Hi, very much a novice but learning. I'm using a DHT22 sensor to monitor the internal greenhouse temperature, for controlling the opening and closing of the door. The sensor needs a 2sec sampling window which is built into my program code as standard practice. My problem is when the door opens and closes the 2 sec delay interferes with the door stop limit switches. What is the best way of taking out the delay command from the loop while the door opens and closes. Any ideas would be appreciated with help examples of code please. Kind regards Jevray
Hello Jevray,
If you want specific advice about your code you need to post your code, we are not telepathic!
General guidance and
How to use this forum
If you want general advice on non-blocking code read:
Using millis for timing
Demonstration for several things at the same time
Thank you.
The code below is how I read my DHT11 ala blink without delay. It's the code from the DHT11 example, stuck in a function, and called via a millis()-based timer.
(Note it's DHT11 not 22, but the idea's exactly what you want....)
// based on....
// FILE: dht11_test1.pde
// PURPOSE: DHT11 library test sketch for Arduino
// ... but tidier
#include <dht11.h>
dht11 DHT;
#define DHT11_PIN 4
unsigned long lastDHT;
int dhtReadInterval = 10000;
Serial.println("DHT TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT11LIB_VERSION);
Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
}//setup
if (millis() - lastDHT >= (unsigned long) dhtReadInterval) //check if time has elapsed
lastDHT = millis(); //save for next time
doDHTstuff();
}//loop
void doDHTstuff()
int chk;
Serial.print("DHT11, \t");
chk = DHT.read(DHT11_PIN); // READ DATA
switch (chk) {
case DHTLIB_OK:
Serial.print("OK,\t");
case DHTLIB_ERROR_CHECKSUM:
Serial.print("Checksum error,\t");
case DHTLIB_ERROR_TIMEOUT:
Serial.print("Time out error,\t");
default:
Serial.print("Unknown error,\t");
// DISPLAT DATA
Serial.print(DHT.humidity, 1);
Serial.print(",\t");
Serial.println(DHT.temperature, 1);
}//dht stuff
In addition to what the others have said, is it possible to know when the door is moving and suspend readings from the DHT22 while it is in progress?
...R
Robin2:
In addition to what the others have said, is it possible to know when the door is moving and suspend readings from the DHT22 while it is in progress?...R
This exactly what I need to do. As the temperature increases beyond a set point the door opens as it activates the limit switch to shut off the door motor any active delay creates a problem with stopping the motor, same situation for when it closes.
Here is my code:-
// software GH_030420_master.INO
// Program written by M. Deeley 03/04/20
// Greenhouse control system using fan ventilation.
// electronic door motor control
// Arduino nano
#define DHTPIN 4 // pin 4 sensor is connected to
#include <DHT.h>
#define DHTTYPE DHT22 // DHT 22 (AM2302)
// motor (1) door control motor = in1,in2,enA
int outPin = 13; // external door hold open led
int in1 = 9; // door control input
int in2 = 10; // " " "
int enApin = 11; // " " "
int vent = 8; // window vent fan
int fan = 12; // humidity fan
int buttonLpin = 6; // left side door switch
int buttonRpin = 5; // right hand door switch
int val = 0;
int ledPin = 7; // door hold open indicator led
// *******************MANUAL DOOR LOCK OPEN *****************
const uint32_t debounceTime = 10; // switches debounce time
const uint8_t switchPin = 2; // switched to ground to activate
const bool switchOn = false; // using INPUT_PULLUP
const bool switchOff = true;
bool lastState = switchOff;
bool newState = switchOff;
bool toggleState = false;
volatile int buttonState = 0;
// ======================== user max/min temperature settings
int maxTemp2 = 29; // max set at 29 for door
int minTemp2 = 25; // min set at 25 " "
int maxTemp = 22; // max set at 18 for vent
int minTemp = 20; // min set at 15 for vent
int maxHum = 60; // humidity setting max
int minHum = 55; // humidity setting min
DHT dht(DHTPIN, DHTTYPE);
pinMode (ledPin, OUTPUT); // door locked open signal
pinMode (vent, OUTPUT); // ventfan
pinMode (enApin, OUTPUT); // motor conrol module enable
pinMode (in1, OUTPUT); // motor control
pinMode (in2, OUTPUT); // motor control
pinMode (fan, OUTPUT); // humidity fan
pinMode (buttonLpin, INPUT_PULLUP); // left door switch
pinMode (buttonRpin, INPUT_PULLUP); // right door switch
pinMode (switchPin, INPUT_PULLUP); // toggle switch internal + external
dht.begin();
delay(2000); // Wait a few seconds between measurements.
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
// *********************** Door manual_open/close *******
{ buttonState = digitalRead (switchPin);
if (buttonState == LOW ) {
digitalWrite(ledPin, HIGH); // internal led(warning door held open
digitalWrite(outPin, HIGH); // external led ( warning door held open
digitalWrite(vent, LOW); // turn vent fan off
digitalWrite(enApin, HIGH); // door motor control logic
val = digitalRead(buttonLpin); // read the Left door limit switch
digitalWrite(enApin, val); // door motor module control pin 9
delay( debounceTime );
digitalWrite(in1, LOW); // door motor >>>> OPEN pin 12
digitalWrite(in2, HIGH); // " " " " pin 11
else {
digitalWrite(ledPin, LOW); //cancel hold open door switch command
digitalWrite(outPin, LOW);
// ================================= VENT CHECK =======================
if (t > maxTemp) {
digitalWrite(vent, HIGH);
} else if (t < minTemp) { // if(h < minHum || t < minTemp) {
// ======================== DOOR CONTROL LOGIC... OPENING FOR HIGH TEMPERATURE (Temp2)
if (t > maxTemp2) {
val = digitalRead(buttonLpin); // read the input pin
digitalWrite(enApin, val); // was in1 for grounded limit sw or 2 if using pull up
// ======================= DOOR CONTROL LOGIC / for temp2 = LOW TEMPERATURE DOOR CLOSING
} else if (t < minTemp2) {
val = digitalRead(buttonRpin); // read the input pin
digitalWrite(enApin, val); // sets the output to in1 (if pull up)(in2 for input grounded via sw)
digitalWrite(in1, HIGH); // door motor >>>> CLOSE pin 12
digitalWrite(in2, LOW); // " " " " pin 11
} //=================== checking humidity sensors to control fan if high fan on
if (h > maxHum) {
digitalWrite(fan, HIGH);
} else if (h < minHum) {
digitalWrite(fan, LOW);
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C ");
See reply #1 for how to use this forum.
Specifically, how about posting your code in code tags?
See reply #1, fix that, follow the instructions in the various tutorials and post your code properly as well.
When someone is given advice and clearly doesn't bother to follow it then it puts people off helping any more.
Jevray:
if your Arduino is causing the door to open then it should be straightforward to stop checking the temperature until the door has finished moving.
Plus what is in Reply #7
...R
Thank you for your reply. Sorry I thought I had used the code brackets! May I just mention here that I posed a question regarding delays within a loop, and gave a brief description regarding the DHT22 delay period between measurements, and is there a method how the delay period could be eliminated from the main program loop. I expected an answer that may be on the lines of, Try this way, or have you tried, etc.
I was not encouraged by your rather abrupt answer! At seventy-four years of age I don't have the benefit of good health. It takes me over an hour just to write a few lines. Also, when I post a reply here i have to post a reply within five minutes or my post is suspended?
In answer to your question, here is my code correctly presented. Kind Regards
// Arduino nano
#include <DHT.h>
int val = 0;
dht.begin();
return;
else {
if (t > maxTemp) {
if (t > maxTemp2) {
if (h > maxHum) {
Serial.print(h);
Serial.print(" %t");
Serial.print(t);
Do you realize delay() stops code execution for the delay amount of time ?
Can you explain what this BWD code segment does ?
if(timerEnableFlag == true && millis() - startTime >= interval)
// do some stuff
larryd:
// do some stuff
The delay of 2 sec period is for the DHT22 sensor temperature reads. My question is how can I avoid this delay within the main control loop of my existing code.Regards Jevray
Trying to help you but first, will you explain what is happening in the code segment below ?
// do some stuff
larryd:
Trying to help you but first, will you explain what is happening in the code segment below ?if(timerEnableFlag == true && millis() - startTime >= interval)
// do some stuff
AS I see it, if timer is set, and delay period - start time, is greater or equal to interval (period) then do whatever?
Jevray:
That is not how you presented the problem in your Original Post. You said "The sensor needs a 2sec sampling window" which I took to mean that when you ask the sensor for a value it waits (internally) for 2 seconds before responding.
That is a very different issue from a decision made by you to cause measurements to be taken at 2-second intervals. If you want to take measurements at intervals without using the delay() function you can do it like this
if (millis() - lastMeasurementTime >= 2000) {
lastMeasurementTime = millis();
// code to take a measurement
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
Well, I'm sorry if you found my answer abrupt but when advice is given and obviously ignored it is frustrating.
Anyway, you have had some good advice from others while I've been watching telly, I have nothing useful to add at this point. Good luck with your project.
PerryBebbington:
Well, I'm sorry if you found my answer abrupt but when advice is given and obviously ignored it is frustrating.Anyway, you have had some good advice from others while I've been watching telly, I have nothing useful to add at this point. Good luck with your project.
Thank you I have not ignored your advice, I'm grateful for any advice that is helpful, for reasons I've explained I have difficulties in responding. Kind Regards Jevray
This will not work but you can see from the code how things can be changed.
Try things out and report back with what needs changing.
//Version 1.00
// Arduino nano
#define DHTPIN 4 //pin 4 sensor is connected to
#include <DHT.h>
#define DHTTYPE DHT22 //DHT 22 (AM2302)
const byte switchPin = 2; // switched to ground to activate
//motor (1) door control motor = in1,in2,enA
const byte buttonRpin = 5; // right hand door switch
const byte buttonLpin = 6; // left side door switch
const byte ledPin = 7; // door hold open indicator led
const byte in1 = 9; // door control input
const byte in2 = 10; //
const byte enApin = 11; //
const byte fan = 12; // humidity fan
const byte outPin = 13; // external door hold open led
int val = 0;
byte lastButtonState;
byte buttonState = 0;
bool motorFlag = false;
bool processFlag = false;
int maxTemp2 = 29; //max set at 29 for door
int minTemp2 = 25; //min set at 25 " "
int maxTemp = 22; //max set at 18 for vent
int minTemp = 20; //min set at 15 for vent
int maxHum = 60; //humidity setting max
int minHum = 55; //humidity setting min
unsigned long switchMillis;
unsigned long dhtMillis;
unsigned long currentMillis;
unsigned long startMillis;
float t;
float h;
dht.begin();
currentMillis = millis();
checkSwitches();
readDHT();
if (processFlag == true)
processDHT();
if (motorFlag == true)
//delay( debounceTime );
motorFlag = false;
} //END of loop()
void checkSwitches()
//check every 50ms
if (currentMillis - switchMillis < 50)
//it is not time yet
return;
//restart the TIMER
switchMillis = currentMillis;
//************************* s w i t c h P i n
//did the switch change state ?
if ( lastButtonState == buttonState)
return;
//update to the this state
lastButtonState = buttonState;
digitalWrite(ledPin, HIGH); // internal led(warning door held open)
digitalWrite(outPin, HIGH); // external led ( warning door held open)
motorFlag = true;
motorFlag = false;
} //END of checkSwitches()
void readDHT()
//time to read the DHT every 2000ms
if (currentMillis - startMillis < 2000)
return;
//restart the TIMER
startMillis = currentMillis;
return;
//we are ready to act on new reading
processFlag = true;
} //END of readDHT()
void processDHT()
//VENT CHECK
if (t > maxTemp)
if (t > maxTemp2)
val = digitalRead(buttonLpin); //read the input pin
digitalWrite(enApin, val); //was in1 for grounded limit sw or 2 if using pull up
digitalWrite(in1, LOW); //door motor >>>> OPEN pin 12
val = digitalRead(buttonRpin); //read the input pin
digitalWrite(enApin, val); //sets the output to in1 (if pull up)(in2 for input grounded via sw)
digitalWrite(in1, HIGH); //door motor >>>> CLOSE pin 12
//checking humidity sensors to control fan if high fan on
if (h > maxHum)
Serial.print(h);
Serial.print(t);
EDIT
Changed to:
Edit
See attached .ino file for version 2.00
sketch_apr15b.ino (6.53 KB)
Jevray:
In #2 I gave you an actual sketch to do that (ok, for a different dht sensor, but still...) and larryd was encouraging you to think along those lines in #10 and #12, as was Robin2 in #14.
No, you have that backwards: you have to wait at least 5 minutes between your posts.
Robin2:
That is not how you presented the problem in your Original Post. You said "The sensor needs a 2sec sampling window" which I took to mean that when you ask the sensor for a value it waits (internally) for 2 seconds before responding.That is a very different issue from a decision made by you to cause measurements to be taken at 2-second intervals. If you want to take measurements at intervals without using the delay() function you can do it like this
Have a look at [Using millis() for timing. A beginners guide](http://forum.arduino.cc/index.php?topic=503368.0) if you need more explanation. ...R
Thank you for your help, I will go through your recommendations, and thanks to others who have posted. Hopefully I can overcome this problem soon. Thanks again to all and be safe. Kind Regards Jevray
