Hi:
I need to control a (HO railroad) turntable that should stop at given angles. Using a hall effect sensor sounds good but how accurate is it? Will it work with a, let's say, 1/10mm accuracy?
Are there any practical examples out there?
Thanks!
Hi:
Thanks!
How about LEDs on light sensors? You could mask off the LEDs to make them laser like.
Using a hall sensor for precise positioning is only feasible if you take steps to shield it from external magnetic fields which is a tricky mechanical problem when you only have hobby level tools.
A LED slot switch or a simple wiper contact like those used in multimeter switches may be easier solutions.
Take an array of three light sensors, masks with 1-3 openings, and you have 7 codes. The openings line up with the light sensors when the turn table is in position; which one(s) is triggered tell you which position your turn table is in.
Increase to 4 sensors for up to 15 positions.
Cheap LDRs are probably good enough for this.
