H Bridge getting very hot
Hi
A have a setup with a steppermotor: JK42HS40-1304F and a dual H Bridge L298N 2Amp, and a arduino
The H bridge is connectet to 12v and there is common ground between the H bridge and the arduino uno.
I run the use the sketch from arduino : stepper_oneRevolution, but after only ie 30 sec the heat sink on the H bridge is getting very hot, so you cant touch it.
And the stepper startes to behave strange.
What is wrong? I dont think it the power supply it is at 16A, but does the H brigde need to manage more amps or ???
Regards
Hi, welcome to the forum.
The L298N is an old driver, and after a little seaching I think everyone has a L298N that is getting hot with Nema 17 stepper motor.
Perhaps the EasyDriver is better : EasyDriver - Stepper Motor Driver - ROB-13226 - SparkFun Electronics
Or the Adafruit Motor Shield V2 : Adafruit Motor/Stepper/Servo Shield for Arduino v2 Kit [v2.3] : ID 1438 : $19.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Or this one from Pololu : Pololu - A4988 Stepper Motor Driver Carriers
Super thanks, I'll try the one from Pololu
You are using a 12V power supply with a 4V motor.
1.3A x 3.2 ohm = 4.16V
The L298 is a simple non-switched H bridge. You are running -way- too much current. Are your steppers getting hot, too?
Use the chopper stepper driver boards from Pololu. Read the data - you are supposed to use a higher voltage power supply with it, but you are to set the current on a potentiometer on the PCB.
BTW, it helps if you provide links to nonstandard parts like stepper motors. When in doubt, provide a link to a datasheet or to the website page where you bought it.
Hi again
I have now tryed the A4988 driver, and it works without it getting hot at all, so that's super.
I'm using this stepper : CNC Nema17 Hybrid Stepper Motor Dc12v 2-phase 4000g.cm 4-lead 1.8 Degree DVG for sale online | eBay
And I was under the impression it was a 12v stepper!!!
But I'm new to this so...
Regards
You may get some useful info in stepper motor basics
...R
Dalhoj:
Hi again
Regards
Bipolar steppers are generaly rated by current and winding resistance, not
voltage, as they are current driven.
