------------------------- SETTINGS -------------------------------
#define NUM_LEDS 30 // number of microcircuits WS2811 on LED strip (note: one WS2811 controls 3 LEDs!)
#define BTN_TIMEOUT 800 // button hold delay, ms
#define BRIGHTNESS 255 // max LED brightness (0 - 255)
#define SWING_TIMEOUT 500 // timeout between swings
#define SWING_L_THR 150 // swing angle speed threshold
#define SWING_THR 300 // fast swing angle speed threshold
#define STRIKE_THR 150 // hit acceleration threshold
#define STRIKE_S_THR 320 // hard hit acceleration threshold
#define FLASH_DELAY 80 // flash time while hit
#define PULSE_ALLOW 1 // blade pulsation (1 - allow, 0 - disallow)
#define PULSE_AMPL 20 // pulse amplitude
#define PULSE_DELAY 30 // delay between pulses
#define R1 100000 // voltage divider real resistance
#define R2 51000 // voltage divider real resistance
#define BATTERY_SAFE 1 // battery monitoring (1 - allow, 0 - disallow)
#define DEBUG 0 // debug information in Serial (1 - allow, 0 - disallow)
#define LED_PIN 6
#define BTN 3
#define IMU_GND A1
#define SD_GND A0
#define VOLT_PIN A6
#define BTN_LED 4
// -------------------------- LIBS ---------------------------
#include <avr/pgmspace.h> // PROGMEM library
#include <SD.h>
#include <TMRpcm.h> // audio from SD library
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
#include <toneAC.h> // hum generation library
#include "FastLED.h" // addressable LED library
#include <EEPROM.h>
CRGB leds[NUM_LEDS];
#define SD_ChipSelectPin 10
TMRpcm tmrpcm;
MPU6050 accelgyro;
// ------------------------------ VARIABLES ---------------------------------
int16_t ax, ay, az;
int16_t gx, gy, gz;
unsigned long ACC, GYR, COMPL;
int gyroX, gyroY, gyroZ, accelX, accelY, accelZ, freq, freq_f = 20;
float k = 0.2;
unsigned long humTimer = -9000, mpuTimer, nowTimer;
int stopTimer;
boolean bzzz_flag, ls_chg_state, ls_state;
boolean btnState, btn_flag, hold_flag;
byte btn_counter;
unsigned long btn_timer, PULSE_timer, swing_timer, swing_timeout, battery_timer, bzzTimer;
byte nowNumber;
byte LEDcolor; // 0 - red, 1 - green, 2 - blue, 3 - pink, 4 - yellow, 5 - ice blue
byte nowColor, red, green, blue, redOffset, greenOffset, blueOffset;
boolean eeprom_flag, swing_flag, swing_allow, strike_flag, HUMmode;
float voltage;
int PULSEOffset;
// --------------------------------- SOUNDS ----------------------------------
const char strike1[] PROGMEM = "SK1.wav";
const char strike2[] PROGMEM = "SK2.wav";
const char strike3[] PROGMEM = "SK3.wav";
const char strike4[] PROGMEM = "SK4.wav";
const char strike5[] PROGMEM = "SK5.wav";
const char strike6[] PROGMEM = "SK6.wav";
const char strike7[] PROGMEM = "SK7.wav";
const char strike8[] PROGMEM = "SK8.wav";
const char* const strikes[] PROGMEM = {
strike1, strike2, strike3, strike4, strike5, strike6, strike7, strike8
int strike_time[8] = {779, 563, 687, 702, 673, 661, 666, 635};
const char strike_s1[] PROGMEM = "SKS1.wav";
const char strike_s2[] PROGMEM = "SKS2.wav";
const char strike_s3[] PROGMEM = "SKS3.wav";
const char strike_s4[] PROGMEM = "SKS4.wav";
const char strike_s5[] PROGMEM = "SKS5.wav";
const char strike_s6[] PROGMEM = "SKS6.wav";
const char strike_s7[] PROGMEM = "SKS7.wav";
const char strike_s8[] PROGMEM = "SKS8.wav";
const char* const strikes_short[] PROGMEM = {
strike_s1, strike_s2, strike_s3, strike_s4,
strike_s5, strike_s6, strike_s7, strike_s8
int strike_s_time[8] = {270, 167, 186, 250, 252, 255, 250, 238};
const char swing1[] PROGMEM = "SWS1.wav";
const char swing2[] PROGMEM = "SWS2.wav";
const char swing3[] PROGMEM = "SWS3.wav";
const char swing4[] PROGMEM = "SWS4.wav";
const char swing5[] PROGMEM = "SWS5.wav";
const char* const swings[] PROGMEM = {
swing1, swing2, swing3, swing4, swing5
int swing_time[8] = {389, 372, 360, 366, 337};
const char swingL1[] PROGMEM = "SWL1.wav";
const char swingL2[] PROGMEM = "SWL2.wav";
const char swingL3[] PROGMEM = "SWL3.wav";
const char swingL4[] PROGMEM = "SWL4.wav";
const char* const swings_L[] PROGMEM = {
swingL1, swingL2, swingL3, swingL4
int swing_time_L[8] = {636, 441, 772, 702};
char BUFFER[10];
FastLED.addLeds<WS2811, LED_PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness(100); // ~40% of LED strip brightness
setAll(0, 0, 0); // and turn it off
Wire.begin();
// ---- НАСТРОЙКА ПИНОВ ----
pinMode(BTN, INPUT_PULLUP);
pinMode(IMU_GND, OUTPUT);
pinMode(SD_GND, OUTPUT);
pinMode(BTN_LED, OUTPUT);
digitalWrite(IMU_GND, 0);
digitalWrite(SD_GND, 0);
digitalWrite(BTN_LED, 1);
randomSeed(analogRead(2)); // starting point for random generator
// IMU initialization
accelgyro.initialize();
accelgyro.setFullScaleAccelRange(MPU6050_ACCEL_FS_16);
accelgyro.setFullScaleGyroRange(MPU6050_GYRO_FS_250);
if (DEBUG) {
if (accelgyro.testConnection()) Serial.println(F("MPU6050 OK"));
else Serial.println(F("MPU6050 fail"));
// SD initialization
tmrpcm.speakerPin = 9;
tmrpcm.setVolume(5);
tmrpcm.quality(1);
if (DEBUG) {
if (SD.begin(8)) Serial.println(F("SD OK"));
else Serial.println(F("SD fail"));
SD.begin(8);
if ((EEPROM.read(0) >= 0) && (EEPROM.read(0) <= 5)) { // check first start
nowColor = EEPROM.read(0); // remember color
HUMmode = EEPROM.read(1); // remember mode
} else { // first start
EEPROM.write(0, 0); // set default
EEPROM.write(1, 0); // set default
nowColor = 0; // set default
setColor(nowColor);
byte capacity = voltage_measure(); // get battery level
capacity = map(capacity, 100, 0, (NUM_LEDS / 2 - 1), 1); // convert into blade lenght
if (DEBUG) {
Serial.print(F("Battery: "));
Serial.println(capacity);
for (char i = 0; i <= capacity; i++) { // show battery level
setPixel(i, red, green, blue);
setPixel((NUM_LEDS - 1 - i), red, green, blue);
FastLED.show();
delay(25);
delay(1000); // 1 second to show battery level
setAll(0, 0, 0);
FastLED.setBrightness(BRIGHTNESS); // set bright
// --- MAIN LOOP---
randomPULSE();
getFreq();
on_off_sound();
btnTick();
strikeTick();
swingTick();
batteryTick();
// --- MAIN LOOP---
void btnTick() {
btnState = !digitalRead(BTN);
if (btnState && !btn_flag) {
if (DEBUG) Serial.println(F("BTN PRESS"));
btn_flag = 1;
btn_counter++;
btn_timer = millis();
if (!btnState && btn_flag) {
btn_flag = 0;
hold_flag = 0;
// если кнопка удерживается
if (btn_flag && btnState && (millis() - btn_timer > BTN_TIMEOUT) && !hold_flag) {
ls_chg_state = 1; // flag to change saber state (on/off)
hold_flag = 1;
btn_counter = 0;
// если кнопка была нажата несколько раз до таймаута
if ((millis() - btn_timer > BTN_TIMEOUT) && (btn_counter != 0)) {
if (ls_state) {
if (btn_counter == 3) { // 3 press count
nowColor++; // change color
if (nowColor >= 6) nowColor = 0;
setColor(nowColor);
setAll(red, green, blue);
eeprom_flag = 1;
if (btn_counter == 5) { // 5 press count
HUMmode = !HUMmode;
if (HUMmode) {
noToneAC();
tmrpcm.play("HUM.wav");
tmrpcm.disable();
toneAC(freq_f);
eeprom_flag = 1;
btn_counter = 0;
void on_off_sound() {
if (ls_chg_state) { // if change flag
if (!ls_state) { // if GyverSaber is turned off
if (voltage_measure() > 10 || !BATTERY_SAFE) {
if (DEBUG) Serial.println(F("SABER ON"));
tmrpcm.play("ON.wav");
delay(200);
light_up();
delay(200);
bzzz_flag = 1;
ls_state = true; // remember that turned on
if (HUMmode) {
noToneAC();
tmrpcm.disable();
toneAC(freq_f);
if (DEBUG) Serial.println(F("LOW VOLTAGE!"));
for (int i = 0; i < 5; i++) {
digitalWrite(BTN_LED, 0);
delay(400);
delay(400);
} else { // if GyverSaber is turned on
noToneAC();
bzzz_flag = 0;
tmrpcm.play("OFF.wav");
delay(300);
light_down();
delay(300);
tmrpcm.disable();
if (DEBUG) Serial.println(F("SABER OFF"));
ls_state = false;
if (eeprom_flag) {
eeprom_flag = 0;
EEPROM.write(0, nowColor); // write color in EEPROM
EEPROM.write(1, HUMmode); // write mode in EEPROM
ls_chg_state = 0;
if (((millis() - humTimer) > 9000) && bzzz_flag && HUMmode) {
humTimer = millis();
swing_flag = 1;
strike_flag = 0;
long delta = millis() - bzzTimer;
if ((delta > 3) && bzzz_flag && !HUMmode) {
if (strike_flag) {
tmrpcm.disable();
strike_flag = 0;
toneAC(freq_f);
bzzTimer = millis();
void randomPULSE() {
if (PULSE_ALLOW && ls_state && (millis() - PULSE_timer > PULSE_DELAY)) {
PULSE_timer = millis();
PULSEOffset = PULSEOffset * k + random(-PULSE_AMPL, PULSE_AMPL) * (1 - k);
if (nowColor == 0) PULSEOffset = constrain(PULSEOffset, -15, 5);
redOffset = constrain(red + PULSEOffset, 0, 255);
greenOffset = constrain(green + PULSEOffset, 0, 255);
blueOffset = constrain(blue + PULSEOffset, 0, 255);
setAll(redOffset, greenOffset, blueOffset);
void strikeTick() {
if ((ACC > STRIKE_THR) && (ACC < STRIKE_S_THR)) {
if (!HUMmode) noToneAC();
nowNumber = random(8);
// читаем название трека из PROGMEM
strcpy_P(BUFFER, (char*)pgm_read_word(&(strikes_short[nowNumber])));
tmrpcm.play(BUFFER);
hit_flash();
if (!HUMmode)
bzzTimer = millis() + strike_s_time[nowNumber] - FLASH_DELAY;
humTimer = millis() - 9000 + strike_s_time[nowNumber] - FLASH_DELAY;
strike_flag = 1;
if (ACC >= STRIKE_S_THR) {
strcpy_P(BUFFER, (char*)pgm_read_word(&(strikes[nowNumber])));
hit_flash();
if (!HUMmode)
bzzTimer = millis() + strike_time[nowNumber] - FLASH_DELAY;
humTimer = millis() - 9000 + strike_time[nowNumber] - FLASH_DELAY;
strike_flag = 1;
void swingTick() {
if (GYR > 80 && (millis() - swing_timeout > 100) && HUMmode) {
swing_timeout = millis();
if (((millis() - swing_timer) > SWING_TIMEOUT) && swing_flag && !strike_flag) {
if (GYR >= SWING_THR) {
nowNumber = random(5);
strcpy_P(BUFFER, (char*)pgm_read_word(&(swings[nowNumber])));
humTimer = millis() - 9000 + swing_time[nowNumber];
swing_flag = 0;
swing_timer = millis();
swing_allow = 0;
if ((GYR > SWING_L_THR) && (GYR < SWING_THR)) {
strcpy_P(BUFFER, (char*)pgm_read_word(&(swings_L[nowNumber])));
humTimer = millis() - 9000 + swing_time_L[nowNumber];
swing_flag = 0;
swing_allow = 0;
void getFreq() {
if (ls_state) { // if GyverSaber is on
if (millis() - mpuTimer > 500) {
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// find absolute and divide on 100
gyroX = abs(gx / 100);
gyroY = abs(gy / 100);
gyroZ = abs(gz / 100);
accelX = abs(ax / 100);
accelY = abs(ay / 100);
accelZ = abs(az / 100);
// vector sum
ACC = sq((long)accelX) + sq((long)accelY) + sq((long)accelZ);
ACC = sqrt(ACC);
GYR = sq((long)gyroX) + sq((long)gyroY) + sq((long)gyroZ);
GYR = sqrt((long)GYR);
COMPL = ACC + GYR;
// отладка работы IMU
Serial.print("$");
Serial.print(gyroX);
Serial.print(" ");
Serial.print(gyroY);
Serial.print(" ");
Serial.print(gyroZ);
Serial.println(";");
freq = (long)COMPL * COMPL / 1500; // parabolic tone change
freq = constrain(freq, 18, 300);
freq_f = freq * k + freq_f * (1 - k); // smooth filter
mpuTimer = micros();
void setPixel(int Pixel, byte red, byte green, byte blue) {
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
void setAll(byte red, byte green, byte blue) {
for (int i = 0; i < NUM_LEDS; i++ ) {
FastLED.show();
void light_up() {
for (char i = 0; i <= (NUM_LEDS / 2 - 1); i++) {
FastLED.show();
delay(25);
void light_down() {
for (char i = (NUM_LEDS / 2 - 1); i >= 0; i--) {
setPixel(i, 0, 0, 0);
setPixel((NUM_LEDS - 1 - i), 0, 0, 0);
FastLED.show();
delay(25);
void hit_flash() {
setAll(255, 255, 255);
delay(FLASH_DELAY);
setAll(red, blue, green);
void setColor(byte color) {
switch (color) {
case 0:
red = 255;
green = 0;
blue = 0;
case 1:
red = 0;
green = 0;
blue = 255;
case 2:
red = 0;
green = 255;
blue = 0;
case 3:
red = 255;
green = 0;
blue = 255;
case 4:
red = 255;
green = 255;
blue = 0;
case 5:
red = 0;
green = 255;
blue = 255;
void batteryTick() {
if (millis() - battery_timer > 30000 && ls_state && BATTERY_SAFE) {
if (voltage_measure() < 15) {
ls_chg_state = 1;
battery_timer = millis();
byte voltage_measure() {
voltage = 0;
for (int i = 0; i < 10; i++) {
voltage += (float)analogRead(VOLT_PIN) * 5 / 1023 * (R1 + R2) / R2;
voltage = voltage / 10;
int volts = voltage / 3 * 100; // 3 cells!!!
if (volts > 387)
return map(volts, 420, 387, 100, 77);
else if ((volts <= 387) && (volts > 375) )
return map(volts, 387, 375, 77, 54);
else if ((volts <= 375) && (volts > 368) )
return map(volts, 375, 368, 54, 31);
else if ((volts <= 368) && (volts > 340) )
return map(volts, 368, 340, 31, 8);
else if (volts <= 340)
return map(volts, 340, 260, 8, 0);
And that's the mistake
Arduino:1.8.19 (Windows 10), Kart:"Arduino Nano, ATmega328P"
In file included from C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:69:0:
C:\Users\ozgur\OneDrive\Belgeler\Arduino\libraries\FastLED-master/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.005
# pragma message "FastLED version 3.001.005"
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino: In function 'void setup()':
GyverSaber:157:3: error: 'setAll' was not declared in this scope
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:157:3: note: suggested alternative: 'setbuf'
setbuf
GyverSaber:203:3: error: 'setColor' was not declared in this scope
setColor(nowColor);
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:203:3: note: suggested alternative: 'HeatColor'
setColor(nowColor);
HeatColor
GyverSaber:204:19: error: 'voltage_measure' was not declared in this scope
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:204:19: note: suggested alternative: 'ColorTemperature'
ColorTemperature
GyverSaber:212:5: error: 'setPixel' was not declared in this scope
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:212:5: note: suggested alternative: 'strikes'
strikes
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino: In function 'void loop()':
GyverSaber:224:3: error: 'randomPULSE' was not declared in this scope
randomPULSE();
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:224:3: note: suggested alternative: 'random16'
randomPULSE();
random16
GyverSaber:225:3: error: 'getFreq' was not declared in this scope
getFreq();
GyverSaber:228:3: error: 'strikeTick' was not declared in this scope
strikeTick();
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:228:3: note: suggested alternative: 'strike_s8'
strikeTick();
strike_s8
GyverSaber:229:3: error: 'swingTick' was not declared in this scope
swingTick();
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:229:3: note: suggested alternative: 'btnTick'
swingTick();
btnTick
GyverSaber:230:3: error: 'batteryTick' was not declared in this scope
batteryTick();
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:230:3: note: suggested alternative: 'btnTick'
batteryTick();
btnTick
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino: In function 'void btnTick()':
GyverSaber:258:9: error: 'setColor' was not declared in this scope
setColor(nowColor);
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:258:9: note: suggested alternative: 'HeatColor'
setColor(nowColor);
HeatColor
GyverSaber:259:9: error: 'setAll' was not declared in this scope
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:259:9: note: suggested alternative: 'setbuf'
setbuf
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:266:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino: In function 'void on_off_sound()':
GyverSaber:281:11: error: 'voltage_measure' was not declared in this scope
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:281:11: note: suggested alternative: 'ColorTemperature'
ColorTemperature
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:283:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
GyverSaber:285:9: error: 'light_up' was not declared in this scope
light_up();
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:291:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:308:28: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
GyverSaber:310:7: error: 'light_down' was not declared in this scope
light_down();
C:\Users\ozgur\OneDrive\Belgeler\GyverSyber\GyverSaber\GyverSaber.ino:323:22: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
GyverSaber:338:20: error: a function-definition is not allowed here before '{' token
GyverSaber:350:19: error: a function-definition is not allowed here before '{' token
void strikeTick() {
GyverSaber:379:18: error: a function-definition is not allowed here before '{' token
void swingTick() {
GyverSaber:407:16: error: a function-definition is not allowed here before '{' token
void getFreq() {
GyverSaber:444:59: error: a function-definition is not allowed here before '{' token
GyverSaber:450:46: error: a function-definition is not allowed here before '{' token
GyverSaber:457:17: error: a function-definition is not allowed here before '{' token
void light_up() {
GyverSaber:466:19: error: a function-definition is not allowed here before '{' token
void light_down() {
GyverSaber:475:18: error: a function-definition is not allowed here before '{' token
void hit_flash() {
GyverSaber:481:27: error: a function-definition is not allowed here before '{' token
GyverSaber:517:20: error: a function-definition is not allowed here before '{' token
GyverSaber:526:24: error: a function-definition is not allowed here before '{' token
GyverSaber:543:1: error: expected '}' at end of input
"EEPROM.h" için birden fazla library bulundu
Kullanılıyor: C:\Users\ozgur\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM
Kullanılmıyor: C:\Users\ozgur\OneDrive\Belgeler\Arduino\libraries\arduino-NVM
exit status 1
option enabled in File -> Preferences.
