HardwareSerial aliases on Mega
I've got three serial devices on Serial1, Serial2 and Serial3 attached to a mega. I'm trying to write a console program to communicate with them.
I set up a HardwareSerial object called SensorSerial, but once I assign it, I can't change it. In this example it will always be Serial1
Is there a trick to this?
#include <HardwareSerial.h>
uint8_t term_mode = 0;
char term_char;
char sens_char;
HardwareSerial & SensorSerial = Serial1;
  Serial.println("Please select mode:");
  Serial.println("     1 - RGB sensor");
  Serial.println("     2 - DO sensor");
  Serial.println("     3 - Conductivity sensor");
  while ( term_mode <= 0 or term_mode > 4) {
    if ( Serial.available() ) {
      term_char = Serial.read() - '0';
      switch (term_char) {
        case 1: {  /* RGB */
          term_mode = 1;
        case 2: {   /* DO */
          HardwareSerial & SensorSerial = Serial2;
          term_mode = 2;
        case 3: {  /*Conductivity*/
          HardwareSerial & SensorSerial = Serial3;
          term_mode = 3;
        default:
          Serial.print("Invalid selection: ");
          Serial.println(term_char + '0');
  SensorSerial.begin(38400);
  while ( Serial.available() ) {
    term_char = Serial.read();
    if ( term_char != 10 ) {
      SensorSerial.write(term_char);
      if (term_char == 13 ) Serial.println("<CR>");
  while ( SensorSerial.available() ) {
    sens_char = SensorSerial.read();
    Serial.write(sens_char);
    if ( sens_char == 13 ) Serial.write(10);
Do you not have to initialize each Serial occurrence like...
Serial1.begin(9600);
Serial2.begin(9600);
Bill
There are 4 instances of the HardwareSerial class defined for you. You must not create more of them, because there are no more hardware serial ports.
What you can do is create a pointer to an instance of the HardwareSerial class, and make it point to one of the existing instances.
HardwareSerial *serialToUse;
Then, you can make it point to an instance:
serialToUse = &Serial3;
Then, use it:
serialToUse->print("Serial3 gets this...");
I only need one of the three at a time and they all run at 38400 so I call begin() at the end of setup().
Based on PaulS's suggestion, It would be:
serialToUse->begin(38400);
Billdefish:
Bill
Here's the code based on PaulS's suggestion:
char term_char;
char sens_char;
        case 1: {  /* RGB */
          serialToUse = &Serial1;
          term_mode = 1;
        case 2: {   /* DO */
          serialToUse = &Serial2;
          term_mode = 2;
          term_mode = 3;
        default:
      serialToUse->write(term_char);
  while ( serialToUse->available() ) {
    sens_char = serialToUse->read();
