HAB LoRa problem
I am trying to make a system that can transmit a radio message from a high altitude balloon using an Adafruit RFM96W 433 Mhz LoRa radio, a SD card module, a BME280, and an Arduino Nano, but it’s not working. The balloon station constantly resets, and there might be more problems. Can you please take a look at my code and let me know where it’s not working and how to fix it? Thanks for any suggestions you could provide. The receiver is the same PCB with the same components. The individual devices work OK. I have tested them using examples,
Link to my GitHub: GitHub - stratoscience25/arduino-workshop-logan
Balloon code:
// Arduino9x_RX
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (receiver)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Arduino9x_TX
#include <SPI.h>
#include <RH_RF95.h>
#include <SD.h>
#include <TinyBME280.h>
#include <String.h>
File myFile;
#define RFM95_CS 4
#define RFM95_RST 2
#define RFM95_INT 3
const int sdcs = 5;
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t len;
bool received_packet = 0;
#define TX_INTERVAL 5000
// Change to 434.0 or other frequency, must match TX's freq!
#define RF95_FREQ 434.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
// Blinky on receipt
#define LED 13
  pinMode(LED, OUTPUT);
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  while (!Serial)
  delay(100);
  Serial.println("Arduino LoRa RX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    while (1)
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1)
  Serial.print("Set Freq to: ");
  Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
  Serial.print(F("Initializing SD card..."));
  if (!SD.begin(sdcs)) {
    Serial.println(F("initialization failed!"));
    while (1)
  Serial.println(F("initialization done."));
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("data.csv", FILE_WRITE);
  myFile.println("Temperature, Humidity, Pressure, Packet ID");
  myFile.close();
  BME280setup();
  // Runs forever after setup
  SmartDelay(TX_INTERVAL);
  //delay(5000);
  // Gives the temperature as a signed 32-bit integer in °C with a resolution of 0.01°C. So an output value of “5123” equals 51.23°C.
  float temp = BME280temperature() / 100;
  String stemp;
  stemp = String(temp);
  // Pives the pressure in Pa as an unsigned 32-bit integer, so an output value of “96386” equals 96386 Pa, or 963.86 hPa.
  float press = BME280pressure() / 100;
  String spress;
  spress = String(press);
  // Gives the humidity in %RH with a resolution of 0.01% RH, so an output value of “4653” represents 46.53 %RH.
  float humid = BME280humidity() / 100;
  String shumid;
  shumid = String(humid);
/////////////////////////////sd code////////////////////////////////
  // Print the data to myFile output!
  myFile.println(stemp + "," + shumid + "," + spress + "," + received_packet);
  myFile.close();
void SmartDelay(int ms) {
  unsigned long starttime = millis();
  while (millis() - starttime < ms) {
    if (rf95.available()) {
      // Should be a message for us now
      if (rf95.recv(buf, &len)) {
        received_packet = 1;
        len = sizeof(buf);
        digitalWrite(LED, HIGH);
        RH_RF95::printBuffer("Received: ", buf, len);
        Serial.print(F("Got: "));
        Serial.println((char*)buf);
        Serial.print(F("RSSI: "));
        Serial.println(rf95.lastRssi(), DEC);
        // Send a reply
        uint8_t data[] = " KC1VVU says hi";
        rf95.send(data, sizeof(data));
        rf95.waitPacketSent();
        Serial.println(F("Sent a reply"));
        digitalWrite(LED, LOW);
        Serial.println(F("Receive failed"));
Ground station code:
//TX Credit to adafruit
// LoRa 9x_TX
// Example sketch showing how to create a simple messaging client (transmitter)
// It is designed to work with the other example LoRa9x_RX
#include <SPI.h>
#include <SD.h>
#define RFM95_CS 4
#define RFM95_RST 2
#define RFM95_INT 3
const int chipSelect = 5;
// Change to 434.0 or other frequency, must match RX's freq!
int Transmit_Counter = 1;
  while (!Serial);
  delay(100);
  Serial.println("Arduino LoRa TX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1)
  Serial.println("card initialized.");
int16_t packetnum = 0;  // packet counter, we increment per xmission
  Serial.println("Sending to rf95_server");
  // Send a message to rf95_server
  char radiopacket[20] = " KC1VVU test/      ";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  radiopacket[19] = 0;
  Serial.println("Sending..."); delay(10);
  rf95.send((uint8_t *)radiopacket, 20);
  Serial.println("Waiting for packet to complete..."); delay(10);
  // Now wait for a reply
  uint8_t len = sizeof(buf);
  Transmit_Counter++;
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  Serial.println("Waiting for reply..."); delay(10);
  if (rf95.waitAvailableTimeout(1000))
    // Should be a reply message for us now
      Serial.print("Got reply: ");
      Serial.print("RSSI: ");
      dataFile.print((char*)buf);
      dataFile.print(", ");
      dataFile.print(packetnum);
      dataFile.println(rf95.lastRssi(), DEC);
      dataFile.close();
      Serial.println("Receive failed");
    Serial.println("No reply, is there a listener around?");
  delay(2000);
we require more details?
have a read of how-to-get-the-best-out-of-this-forum
e.g.
what is the host microcontroller?
what other devices/sensors are there?
how is it powered? upload a schematic?
do the individual devices work OK?
what is the receiver?
post your code - click < CODE > and paste you code where it says 'type or paste code here
Is that legal?
Yes, I have a ham radio license
I have all the code in my GitHub
For help on this forum, please answer all the questions in post #2, after reading the "How to get the best out of this forum" post.
Most likely a power or wiring problem. Be sure to post a full size picture of the schematic diagram, a clear, focused photo of the populated and wired PCB and links to all of the components.
Hint: for power consumption and reliability, this is the worst possible approach toward coding:
  myFile.close();
Opening a file, writing a line of data, and closing it again dramatically increases SD card current consumption, error rate and time to write data.
Using String variables on an MCU with limited memory leads to memory problems and program crashes due to poor to nonexistent memory management.
Good, greate! Then You know the rules applied to it. "Wildly transmitting" is a serious business.
Just got permission to use a comradio on the airband in connection with drone flying!
Whish You good help and good luck!
What’s the right way to do it?
Open a file once in setup() and close it again when done collecting data. For reliability, call myFile.flush() every 10 minutes or so to update file pointers, so in case of a crash you lose only the last few minutes of data. Note that some SD cards briefly draw up to 200 mA every time a file is opened or closed.
Don't use Strings.
For example, replace this line
with
myFile.print(temp);  //NOT "stemp"
myFile.print(',');
myFile.print(humid);
myFile.print(',');
myFile.print(press);
myFile.print(',');
myFile.println(received_packet);
Believe it or not, that replacement will save a lot of RAM and program memory, by removing the String class code.
Finally, make sure the LoRa radios communicate with library examples, before writing your own code.
Thank you, I did that, however, it’s still crashing
Please reread post #2, and supply the requested information.
I uploaded the code and the requested information
