I am trying to create a project using a hall sensor to measure the rotations of a wheel. After 5 rotations I would like to have a HIGH output on a pin 3 (which will be switched LOW with another sensor). I use the digital output of KY-024 linear magnetic hall sensor attached to an Arduino Uno device. I created the following sketch.
const int inputPin = 2; // Digital input pin
const int outputPin = 3; // Digital output pin
int consecutiveTrueHighCount = 0; // Counter for consecutive true HIGH events
const int requiredConsecutiveTrueHigh = 5; // Number of consecutive true HIGH events required
pinMode(inputPin, INPUT);
pinMode(outputPin, OUTPUT);
digitalWrite(outputPin, LOW); // Set the initial state of the output pin to LOW
static int consecutiveHigh = 0;
int currentState = digitalRead(inputPin);
if (currentState == HIGH) {
consecutiveHigh++;
} else if (currentState == LOW && consecutiveHigh > 0) {
consecutiveTrueHighCount++;
if (consecutiveTrueHighCount == requiredConsecutiveTrueHigh) {
digitalWrite(outputPin, HIGH); // Set the output pin to HIGH
Serial.println("Consecutive True HIGH reached!");
// Reset the counter after reaching the required consecutive true HIGH events
delay(10); // Adjust the delay as needed based on your application
...hope I managed to paste the code in a format as it should be.
I am a bit confused because the if I approach a magnet to the sensor, 5 times I might or might not get the required HIGH output on pin 3 (LED light for test). Sometimes I get the high after approaching the sensor more than 5 times (6-9) sometimes the HIGHT ouutput is not triggered at all.
What am I doing wrong? I just do not understand why I have this confusing output.
Print the "consecutiveTrueHighCount" after line 20
to know if when approaching the magnet the counting is occurring correctly.
Serial.println(consecutiveTrueHighCount);
Are you sure that the end of the magnet is pointing at the hall effect device and that you are approaching the face of the Hall Effect device with the part number printed on it?
Hi all and thank you very much for the help so far. I am trying to build a small device which starts at every 9th rotation of a wheel and stops when a signal comes in from pin 6.
This is my code:
const int rotationPin = 2;
const int ejectorStartPin = 5;
const int ejectorStopPin =6;
// Variables will change:
int rotationCounter = 0; // counter for the number of button presses
int sensorState = 0; // current state of the button
int lastSensorState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(rotationPin, INPUT);
// initialize the LED as an output:
pinMode (ejectorStartPin, OUTPUT);
pinMode (ejectorStopPin, INPUT);
// initialize serial communication:
// read the pushbutton input pin:
sensorState = digitalRead(rotationPin);
// compare the buttonState to its previous state
if (sensorState != lastSensorState) {
// if the state has changed, increment the counter
if (sensorState == HIGH) {
// if the current state is HIGH then the button went from off to on:
rotationCounter++;
Serial.println("on");
Serial.print("number of rotation: ");
Serial.println(rotationCounter);
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
lastSensorState = sensorState;
if (rotationCounter % 9 == 0) {
digitalWrite(ejectorStartPin, HIGH);
if (digitalRead(ejectorStopPin) == HIGH) {
delay (500);
digitalWrite(ejectorStartPin, LOW);
Everything works fine except for one thing.
The ejector is always receives a HIGH signal while the rotation counter measures a rotation that is a multiple of 9 - as it is programmed, but I am not able to switch it to LOW with the signal from pin6 unless the rotation counter shows a value that is not a multiple of 9.
In other words if the rotation counter stays on 9, 18, 27, etc. the ejector will be on and I am not able to swicth it off with pin 6.
Thanks for the suggestions, I tested it and the ejector stops on HIGH from ejectorStopPin only if the rotation counter value is other than a multiple of 9 any other suggestion?
Correct, that is how you have coded it.
Each time round the loop the "ejectorStartPin" goes LOW only for a fraction of a second before it is put high again by the logic. This is because the lines that deal with the "ejectorStartPin" are just tagged on the end of the loop function and always get called.
You only want to do this when you get a change of state of the rotation pin, not every time through the loop.
Thanks Grumpy_Mike for putting me in the right direction! Sorry for annoying everyone with basic questions but coming from a completely different background I need some time to understand the logic of how Arduino works.
I started the assembly of the unit after doing the test on the breadboard - and the whole thing collapsed. Does the length of the wires change the way hall sensor operates? I used an SA-15 unit for testing. Then I removed the hall sensor from the unit and replaced it with a more solid one. Still worked. Then added cc. 4 meters of wire to the circuit (between the sensor and the SA-15 unit and now it doesn't ot work. Can you guide me if there is a way to get rid of th whole SA-15 unit? How can I calculate what size of resistors I should add to the circuit to make it work?
Please see attached the drawing of my project. drawing.pdf (207.7 KB)
I am building a device that is connected to an ATV. The purpose is to eject a tube every 20 meters while the ATV moves on a field. On the wheel, I attach a magnet, and the rotation of the wheel is measured by a hall sensor. Every 20 meters a signal should start an electric motor that is attached to a revolver-type chamber (similar to a revolver gun). On this chamber, there is another magnet and another hall sensor that detects the movement of the chamber to stop the motor so every time just one tube is dropped from the revolver chamber.
I used this hall sensor for the test circuit and programming
but I would like to use a more protected one so I tried to use this one:
I use an Arduino Uno. I see what you mean! Thanks for the tip. I did not damage it yet, but I should change the circuit to avoid it. Do you have any idea how can I overcome this 40 mA difference or I should dump the idea of using a relay? Would a capacitor help?
