Hi! I'm trying to make a tachometer/speedometer for a small electric car I'm building. I bought a hall effect sensor (digital and analog outputs) and some magnets. After testing it out by hand, I noticed that the hall effect sensor is triggering multiple interrupts near the threshold of detection. I've experienced this with a button before, but I did not expect the same with a hall effect sensor.
Can anyone explain why this is occurring? I could add some software debouncing logic, but wouldn't that limit the max rpm it can detect?
If it has analog output its probably not a hall switch, so there's no hysteresis. You could read the analog output
and add your own hysteresis in software... If you just want to count pulses get a hall switch,
not an analog sensor.
However we may be missing something and you haven't said which sensor this is - please get in the
habit of providing details (datasheet, partnumber) of hardware in a question unless you only
want a vague and possibly wrong answer. Details are all-important.
The ones with analog and digital output are often based on an lm393 comparator configured without feedback for hysteresis control. Try a capacitor between the D0 pin and ground.
I have the same problem as OP. I'm using part nr UGN3132UA on a breadboard. I've connected the supply pin with the 3.3V port at Arduino Uno, the ground pin goes to ground on Arduino, and the output pin is connected to pin 2 on the Arduino. My code is very similar to WillFreeman:
Whenever I move a magnet close to the sensor, I get 10-20 interrupts. Sometimes, I can keep my hand in a "sweet spot" where interrupts are being generated continuously. I'd rather get exactly one interrupt. What can I do ?
#define HALL_PIN 2
#define LED_PIN 13
bool lit = true;
attachInterrupt(digitalPinToInterrupt(HALL_PIN), magnet_detect, RISING);//Initialize the intterrupt pin (Arduino digital pin 2)
pinMode(LED_PIN, OUTPUT);
pinMode(HALL_PIN, INPUT_PULLUP);
digitalWrite(LED_PIN, HIGH);
void loop()//Measure RPM
if (digitalRead(HALL_PIN) == LOW) {
Serial.println("LOW");
else Serial.println("HIGH");
void magnet_detect()//This function is called whenever a magnet/interrupt is detected by the arduino
Serial.println("interrupt");
lit = (digitalRead(HALL_PIN) == HIGH);
if (lit) {
else {
digitalWrite(LED_PIN, LOW);
You do not have the same kind of hall sensor as the original poster, and the data sheet I'm looking at indicates that yours is a 5v device. Why are you running it at 3.3v.
If it does not work in a stable fashion at 5v, I would try a stronger external pullup (10K or 4.7K) on the output than you get with the internal INPUT_PULLUP.
The sensor should not be oscillating as you indicate, but you could try some software debouncing with a lock out period between allowed interrupts. Choose a lock out time consistent with the application and the expected rate of switching.
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
const unsigned long lock_out = 50;
// Serial.println("interrupt"); //no serial printing within an ISR
if (interrupt_time - last_interrupt_time >= lock_out)
if (lit) {
else {
cattledog:
Oops! I missed the line about minimum operating voltage being 4.5V. I've connected it to the 5V pin and now there is no bouncing at all.
