Hello, i am trying to count the number of rotations a wheel makes, I'm using a hall effect sensor and a magnet on the wheel, i want an led to light up when the magnet passes the hell sensor 5 times, but it lights up on the first no matter what number i set the fancied count to, any input on what I'm doing wrong would be greatly appreciated
btw i have a 10k resistor from pin 1 to 3 of the hall
onst int hallPin = 12; // the number of the hall effect sensor pin
const int ledPin = 13; // the number of the LED pin
int count = 0;
int hallState = 0; // variable for reading the hall sensor status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the hall effect sensor pin as an input:
pinMode(hallPin, INPUT);
void loop(){
hallState = digitalRead(hallPin);
if (hallState == LOW)
count++;
if (count >= 5) //fancied passes
digitalWrite(ledPin, HIGH);
Unless DigitalRead() does something I am not aware of (I am used to PIC processors), you need for it to go high again before waiting for the next count. Typically, looking for it to go low then increment the count will count low many times before it goes high again (very similar problem to switch bounce/debounce).
I suspect that your loop runs so fast that the loop reads the sensor many times on each pass of the magnet. You could fix this two ways:
use a time delay after each reading that increments the counter, provided it is short enough not to block the next legitimate transition from high to low.
use an interrupt, high to low, to read the sensor. That would be the most bullet proof way, provided the sensor cleanly enters and exits the sensing of the magnet.
Also with a DMM, check to see what voltage you have on the input pin, with a magnet in postion,note you will get a different response with each pole, no magnet will probably give you half the supply voltage.
Hello, i have found a way to make it work by using some code from diy hacking
ill show the mod that i did
Arduino Hall Effect Sensor Project
by Arvind Sanjeev
Please check out http://diyhacking.com for the tutorial of this project.
DIY Hacking
volatile byte half_revolutions;
unsigned int rpm;
unsigned long timeold;
attachInterrupt(0, magnet_detect, RISING);//Initialize the intterrupt pin (Arduino digital pin 2)
pinMode(12, OUTPUT);
half_revolutions = 0;
rpm = 0;
timeold = 0;
void loop()//Measure RPM
if (half_revolutions >= 20) {
rpm = 30*1000/(millis() - timeold)*half_revolutions;
timeold = millis();
//Serial.println(rpm,DEC);
void magnet_detect()//This function is called whenever a magnet/interrupt is detected by the arduino
half_revolutions++;
Serial.println("detect");
if (half_revolutions >= 5) //this is the mod that i made, add an if statement, the number it equals is
//the number of rotations, if you wanted it to blink at 500 rotations you would set it to 500, easy
digitalWrite(12, HIGH); //this says what you want the led to do
