Hello,
im a new member of the forum so if i type something unusual im so sorry from now..
so im having issue with my strips,
my goal is to make a ambilight setup that you can see on YT there is a lot of them..
i placed my strips around my 34 inch monitor they are 125 pixels total,
i have a Arduino nano, i made the connections;
Data from LEDs to arduino D6,
Ground and 5V pins to Arduino these are the baby steps you know ![]()
and after i uploaded a basic code all the lights were working good but as you can gues from a USB 2.0 or 3.0 we can get only 100 - 150 miliamps
which made some color differences on my strip i mean if i light all the strips white, pixels at the begining were white, but at the end of the strips were like more yellowish white.. so as you can guess i need more power,
i bought a LED power supply 12V 12.5Amps, which is enough i think for 125 pixels,
BUT THIS IS THE POINT WHERE MY PROBLEMS STARTING...
ifi cutted the wiire for 5V from Arduino and connected it directly to my power supply V+ output and V- to LED's Ground, also on my strip there is another ground cable that goes to Arduino ground
so, if i turn my power supply on, nothing happens only the first pixel lights up, if i reset it by unplug it and plug it again, lights are working but without any effect something like stucked , and if i repeat that process unplug and plug again, sometimes working with effects but looking like its trying to run all effects on the code at the same time, sometimes stucking again i mean its not working correctly...
AFTER THAT,
i cut my data cable from leds to arduino and put a 470ohm resistor, and this time nothing happened only the first pixel working when my power supply is plugged...
AFTER THAT, i connected a capacitor 1000fu 10v to cables that goes from V+ V- to the strip and nothing happened again...
so guys, can you tell me where im doing something wrong ?? :(((
its working fine from usb but not working with my power supply ![]()
