Linker error, variant.cpp.o file?
Some time ago I developed a custom board similar to a MKRZERO except it has a few pin changes related to the pins that were used for the SD card are now used as general I/O.
I had this all working, compiling etc. with a custom boards.txt, I did all the JSON related stuff. Everything was working.
Fast forward 6 months or so I try to recompile and now I have compile/link errors. I have not modified the original .ino for the project, I did upgrade a few libraries along the way while working on other Arduino projects. So I recreated my custom board variant using the now upgraded libraries, and most of the compile errors are now gone, I think I'm down to just one error.
The error appears to be related to variant.cpp.o. My understanding of the compile and linking process is pretty limited so I assumed that for some reason Arduino was using an out of date variant.cpp.o file, so I located it and renamed it ___old___variant.cpp.o, expecting Arduino to make a new variant.cpp.o based on variant .cpp, instead it gives basically the same error and is still using the original object file (I think) because the error now states: *"C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.rodata.g_APinDescription+0x0): first defined here collect2.exe: error: ld returned 1 exit status"*
Please suggest what I should do.
I have attached the error messages below, the error is very near the end 11 lines up, I had to delete some of middle section of the error messages as the file is too long, the part I deleted does not have any errors, just normal compile messages, some with warnings
Arduino: 1.8.15 (Windows 7), Board: "EPC E066"
C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware -hardware C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\tools-builder -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware\tools\avr -tools C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\libraries -libraries C:\Users\EPC-JRS\Documents\Arduino\libraries -fqbn=EPC E066-01:samd:epc_E066 -ide-version=10815 -build-path C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208 -warnings=more -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.openocd.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -prefs=runtime.tools.CMSIS-4.0.0-atmel.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -verbose C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino
C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\arduino-builder -compile -logger=machine -hardware C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware -hardware C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\tools-builder -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware\tools\avr -tools C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\libraries -libraries C:\Users\EPC-JRS\Documents\Arduino\libraries -fqbn=EPC E066-01:samd:epc_E066 -ide-version=10815 -build-path C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208 -warnings=more -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.openocd.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -prefs=runtime.tools.CMSIS-4.0.0-atmel.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -verbose C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino
Using board 'epc_E066' from platform in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E066-01\hardware\samd\1.0.0
Using core 'arduino' from platform in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E066-01\hardware\samd\1.0.0
Detecting libraries used...
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for MemoryFree.h: [ZZ_CRAP_Arduino-MemoryFree-master pgmStrToRAM]
ResolveLibrary(MemoryFree.h)
  -> candidates: [ZZ_CRAP_Arduino-MemoryFree-master pgmStrToRAM]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.13]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.10.13]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for Adafruit_ILI9341.h: [Adafruit_ILI9341@1.5.10 arduino_829653@1.5.10]
ResolveLibrary(Adafruit_ILI9341.h)
  -> candidates: [Adafruit_ILI9341@1.5.10 arduino_829653@1.5.10]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for XPT2046_Touchscreen.h: [XPT2046_Touchscreen@1.4]
ResolveLibrary(XPT2046_Touchscreen.h)
  -> candidates: [XPT2046_Touchscreen@1.4]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for OneWire.h: [OneWire@2.3.5]
ResolveLibrary(OneWire.h)
  -> candidates: [OneWire@2.3.5]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
Alternatives for DallasTemperature.h: [Arduino-Temperature-Control-Library-master@3.9.0]
ResolveLibrary(DallasTemperature.h)
  -> candidates: [Arduino-Temperature-Control-Library-master@3.9.0]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\MemoryFree.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\pgmStrToRAM.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.10.1]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.10.1]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
**///// deleted a bumch of lines here to shorten file
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:11:25: warning: extra tokens at end of #include directive
 #include <pgmStrToRAM.h>; // not needed for new way. but good to have for reference.
In file included from C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:13:0:
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20.h:77:50: warning: "/*" within comment [-Wcomment]
 #define   ADC_INPUTCTRL_GAIN_1X_Val       0x0ul  /**< \brief (ADC_INPUTCTRL) 1x
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20.h:78:50: warning: "/*" within comment [-Wcomment]
 #define   ADC_INPUTCTRL_GAIN_2X_Val       0x1ul  /**< \brief (ADC_INPUTCTRL) 2x
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20.h:79:50: warning: "/*" within comment [-Wcomment]
 #define   ADC_INPUTCTRL_GAIN_4X_Val       0x2ul  /**< \brief (ADC_INPUTCTRL) 4x
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20.h:80:50: warning: "/*" within comment [-Wcomment]
 #define   ADC_INPUTCTRL_GAIN_8X_Val       0x3ul  /**< \brief (ADC_INPUTCTRL) 8x
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20.h:81:50: warning: "/*" within comment [-Wcomment]
 #define   ADC_INPUTCTRL_GAIN_16X_Val      0x4ul  /**< \brief (ADC_INPUTCTRL) 16x
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20.h:82:50: warning: "/*" within comment [-Wcomment]
 #define   ADC_INPUTCTRL_GAIN_DIV2_Val     0xFul  /**< \brief (ADC_INPUTCTRL) 1/2x
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:4650:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
      displayText("Down", 48, 143, 2, ILI9341_BLACK );   //  text, x, y, size, color
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:4652:51: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
      displayText("Up", 242, 143, 2, ILI9341_BLACK );   //  text, x, y, size, color
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino: At global scope:
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:2318:16: warning: 'rc' defined but not used [-Wunused-variable]
     static int rc =0;
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:1420:17: warning: 'oldVal' defined but not used [-Wunused-variable]
     static char oldVal[7];
         sprintf(tChar, " %d.%02d ", (int)R, (int)(R*100)%100);
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:3997:6: warning: '%d' directive writing between 1 and 10 bytes into a region of size 9 [-Wformat-overflow=]
 void displayAlarms(void) {   //-------------------------------------------------------------------------
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:3997:6: note: directive argument in the range [0, 2147483647]
C:\Users\EPC-JRS\Documents\Arduino\EL20\EL20_1.ino\EL20_1.ino.ino:4042:16: note: 'sprintf' output between 4 and 13 bytes into a destination of size 10
         sprintf(tChar, " %d ", (int)R);
Compiling libraries...
Compiling library "ZZ_CRAP_Arduino-MemoryFree-master"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\MemoryFree.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\MemoryFree.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\pgmStrToRAM.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\pgmStrToRAM.cpp.o"
Compiling library "SPI"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\SPI\\SPI.cpp.o"
Compiling library "Adafruit_GFX_Library"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-coments\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o"
Compiling library "Wire"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Arduino-Temperature-Control-Library-master" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\libraries\\Wire\\Wire.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Wire\\Wire.cpp.o"
Compiling core...
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01\\variant.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\variant.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01\\_original variant files\\___old___variant.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\_original variant files\\___old___variant.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -x assembler-with-cpp -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino\\pulse_asm.S" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\pulse_asm.S.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\WInterrupts.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino\\hooks.c" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\hooks.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_EPC_E066 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"EPC Inc\"" "-DUSB_PRODUCT=\"EPC_E066\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\cores\\arduino\\cortex_handlers.c" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\cortex_handlers.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\pulse_asm.S.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\USB\\samd21_host.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\WInterrupts.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\compact\\dtostrf.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\cortex_handlers.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\delay.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\hooks.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\itoa.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\pulse.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\startup.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\wiring.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\wiring_analog.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\wiring_digital.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\wiring_private.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\wiring_shift.c.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\Reset.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\SERCOM.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\Tone.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\USB\\CDC.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\USB\\USBCore.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\Uart.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\WMath.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\abi.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\api\\Common.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\api\\Print.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\api\\Stream.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\api\\String.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\main.cpp.o"
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-ar" rcs "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\core.a" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\new.cpp.o"
Linking everything together...
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\EPC E066-01\\hardware\\samd\\1.0.0\\variants\\E066_01/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208/EL20_1.ino.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208/EL20_1.ino.ino.elf" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\sketch\\EL20_1.ino.ino.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\MemoryFree.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\ZZ_CRAP_Arduino-MemoryFree-master\\pgmStrToRAM.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_ILI9341\\Adafruit_ILI9341.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\XPT2046_Touchscreen\\XPT2046_Touchscreen.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\OneWire\\OneWire.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Arduino-Temperature-Control-Library-master\\DallasTemperature.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\_original variant files\\___old___variant.cpp.o" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_330208/core\\core.a" -Wl,--end-group
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o: In function `SERCOM5_Handler':
C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E066-01\hardware\samd\1.0.0\variants\E066_01/variant.cpp:187: multiple definition of `SERCOM5_Handler'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E066-01\hardware\samd\1.0.0\variants\E066_01\_original variant files/___old___variant.cpp:182: first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.Serial1+0x0): multiple definition of `Serial1'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.Serial1+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.sercom5+0x0): multiple definition of `sercom5'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.sercom5+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.sercom4+0x0): multiple definition of `sercom4'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.sercom4+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.sercom3+0x0): multiple definition of `sercom3'
Multiple libraries were found for "MemoryFree.h"
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.sercom3+0x0): first defined here
 Used: C:\Users\EPC-JRS\Documents\Arduino\libraries\ZZ_CRAP_Arduino-MemoryFree-master
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.sercom2+0x0): multiple definition of `sercom2'
 Not used: C:\Users\EPC-JRS\Documents\Arduino\libraries\pgmStrToRAM
Multiple libraries were found for "Adafruit_ILI9341.h"
 Used: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_ILI9341
 Not used: C:\Users\EPC-JRS\Documents\Arduino\libraries\arduino_829653
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.sercom2+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.sercom1+0x0): multiple definition of `sercom1'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.sercom1+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.bss.sercom0+0x0): multiple definition of `sercom0'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.bss.sercom0+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.data.g_apTCInstances+0x0): multiple definition of `g_apTCInstances'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.data.g_apTCInstances+0x0): first defined here
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\variant.cpp.o:(.rodata.g_APinDescription+0x0): multiple definition of `g_APinDescription'
C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_330208\core\_original variant files\___old___variant.cpp.o:(.rodata.g_APinDescription+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
Using library ZZ_CRAP_Arduino-MemoryFree-master in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\ZZ_CRAP_Arduino-MemoryFree-master (legacy)
Using library SPI at version 1.0 in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E066-01\hardware\samd\1.0.0\libraries\SPI
Using library Adafruit_GFX_Library at version 1.10.13 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_ILI9341 at version 1.5.10 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_ILI9341
Using library XPT2046_Touchscreen at version 1.4 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\XPT2046_Touchscreen
Using library OneWire at version 2.3.5 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\OneWire
Using library Arduino-Temperature-Control-Library-master at version 3.9.0 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master
Using library Adafruit_BusIO at version 1.10.1 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E066-01\hardware\samd\1.0.0\libraries\Wire
exit status 1
Error compiling for board EPC E066.
It looks like the linker included both __old__variant.cpp.o and variant.cpp.o
I would suggest you rename the extension: __old__varient.cpp.o.old
blh64,
I think your right. Can you explain, why the linker would do that?
My guess is that this happened because I made a folder named old_varients and put the old versions of the variant.h and .cpp just in case I needed to look at the old ones. I moved that folder renamed the .o files and it finally compiles.
Thanks very much, I learned a little lesson from this.
J
I don't know for sure but the IDE tool chains moves a lot of stuff into temporary folders when compiling and my guess is that is just assumes everything in there needs to be compiled and linked together due to its existence.
