I would appreciate help; I can't find the problem in the code. Matrix 1 works as expected according to the XYTable1 array, and I want Matrix 2 (LED_PIN2) to work according to the XYTable2 array. I can't figure out where the problem is.
#include <FastLED.h>
// #ifdef __AVR__
// #include <avr/power.h>
// #endif
// #define NUM_LEDS 100
uint16_t XY(uint8_t x, uint8_t y, uint8_t matrixIndex);
#define LED_PIN 1
#define LED_PIN2 18
#define COLOR_ORDER GRB // Color order of LED string [GRB]
#define CHIPSET WS2812B // LED string type [WS2182B]
#define BRIGHTNESS 50 // Overall brightness [50]
#define LAST_VISIBLE_LED 102 // Last LED that's visible [102]
#define MAX_MILLIAMPS 5000 // Max current in mA to draw from supply [500]
#define SAMPLE_WINDOW 100 // How many ms to sample audio for [100]
#define DEBOUNCE_MS 20 // Number of ms to debounce the button [20]
#define LONG_PRESS 500 // Number of ms to hold the button to count as long press [500]
#define PATTERN_TIME 10 // Seconds to show each pattern on autoChange [10]
#define kMatrixWidth 16 // Matrix width [15]
#define kMatrixHeight 16 // Matrix height [11]
#define NUM_LEDS (kMatrixWidth * kMatrixHeight) // Total number of Leds
#define MAX_DIMENSION ((kMatrixWidth>kMatrixHeight) ? kMatrixWidth : kMatrixHeight) // Largest dimension of matrix
Adafruit_NeoPixel matrix_M1 = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel matrix_M2 = Adafruit_NeoPixel(NUM_LEDS, LED_PIN2, NEO_GRB + NEO_KHZ800);
#define NUM_MATRICES 2
#define RANDOM_PATTERN_TIME (random(10, 20)) // Change the range according to your preferences
CRGB leds[NUM_LEDS];
CRGB leds2[NUM_LEDS];
uint8_t patternCounters[NUM_MATRICES] = {0, 0};
uint16_t patternDurations[NUM_MATRICES] = {10, 0}; // Array to store pattern durations
bool isRunning[NUM_MATRICES] = {false, false};
// uint8_t patternCounter = 0; // Added this line
// void runPride2015(uint8_t matrixIndex, uint16_t duration, const uint8_t XYTable[kMatrixHeight][kMatrixWidth]);
void runPlasma(uint8_t matrixIndex, uint16_t duration);
void runPacifica(uint8_t matrixIndex, uint16_t duration);
void checkTimer();
#include "Fire2012.h"
#include "Pacifica.h"
// #include "Pride2015.h"
// #include "Rainbow.h"
#include "Plasma.h"
#include "XYUtils.h"
const uint8_t XYTable1[kMatrixHeight][kMatrixWidth] = {
{32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47},
{63,62,61,60,59,58,57,56,55,54,53,52,51,50,49,48},
{64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79},
{95,94,93,92,91,90,89,88,87,86,85,84,83,82,81,80},
{96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111},
{127,126,125,124,123,122,121,120,119,118,117,116,115,114,113,112},
{128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143},
{159,158,157,156,155,154,153,152,151,150,149,148,147,146,145,144},
{160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175},
{191,190,189,188,187,186,185,184,183,182,181,180,179,178,177,176},
{192,193,194,195,196,197,198,199,200,201,202,203,204,205,206,207},
const uint8_t XYTable2[kMatrixHeight][kMatrixWidth] = {
// #define RANDOM_PATTERN_TIME (random(10, 20)) // Change the range according to your preferences
const uint8_t (*xyTables[])[kMatrixHeight][kMatrixWidth] = {&XYTable1, &XYTable2 /*, ... add more XYTables if needed */};
uint16_t XY(uint8_t x, uint8_t y, uint8_t matrixIndex) {
if (matrixIndex == 0) {
// XYTable1 is associated with matrixIndex 0
if (x < kMatrixWidth && y < kMatrixHeight) {
return XYTable1[y][x];
} else if (matrixIndex == 1) {
// XYTable2 is associated with matrixIndex 1
return XYTable2[y][x];
return 0; // or some default value
FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
FastLED.addLeds<WS2812B, LED_PIN2, GRB>(leds2, NUM_LEDS);
matrix_M1.begin();
matrix_M1.show(); // Initialize all pixels to 'off'
matrix_M2.begin();
matrix_M2.show(); // Initialize all pixels to 'off'
FastLED.setBrightness(50);
Serial.begin(57600);
for (int i = 0; i < NUM_MATRICES; i++) {
patternCounters[i] = random(3); // Initialize each matrix with a random pattern
patternDurations[i] = i+6; // Set initial duration for each matrix
void checkTimer() {
EVERY_N_SECONDS(RANDOM_PATTERN_TIME) {
nextPattern();
void nextPattern() {
isRunning[i] = false;
patternDurations[i] = random(2, 40); // Update duration for each matrix
void runMatrix(uint8_t matrixIndex) {
// Generate a random duration for the current matrix
uint16_t randomDuration = random(2, 28);
// Serial.println(matrixIndex);
switch (patternCounters[matrixIndex]) {
case 0:
runPacifica(matrixIndex, randomDuration);
case 1:
runPlasma(matrixIndex, randomDuration);
case 2:
// Add more cases if you have more patterns
if (!isRunning[i]) {
// Select a random pattern for each matrix if it's not currently running
patternDurations[i] = random(1, 15); // Update duration for each matrix
// runMatrix(i, *xyTables[i]);
runMatrix(i);
checkTimer();
void runPacifica(uint8_t matrixIndex, uint16_t duration) {
isRunning[matrixIndex] = true;
Pacifica pacifica = Pacifica(patternDurations[matrixIndex], matrixIndex);
unsigned long startTime = millis();
while (isRunning[matrixIndex] && (millis() - startTime) < (duration * 1000)) {
pacifica.runPattern();
delay(50);
isRunning[matrixIndex] = false;
void runPlasma(uint8_t matrixIndex, uint16_t duration) {
Plasma plasma = Plasma(patternDurations[matrixIndex], matrixIndex); // Pass XYTable to the constructor
plasma.runPattern();
delay(50);
