I'm trying to write my own serial module for a library that I'm working on. You can find it here:
(GitHub - jklarenbeek/protoduino).
I have created a .ino project file in the examples folder called 21-pt-serial-echo.ino, but I cannot get it to work. It breaks when linking the ISR implementation of the serial0.c module, but since I do not reference any Serial.begin or Serial.print, etc call in the .ino file it should not link the HardwareSerial0.cpp.o to begin with.
However, this appears to be happening. What am I doing wrong here?
Actually, you didn't post your code, you posted a link to it. (Or I wouldn't have commented)
But, it seems you'd rather argue than get help, so I'll leave you to it.
I didn't include the cc.h file and the pt.h file since the first are only compiler helpers like CC_EXTERN and the other i very large and complex but doesnt include anything noteworthy outside of its own source tree other then stdbool.h or stdint.h. I hope this helps.
Now i think about it, cc.h does include <avr/pgmspace.h>. I should probably investigate that further.
* @file cc.h
* @brief Common definitions and macros for Protoduino
* This file provides common definitions and macros used in the Protoduino library.
* It includes various macros for attribute handling, inlining functions, concatenating
* strings/identifiers, defining constant arrays and strings stored in program memory,
* declaring externally defined constant arrays and strings, and determining the number
* of elements in an array.
#ifndef __CC_H__
#define __CC_H__
#include <avr/pgmspace.h>
* @def CC_UNUSED
* @brief Macro to mark a variable as unused
#define CC_UNUSED __attribute__ ((unused))
* @def CC_INLINE
* @brief Macro to inline a function or code snippet
#define CC_INLINE inline
* @def CC_ALWAYS_INLINE
* @brief Macro to define an inline function with the given attribute
* @param f The function definition
#ifndef CC_ALWAYS_INLINE
#if defined(__GNUC__) && !defined(__MINGW32__)
#define CC_ALWAYS_INLINE __attribute__((__always_inline__)) inline
#elif defined(_MSC_VER)
#define CC_ALWAYS_INLINE __forceinline
#else
#define CC_ALWAYS_INLINE inline
#endif
#endif
#define CC_FLATTEN __attribute__((flatten))
#define CC_NO_INLINE __attribute__((noinline))
* @def CC_EXTERN
* @brief Macro to define an extern c function
#ifdef __cplusplus
#define CC_EXTERN extern "C"
#else
#define CC_EXTERN
#endif
* @def CC_WEAKFN(f)
* @brief Macro to define a weak function
#define CC_WEAKFN(f) f __attribute__((weak))
* @def CC_CONCAT2EXT(s1, s2)
* @brief Macro to concatenate two strings or identifiers
* @param s1 The first string or identifier
* @param s2 The second string or identifier
#define CC_CONCAT2EXT(s1, s2) s1##s2
* @def CC_CONCAT2(s1, s2)
#define CC_CONCAT2(s1, s2) CC_CONCAT2EXT(s1, s2)
* @def CC_CONST_PTYPE_ARRAY(type, varname)
* @brief Macro to define a constant array stored in program memory
* @param type The data type of the array elements
* @param varname The name of the variable representing the array
#define CC_CONST_PTYPE_ARRAY(type, varname) const type varname[] PROGMEM
* @def CC_EXPORT_CONST_PTYPE_ARRAY(type, varname)
* @brief Macro to declare an externally defined constant array stored in program memory
#define CC_EXPORT_CONST_PTYPE_ARRAY(type, varname) extern const type varname[]
* @def CC_CONST_PSTR(varname, value)
* @brief Macro to define a constant string stored in program memory
* @param varname The name of the variable representing the string
* @param value The value of the string
#define CC_CONST_PSTR(varname, value) CC_CONST_PTYPE_ARRAY(char, varname) = value;
//#define CC_CONST_PSTR(var, val) const char var[] PROGMEM = val
* @def CC_EXPORT_CONST_PSTR(varname)
* @brief Macro to declare an externally defined constant string stored in program memory
#define CC_EXPORT_CONST_PSTR(varname) CC_EXPORT_CONST_PTYPE_ARRAY(char, varname)
* @def CC_CONST_PSTRUCT_ARR(type, varname)
* @brief Macro to define a constant array of structures stored in program memory
* @param type The data type of the structures in the array
#define CC_CONST_PSTRUCT_ARR(type, varname) CC_CONST_PTYPE_ARRAY(struct type, varname)
//#define CC_CONST_PSTRUCT_ARR(type, varname) const struct type varname[] PROGMEM
* @def CC_NELEM(x)
* @brief Macro to determine the number of elements in an array
* @param x The array
* @return The number of elements in the array
#define CC_NELEM(x) (sizeof (x)/sizeof (x)[0])
#define CC_ALIGN(n) __attribute__((__aligned__(n)))
* @def CC_MAIN_CONSTRUCTOR(name)
* @brief function called before the void main() entry point
#define CC_MAIN_CONSTRUCTOR(name) void __attribute__((constructor)) name();
* @def CC_MAIN_DESTRUCTOR(name)
* @brief function called after the void main() entry point
#define CC_MAIN_DESTRUCTOR(name) void __attribute__((destructor)) name();
#endif
It should not if I compare it against libraries like DMXSerial or PicoSerial
However, clearly something is going wrong and something is making a reference to one off the HardwareSerial0.cpp members. But which...
Having checked avr-libc I couldn't find anything either that would reference any of these members... so I think I'm going to try to see if I can get some answers from the compiler process by including something like g++ -E -dI or g++ -MM to it.
Even though I do not use <dbg/examples.h> or <utf/utf8-stream.h> in the sketch 21-pt-serial-echo.ino it appears the linker just links the object files examples.cpp.o and utf8-stream.cpp.o from the protoduino library. These 2 object files do use the HardwareSerial0.cpp class members.
Even though my sketch isn't using it, the linker isn't smart enough to figure that out. It would probably not have occurred when the arduino-cli would have created a static precompiled library of all object files first. But that is not what is happening...
That means I have a decision to make. Do I throw out these 2 classes or should I make a conditional build that filters them out when I use serial0.c. The first looks more promising though. But then I have to change the documentation and a lot of code.... brrrr.
Just before I go and make the decision, does anyone know how I add a global define to the compiler options? For vscode I can add it to the c_cpp_properties.json file, but I'm not sure how I should go about with the Arduino IDE.
