Having issues with mpu6050 (HELP PLEASE)
HI
I'm trying to do this project
I connected everything according to the diagram
everything works fine except for the mpu6050
I tried 2 different boards and they both failed to recognize (mpu6050 fail) message on the serial monitor
I tested both mpu6050 using the mpu6050 sketch library and both work fine, so it's not a problem with the boards I think.
can someone help me, please!
thanks
the error messege
Capture
this is the code I'm using
with an Arduino nano
     SUPER-DUPER COOL ARDUINO BASED MULTICOLOR SOUND PLAYING LIGHTSABER!
   HARDWARE:
     Addressable LED strip (WS2811) to get any blade color and smooth turn on effect
     MicroSD card module to play some sounds
     IMU MPU6050 (accel + gyro) to generate hum. Frequency depends on angle velocity of blade
     OR measure angle speed and play some hum sounds from SD
   CAPABILITIES:
     Smooth turning on/off with lightsaber-like sound effect
     Randomly pulsing color (you can turn it off)
     Sounds:
       MODE 1: generated hum. Frequency depends on angle velocity of blade
       MODE 2: hum sound from SD card
         Slow swing - long hum sound (randomly from 4 sounds)
         Fast swing - short hum sound (randomly from 5 sounds)
     Bright white flash when hitting
     Play one of 16 hit sounds, when hit
       Weak hit - short sound
       Hard hit - long "bzzzghghhdh" sound
     After power on blade shows current battery level from 0 to 100 percent
     Battery safe mode:
       Battery is drain BEFORE TURNING ON: GyverSaber will not turn on, button LED will PULSE a couple of times
       Battery is drain AFTER TURNING ON: GyverSaber will be turned off automatically
   CONTROL BUTTON:
     HOLD - turn on / turn off GyverSaber
     TRIPLE CLICK - change color (red - green - blue - yellow - pink - ice blue)
     QUINARY CLICK - change sound mode (hum generation - hum playing)
     Selected color and sound mode stored in EEPROM (non-volatile memory)
   Project GitHub repository: https://github.com/AlexGyver/EnglishProjects/tree/master/GyverSaber
   YouTube channel: https://www.youtube.com/channel/UCNEOyqhGzutj-YS-d5ckYdg?sub_confirmation=1
   Author: MadGyver
// ---------------------------- SETTINGS -------------------------------
#define NUM_LEDS 38         // number of microcircuits WS2811 on LED strip (note: one WS2811 controls 3 LEDs!)
#define BTN_TIMEOUT 800     // button hold delay, ms
#define BRIGHTNESS 255      // max LED brightness (0 - 255)
#define SWING_TIMEOUT 500   // timeout between swings
#define SWING_L_THR 150     // swing angle speed threshold
#define SWING_THR 300       // fast swing angle speed threshold
#define STRIKE_THR 150      // hit acceleration threshold
#define STRIKE_S_THR 320    // hard hit acceleration threshold
#define FLASH_DELAY 80      // flash time while hit
#define PULSE_ALLOW 1       // blade pulsation (1 - allow, 0 - disallow)
#define PULSE_AMPL 20       // pulse amplitude
#define PULSE_DELAY 30      // delay between pulses
#define R1 100000           // voltage divider real resistance
#define R2 51000            // voltage divider real resistance
#define BATTERY_SAFE 1      // battery monitoring (1 - allow, 0 - disallow)
#define DEBUG 1             // debug information in Serial (1 - allow, 0 - disallow)
#define LED_PIN 6
#define BTN 3
#define IMU_GND A1
#define SD_GND A0
#define VOLT_PIN A6
#define BTN_LED 4
// -------------------------- LIBS ---------------------------
#include <avr/pgmspace.h>   // PROGMEM library
#include <SD.h>
#include <TMRpcm.h>         // audio from SD library
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
#include <toneAC.h>         // hum generation library
#include "FastLED.h"        // addressable LED library
#include <EEPROM.h>
CRGB leds[NUM_LEDS];
#define SD_ChipSelectPin 10
TMRpcm tmrpcm;
MPU6050 accelgyro;
// ------------------------------ VARIABLES ---------------------------------
int16_t ax, ay, az;
int16_t gx, gy, gz;
unsigned long ACC, GYR, COMPL;
int gyroX, gyroY, gyroZ, accelX, accelY, accelZ, freq, freq_f = 20;
float k = 0.2;
unsigned long humTimer = -9000, mpuTimer, nowTimer;
int stopTimer;
boolean bzzz_flag, ls_chg_state, ls_state;
boolean btnState, btn_flag, hold_flag;
byte btn_counter;
unsigned long btn_timer, PULSE_timer, swing_timer, swing_timeout, battery_timer, bzzTimer;
byte nowNumber;
byte LEDcolor;  // 0 - red, 1 - green, 2 - blue, 3 - pink, 4 - yellow, 5 - ice blue
byte nowColor, red, green, blue, redOffset, greenOffset, blueOffset;
boolean eeprom_flag, swing_flag, swing_allow, strike_flag, HUMmode;
float voltage;
int PULSEOffset;
// --------------------------------- SOUNDS ----------------------------------
const char strike1[] PROGMEM = "SK1.wav";
const char strike2[] PROGMEM = "SK2.wav";
const char strike3[] PROGMEM = "SK3.wav";
const char strike4[] PROGMEM = "SK4.wav";
const char strike5[] PROGMEM = "SK5.wav";
const char strike6[] PROGMEM = "SK6.wav";
const char strike7[] PROGMEM = "SK7.wav";
const char strike8[] PROGMEM = "SK8.wav";
const char* const strikes[] PROGMEM  = {
  strike1, strike2, strike3, strike4, strike5, strike6, strike7, strike8
int strike_time[8] = {779, 563, 687, 702, 673, 661, 666, 635};
const char strike_s1[] PROGMEM = "SKS1.wav";
const char strike_s2[] PROGMEM = "SKS2.wav";
const char strike_s3[] PROGMEM = "SKS3.wav";
const char strike_s4[] PROGMEM = "SKS4.wav";
const char strike_s5[] PROGMEM = "SKS5.wav";
const char strike_s6[] PROGMEM = "SKS6.wav";
const char strike_s7[] PROGMEM = "SKS7.wav";
const char strike_s8[] PROGMEM = "SKS8.wav";
const char* const strikes_short[] PROGMEM = {
  strike_s1, strike_s2, strike_s3, strike_s4,
  strike_s5, strike_s6, strike_s7, strike_s8
int strike_s_time[8] = {270, 167, 186, 250, 252, 255, 250, 238};
const char swing1[] PROGMEM = "SWS1.wav";
const char swing2[] PROGMEM = "SWS2.wav";
const char swing3[] PROGMEM = "SWS3.wav";
const char swing4[] PROGMEM = "SWS4.wav";
const char swing5[] PROGMEM = "SWS5.wav";
const char* const swings[] PROGMEM  = {
  swing1, swing2, swing3, swing4, swing5
int swing_time[8] = {389, 372, 360, 366, 337};
const char swingL1[] PROGMEM = "SWL1.wav";
const char swingL2[] PROGMEM = "SWL2.wav";
const char swingL3[] PROGMEM = "SWL3.wav";
const char swingL4[] PROGMEM = "SWL4.wav";
const char* const swings_L[] PROGMEM  = {
  swingL1, swingL2, swingL3, swingL4
int swing_time_L[8] = {636, 441, 772, 702};
char BUFFER[10];
  FastLED.addLeds<WS2811, LED_PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(100);  // ~40% of LED strip brightness
  setAll(0, 0, 0);             // and turn it off
  Wire.begin();
  // ---- НАСТРОЙКА ПИНОВ ----
  pinMode(BTN, INPUT_PULLUP);
  pinMode(IMU_GND, OUTPUT);
  pinMode(SD_GND, OUTPUT);
  pinMode(BTN_LED, OUTPUT);
  digitalWrite(IMU_GND, 0);
  digitalWrite(SD_GND, 0);
  digitalWrite(BTN_LED, 1);
  randomSeed(analogRead(2));    // starting point for random generator
  // IMU initialization
  accelgyro.initialize();
  accelgyro.setFullScaleAccelRange(MPU6050_ACCEL_FS_16);
  accelgyro.setFullScaleGyroRange(MPU6050_GYRO_FS_250);
  if (DEBUG) {
    if (accelgyro.testConnection()) Serial.println(F("MPU6050 OK"));
    else Serial.println(F("MPU6050 fail"));
  // SD initialization
  tmrpcm.speakerPin = 9;
  tmrpcm.setVolume(5);
  tmrpcm.quality(1);
  if (DEBUG) {
    if (SD.begin(8)) Serial.println(F("SD OK"));
    else Serial.println(F("SD fail"));
    SD.begin(8);
  if ((EEPROM.read(0) >= 0) && (EEPROM.read(0) <= 5)) {  // check first start
    nowColor = EEPROM.read(0);   // remember color
    HUMmode = EEPROM.read(1);    // remember mode
  } else {                       // first start
    EEPROM.write(0, 0);          // set default
    EEPROM.write(1, 0);          // set default
    nowColor = 0;                // set default
  setColor(nowColor);
  byte capacity = voltage_measure();       // get battery level
  capacity = map(capacity, 100, 0, (NUM_LEDS / 2 - 1), 1);  // convert into blade lenght
  if (DEBUG) {
    Serial.print(F("Battery: "));
    Serial.println(capacity);
  for (char i = 0; i <= capacity; i++) {   // show battery level
    setPixel(i, red, green, blue);
    setPixel((NUM_LEDS - 1 - i), red, green, blue);
    FastLED.show();
    delay(25);
  delay(1000);                         // 1 second to show battery level
  setAll(0, 0, 0);
  FastLED.setBrightness(BRIGHTNESS);   // set bright
// --- MAIN LOOP---
  randomPULSE();
  getFreq();
  on_off_sound();
  btnTick();
  strikeTick();
  swingTick();
  batteryTick();
// --- MAIN LOOP---
void btnTick() {
  btnState = !digitalRead(BTN);
  if (btnState && !btn_flag) {
    if (DEBUG) Serial.println(F("BTN PRESS"));
    btn_flag = 1;
    btn_counter++;
    btn_timer = millis();
  if (!btnState && btn_flag) {
    btn_flag = 0;
    hold_flag = 0;
  // если кнопка удерживается
  if (btn_flag && btnState && (millis() - btn_timer > BTN_TIMEOUT) && !hold_flag) {
    ls_chg_state = 1;                     // flag to change saber state (on/off)
    hold_flag = 1;
    btn_counter = 0;
  // если кнопка была нажата несколько раз до таймаута
  if ((millis() - btn_timer > BTN_TIMEOUT) && (btn_counter != 0)) {
    if (ls_state) {
      if (btn_counter == 3) {               // 3 press count
        nowColor++;                         // change color
        if (nowColor >= 6) nowColor = 0;
        setColor(nowColor);
        setAll(red, green, blue);
        eeprom_flag = 1;
      if (btn_counter == 5) {               // 5 press count
        HUMmode = !HUMmode;
        if (HUMmode) {
          noToneAC();
          tmrpcm.play("HUM.wav");
          tmrpcm.disable();
          toneAC(freq_f);
        eeprom_flag = 1;
    btn_counter = 0;
void on_off_sound() {
  if (ls_chg_state) {                // if change flag
    if (!ls_state) {                 // if GyverSaber is turned off
      if (voltage_measure() > 10 || !BATTERY_SAFE) {
        if (DEBUG) Serial.println(F("SABER ON"));
        tmrpcm.play("ON.wav");
        delay(200);
        light_up();
        delay(200);
        bzzz_flag = 1;
        ls_state = true;               // remember that turned on
        if (HUMmode) {
          noToneAC();
          tmrpcm.disable();
          toneAC(freq_f);
        if (DEBUG) Serial.println(F("LOW VOLTAGE!"));
        for (int i = 0; i < 5; i++) {
          digitalWrite(BTN_LED, 0);
          delay(400);
          delay(400);
    } else {                         // if GyverSaber is turned on
      noToneAC();
      bzzz_flag = 0;
      tmrpcm.play("OFF.wav");
      delay(300);
      light_down();
      delay(300);
      tmrpcm.disable();
      if (DEBUG) Serial.println(F("SABER OFF"));
      ls_state = false;
      if (eeprom_flag) {
        eeprom_flag = 0;
        EEPROM.write(0, nowColor);   // write color in EEPROM
        EEPROM.write(1, HUMmode);    // write mode in EEPROM
    ls_chg_state = 0;
  if (((millis() - humTimer) > 9000) && bzzz_flag && HUMmode) {
    humTimer = millis();
    swing_flag = 1;
    strike_flag = 0;
  long delta = millis() - bzzTimer;
  if ((delta > 3) && bzzz_flag && !HUMmode) {
    if (strike_flag) {
      tmrpcm.disable();
      strike_flag = 0;
    toneAC(freq_f);
    bzzTimer = millis();
void randomPULSE() {
  if (PULSE_ALLOW && ls_state && (millis() - PULSE_timer > PULSE_DELAY)) {
    PULSE_timer = millis();
    PULSEOffset = PULSEOffset * k + random(-PULSE_AMPL, PULSE_AMPL) * (1 - k);
    if (nowColor == 0) PULSEOffset = constrain(PULSEOffset, -15, 5);
    redOffset = constrain(red + PULSEOffset, 0, 255);
    greenOffset = constrain(green + PULSEOffset, 0, 255);
    blueOffset = constrain(blue + PULSEOffset, 0, 255);
    setAll(redOffset, greenOffset, blueOffset);
void strikeTick() {
  if ((ACC > STRIKE_THR) && (ACC < STRIKE_S_THR)) {
    if (!HUMmode) noToneAC();
    nowNumber = random(8);
    // читаем название трека из PROGMEM
    strcpy_P(BUFFER, (char*)pgm_read_word(&(strikes_short[nowNumber])));
    tmrpcm.play(BUFFER);
    hit_flash();
    if (!HUMmode)
      bzzTimer = millis() + strike_s_time[nowNumber] - FLASH_DELAY;
      humTimer = millis() - 9000 + strike_s_time[nowNumber] - FLASH_DELAY;
    strike_flag = 1;
  if (ACC >= STRIKE_S_THR) {
    strcpy_P(BUFFER, (char*)pgm_read_word(&(strikes[nowNumber])));
    hit_flash();
    if (!HUMmode)
      bzzTimer = millis() + strike_time[nowNumber] - FLASH_DELAY;
      humTimer = millis() - 9000 + strike_time[nowNumber] - FLASH_DELAY;
    strike_flag = 1;
void swingTick() {
  if (GYR > 80 && (millis() - swing_timeout > 100) && HUMmode) {
    swing_timeout = millis();
    if (((millis() - swing_timer) > SWING_TIMEOUT) && swing_flag && !strike_flag) {
      if (GYR >= SWING_THR) {
        nowNumber = random(5);
        strcpy_P(BUFFER, (char*)pgm_read_word(&(swings[nowNumber])));
        humTimer = millis() - 9000 + swing_time[nowNumber];
        swing_flag = 0;
        swing_timer = millis();
        swing_allow = 0;
      if ((GYR > SWING_L_THR) && (GYR < SWING_THR)) {
        strcpy_P(BUFFER, (char*)pgm_read_word(&(swings_L[nowNumber])));
        humTimer = millis() - 9000 + swing_time_L[nowNumber];
        swing_flag = 0;
        swing_allow = 0;
void getFreq() {
  if (ls_state) {                                               // if GyverSaber is on
    if (millis() - mpuTimer > 500) {
      accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
      // find absolute and divide on 100
      gyroX = abs(gx / 100);
      gyroY = abs(gy / 100);
      gyroZ = abs(gz / 100);
      accelX = abs(ax / 100);
      accelY = abs(ay / 100);
      accelZ = abs(az / 100);
      // vector sum
      ACC = sq((long)accelX) + sq((long)accelY) + sq((long)accelZ);
      ACC = sqrt(ACC);
      GYR = sq((long)gyroX) + sq((long)gyroY) + sq((long)gyroZ);
      GYR = sqrt((long)GYR);
      COMPL = ACC + GYR;
         // отладка работы IMU
         Serial.print("$");
         Serial.print(gyroX);
         Serial.print(" ");
         Serial.print(gyroY);
         Serial.print(" ");
         Serial.print(gyroZ);
         Serial.println(";");
      freq = (long)COMPL * COMPL / 1500;                        // parabolic tone change
      freq = constrain(freq, 18, 300);
      freq_f = freq * k + freq_f * (1 - k);                     // smooth filter
      mpuTimer = micros();
void setPixel(int Pixel, byte red, byte green, byte blue) {
  leds[Pixel].r = red;
  leds[Pixel].g = green;
  leds[Pixel].b = blue;
void setAll(byte red, byte green, byte blue) {
  for (int i = 0; i < NUM_LEDS; i++ ) {
  FastLED.show();
void light_up() {
  for (char i = 0; i <= (NUM_LEDS / 2 - 1); i++) {
    FastLED.show();
    delay(25);
void light_down() {
  for (char i = (NUM_LEDS / 2 - 1); i >= 0; i--) {
    setPixel(i, 0, 0, 0);
    setPixel((NUM_LEDS - 1 - i), 0, 0, 0);
    FastLED.show();
    delay(25);
void hit_flash() {
  setAll(255, 255, 255);
  delay(FLASH_DELAY);
  setAll(red, blue, green);
void setColor(byte color) {
  switch (color) {
    case 0:
      red = 255;
      green = 0;
      blue = 0;
    case 1:
      red = 0;
      green = 0;
      blue = 255;
    case 2:
      red = 0;
      green = 255;
      blue = 0;
    case 3:
      red = 255;
      green = 0;
      blue = 255;
    case 4:
      red = 255;
      green = 255;
      blue = 0;
    case 5:
      red = 0;
      green = 255;
      blue = 255;
void batteryTick() {
  if (millis() - battery_timer > 30000 && ls_state && BATTERY_SAFE) {
    if (voltage_measure() < 15) {
      ls_chg_state = 1;
    battery_timer = millis();
byte voltage_measure() {
  voltage = 0;
  for (int i = 0; i < 10; i++) {
    voltage += (float)analogRead(VOLT_PIN) * 5 / 1023 * (R1 + R2) / R2;
  voltage = voltage / 10;
  int volts = voltage / 3 * 100;    // 3 cells!!!
  if (volts > 387)
    return map(volts, 420, 387, 100, 77);
  else if ((volts <= 387) && (volts > 375) )
    return map(volts, 387, 375, 77, 54);
  else if ((volts <= 375) && (volts > 368) )
    return map(volts, 375, 368, 54, 31);
  else if ((volts <= 368) && (volts > 340) )
    return map(volts, 368, 340, 31, 8);
  else if (volts <= 340)
    return map(volts, 340, 260, 8, 0);
The diagram shows the I2C lines connected directly to an Arduino being powered with 5V. There is no I2C pull up resistors shown, nor the internal 5V pull up resistor being disabled in the software.
The I2C lines on the mpu6050 needs a pull up resistor to 3V3 volts, about 1K8 to 3K3 will do. And the internal pull up resistors should be disabled in the setup function by using a pinMode(INPUT) on both pins.
There are likely to be pull up resistors on the mpu6050, but these will not be strong enough.
See also
Issues 1 on the Git Hub page.
hi
thank you so much for replying
can you please explain a little more and in a simple way please
i'm new to arduino :sweat_smile:
thank you
Can you tell me what you don't understand in my reply please, then I can explain that specifically.
what do i have to do exactly now
attach a 1k8 resistor to where
and what should i do with the code
thanks
Between A4 and 3V3 and another one between A5 and 3V3.
In the setup function after the Wire.begin call add
pinMode(A5, INPUT);    // turn off the Arduino internal pull-up resistors
pinMode(A4, INPUT);   // turn off the Arduino internal pull-up resistors
awesome
thank you so much for explaining it
just to be sure you want me to short A4 and A5 with 3v3, correct?
It is correct, but it is not a short because it is passing the current through a resistor. A short would be to connect the pins directly to the supply voltage and would damage your Arduino.
What happens with I2C is that normally these resistors make the bus voltage look HIGH but at an impedance (think of it like a resistance) that limits the current it will have to sink (pull out of the line) to make it look like a logic LOW.
Then the I2C commands pull down this voltage for all devices on the bus, and sends the address of the device it wants to talk to. All devices on the bus listen to this address and if it is not one that it recognises as belonging to it then it ignores all other messages. If it does recognise it then it sends an acknowledge pulse back by pulling the bus down. Then the rest of the transfer continues.
I see
thank you for explaining it
also I do not have a 1k8 resistor, can I use a 2k? Is there a difference?
You can cross-check your method with this tutorial: Introduction to MPU6050 - The Engineering Projects
It is based on Arduino UNO and MPU6050.
Yes, this is going to require that the I2C device will have to pull down 3.3 mA of current which is quite close to the 4mA absolute maximum of the I2C specification.
If you only have 1K resistors then you are best putting two in series to give you a total value of 2K in all.
alright ill try it out and I'll let you know if it worked or not
than you!
hi
I did what you said
i attached a 2k resistor between A4 and A5 with 3v3
and added the 2 lines of code you mentioned
it didn't work, unfortunately.
First run the I2C scanner code and see what addresses you pick up for the mpu6050. Make sure your code is using the correct address.
The next thing is to take some voltage measurements. Measure from ground to A4 and A5 and report back the voltage for each pin.
14:49:32.831 -> Scanning...
14:49:32.831 -> I2C device found at address 0x68  !
14:49:32.877 -> done
14:49:32.877 -> ```
and I got about 3.3v for both of them
I just tested the same code with the same mpu6050 with the same wires and everything on my Arduino UNO and it worked...
I'm extremely confused now, why would it work on the UNO and not the nano?
Thanks for that that looks OK.
I tried to compile the code you posted and got this message:-
Sketch uses 24478 bytes (79%) of program storage space. Maximum is 30720 bytes.
Global variables use 1631 bytes (79%) of dynamic memory, leaving 417 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
Do you get this?
Have you tried removing some of the memory heavy stuff like the LEDs and see what that number comes down to and does it make the MPU6050 fail message go away?
no i do not get this error
and i tried removing everything except for the mpu6050 still doesn't work on the nano
So what do you get at the end of compiling the code in your first code?
So can you post that code as well as what you get at the end of compilation?
this is what I get when I upload the code as well as upload done
and this is the code I'm using
GyverSaber.ino (17.2 KB)
