Problems with Arduino, LoRa and LCD display
Hello!
I’m trying to send a message from one Arduino to the other but somehow this receiver code wont work properly.
It looks like the program restarts all the time. Any ideas, you eagle eyed people?
  LoRa Demo 1 Receiver
  lora-demo1-receive.ino
  Receives and displays contents of test packet
  Requires LoRa Library by Sandeep Mistry - https://github.com/sandeepmistry/arduino-LoRa
  DroneBot Workshop 2023
  https://dronebotworkshop.com
// Include required libraries
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
// Define the pins used by the LoRa module
const int csPin = 4;     // LoRa radio chip select
const int resetPin = 2;  // LoRa radio reset
const int irqPin = 3;    // Must be a hardware interrupt pin
// Create LCD-object (adress 0x27 or 0x3F, depending on module)
LiquidCrystal_I2C lcd(0x27, 16, 2);
 String received_text = "";
  while (!Serial)
// Initiera LCD
  Wire.begin();
  Wire.setClock(100000);   // Run in 100 kHz for stability
  lcd.init();           // Initiate LCD display
  lcd.backlight();      // Turn on backlight
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("LoRa receiver");
  // Setup LoRa module
  LoRa.setPins(csPin, resetPin, irqPin);
  Serial.println("LoRa Receiver Test");
 // Serial.println("Setup");
  // Start LoRa module at local frequency
  // 433E6 for Asia
  // 866E6 for Europe
  // 915E6 for North America
  if (!LoRa.begin(866E6)) {
    Serial.println("Starting LoRa failed!");
    while (1)
    lcd.setCursor(0, 1);
    lcd.print("LoRa error!");
 received_text = "";
  // Try to parse packet
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    // Received a packet
    Serial.print("Received '");
    // Read packet
   // while (LoRa.available()) {
   //   Serial.print((char)LoRa.read());
      received_text += (char)LoRa.read();
    // Print RSSI of packet
    Serial.println(received_text);
    Serial.print("' with RSSI ");
    Serial.println(LoRa.packetRssi());
    // Write to LCD
    lcd.clear();
    lcd.print(received_text.substring(0, 16));
I’m using an Arduino Uno R3 for this.
I will add more info…
/// Martin ///
Maybe explain what you mean by this, for instance what output do you see on the Serial monitor ?
Do you know which type of Arduino you are using ?
This could eventually get you into all kinds of trouble. Depending on the available RAM on your processor, that could happen very soon, or later. But given the right circumstances (a transmitter constantly sending), eventually it will.
So, i did some troubleshooting:
This works:
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
  while (!Serial)
// Initiera LCD
  Wire.begin();
  lcd.clear();
  // 433E6 for Asia
  // 866E6 for Europe
    while (1)
 received_text = "";
  if (packetSize) {
    // Read packet
    int rssi = LoRa.packetRssi();
    float snr = LoRa.packetSnr();
    // Write to LCD
    lcd.clear();
    // lcd.setCursor(0, 1);
    //lcd.print("R:");
    //lcd.print(rssi);
    //lcd.print(" S:");
    //lcd.print(snr, 1);
Serial:
LoRa Receiver Test
Received 'Temperatur: 21.00
' with RSSI -28
' with RSSI -29
' with RSSI -28
And this doesnt, the only diffs are at the end.
With this, the serial output is unpredictable and the unit seems to restart.
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
  while (!Serial)
// Initiera LCD
  Wire.begin();
  lcd.clear();
  // 433E6 for Asia
  // 866E6 for Europe
    while (1)
 received_text = "";
  if (packetSize) {
    // Read packet
    // Write to LCD
    lcd.clear();
    lcd.print("R:");
    lcd.print(rssi);
    lcd.print(" S:");
    lcd.print(snr, 1);
Serial:
ReLoRa Receiver Test
' with RSSI -31
R�LoRa Receiver Test
' with RSSI -28
Yea, if you have any advice, i’ll all ears :slight_smile:
/// Martin ///
My advice is "you might want to rethink this part of your code."
Good luck with your project.
please post the compiler summary of your code so we can see the free Flash/free SRAM
I suspect you run low on SRAM. At least use the F-Makro for your fix text outputs (Serial, LCD...)
Hi, here is the compiler output:
Sketch uses 7724 bytes (23%) of program storage space. Maximum is 32256 bytes.
Global variables use 580 bytes (28%) of dynamic memory, leaving 1468 bytes for local variables. Maximum is 2048 bytes.
Flashing with command:C:/Users/rekla/.arduino-create/arduino/avrdude/6.3.0-arduino17/bin/avrdude.exe -CC:/Users/rekla/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:/Users/rekla/AppData/Local/Temp/arduino-create-agent2187807675/Temp_LCD_LoRa_Receiver.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/rekla/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: reading input file "C:/Users/rekla/AppData/Local/Temp/arduino-create-agent2187807675/Temp_LCD_LoRa_Receiver.hex"
avrdude: writing flash (7724 bytes):
Writing | ################################################## | 100% 1.25s
avrdude: 7724 bytes of flash written
avrdude: verifying flash memory against C:/Users/rekla/AppData/Local/Temp/arduino-create-agent2187807675/Temp_LCD_LoRa_Receiver.hex:
avrdude: load data flash data from input file C:/Users/rekla/AppData/Local/Temp/arduino-create-agent2187807675/Temp_LCD_LoRa_Receiver.hex:
avrdude: input file C:/Users/rekla/AppData/Local/Temp/arduino-create-agent2187807675/Temp_LCD_LoRa_Receiver.hex contains 7724 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 1.00s
avrdude: verifying ...
avrdude: 7724 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
Ok
To me there seems to be enough RAM, right?
Please post compiler/error message lists inside code tags. Same for serial monitor output.
(Each separately in their own pair of code tags, otherwise it would be very confusing!)
What makes you so sure the code is the problem?
Unexpected Arduino resets are often power supply problems: a sudden demand for a large current causing a voltage drop which triggers the Arduino's brown-out detector.
You are quite right, one should not assume anything.
The reason i suspected code was because i could repeat the problem, to some degree.
I used an Uno R4 as sender and a R3 as receiver. The sender, equipped with similar hardware worked perfectly,the R3 not so.
Today i replaced the R3 with a new R4 and so far it seems to work and i hope it stays that way.
That said, i will make use of the F-function, now that i’m a wiser man.
Thanks, all !
/// Marti ///
