Hello All,
**THERE ARE TWO SCRIPTS HERE THE FIRST ONE WORKS, THE SECOND ON FAILS WHEN I ADD VOID PAINTROOM()**
I am writing this Script I found and am editing, for my use, to a ESP8266 NodeMCU Board
I want to add a "void paintroom()" to this script so that the if else statement " if (i==1) //1 = Paint Room" can call the void Paint Room() where the word Paint Room is added.
I tried it and keep getting failed compiles that I can't find a way to fix the problems.
Please help if you can
Thanks
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp8266-relay-module-ac-web-server/
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
// Import required libraries
#include "ESP8266WiFi.h"
#include "ESPAsyncWebServer.h"
// Set to true to define Relay as Normally Open (NO)
#define RELAY_NO true
// Set number of relays
//#define NUM_RELAYS 5
// Assign each GPIO to a relay
//int relayGPIOs[NUM_RELAYS] = {5, 4, 14, 12, 13};
// Replace with your network credentials
//const char* ssid = "REPLACE_WITH_YOUR_SSID";
//const char* password = "REPLACE_WITH_YOUR_PASSWORD";
const char* ssid = "XXXXXXXX";
const char* password = "XXXXXXXXXX";
const char* PARAM_INPUT_1 = "relay";
const char* PARAM_INPUT_2 = "state";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<style>
html {font-family: Arial; display: inline-block; text-align: center;}
h2 {font-size: 3.0rem;}
p {font-size: 3.0rem;}
body {max-width: 600px; margin:0px auto; padding-bottom: 25px;}
.switch {position: relative; display: inline-block; width: 120px; height: 68px}
.switch input {display: none}
.slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 34px}
.slider:before {position: absolute; content: ""; height: 52px; width: 52px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .4s; transition: .4s; border-radius: 68px}
input:checked+.slider {background-color: #2196F3}
input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(52px); transform: translateX(52px)}
</style>
</head>
<body>
<h2>Hoffman Collision ESP Web Server</h2>
%BUTTONPLACEHOLDER%
<script>function toggleCheckbox(element) {
var xhr = new XMLHttpRequest();
if(element.checked){ xhr.open("GET", "/update?relay="+element.id+"&state=1", true); }
else { xhr.open("GET", "/update?relay="+element.id+"&state=0", true); }
xhr.send();
}</script>
</body>
</html>
)rawliteral";
// Replaces placeholder with button section in your web page
String processor(const String& var){
//Serial.println(var);
if(var == "BUTTONPLACEHOLDER"){
String buttons ="";
for(int i=1; i<=NUM_RELAYS; i++){
String relayStateValue = relayState(i);
//My Edit if i = 1
{ // I WANT TO CALL VOID PAINT ROOM() HERE
buttons+= "<h4>Relay #" + String(i) + " - GPIO " + relayGPIOs[i-1] + " Paint Room " + "</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"" + String(i) + "\" "+ relayStateValue +"><span class=\"slider\"></span></label>";
buttons+= "<h4>Relay #" + String(i) + " - GPIO " + relayGPIOs[i-1] + "</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"" + String(i) + "\" "+ relayStateValue +"><span class=\"slider\"></span></label>";
return buttons;
return String();
String relayState(int numRelay){
if(RELAY_NO){
if(digitalRead(relayGPIOs[numRelay-1])){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
// Serial port for debugging purposes
// Set all relays to off when the program starts - if set to Normally Open (NO), the relay is off when you set the relay to HIGH
pinMode(relayGPIOs[i-1], OUTPUT);
if(RELAY_NO){
digitalWrite(relayGPIOs[i-1], HIGH);
else{
digitalWrite(relayGPIOs[i-1], LOW);
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
// Print ESP8266 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
// Send a GET request to <ESP_IP>/update?relay=<inputMessage>&state=<inputMessage2>
server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) {
String inputMessage;
String inputParam;
String inputMessage2;
String inputParam2;
// GET input1 value on <ESP_IP>/update?relay=<inputMessage>
if (request->hasParam(PARAM_INPUT_1) & request->hasParam(PARAM_INPUT_2)) {
inputMessage = request->getParam(PARAM_INPUT_1)->value();
inputParam = PARAM_INPUT_1;
inputMessage2 = request->getParam(PARAM_INPUT_2)->value();
inputParam2 = PARAM_INPUT_2;
if(RELAY_NO){
Serial.print("NO ");
digitalWrite(relayGPIOs[inputMessage.toInt()-1], !inputMessage2.toInt());
else{
Serial.print("NC ");
digitalWrite(relayGPIOs[inputMessage.toInt()-1], inputMessage2.toInt());
else {
inputMessage = "No message sent";
inputParam = "none";
Serial.println(inputMessage + inputMessage2);
request->send(200, "text/plain", "OK");
// Start server
server.begin();
//THIS IS THE FAILED SCRIPT WHERE I TRIED ADDING THE void PaintRoom()
Rui Santos
//My Edits
String buttons ="";
int i;
int relayStateValue;
int relayValue;
String relayState;
const char* ssid = "SECURE_10";
const char* password = "DED4DD82CD";
<head>
<style>
</style>
</head>
<body>
%BUTTONPLACEHOLDER%
xhr.send();
}</script>
</body>
</html>
)rawliteral";
String buttons ="";
Serial.println (relayGPIOs[i-1]);
if(i==5)
PaintRoom();
return buttons;
return String();
if(RELAY_NO){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
//My Edit
String paintroom = "Paint Room";
// Set all relays to off when the program starts - if set to Normally Open (NO), the relay is off, when you set the relay to HIGH
if(RELAY_NO){
else{
// Connect to Wi-Fi
String inputParam;
String inputParam2;
if(RELAY_NO){
else{
else {
// Start server
server.begin();
void PaintRoom()
//buttons+= "<h4>Relay #" + String(i) + " - GPIO " + relayGPIOs[i-1] + " Paint Room " + "</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"" + String(i) + "\" "+ relayStateValue +"><span class=\"slider\"></span></label>";
buttons+= "<h4>Relay #" + String(1) + " - GPIO " + relayGPIOs[1] + " Paint Room " + "</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"" + String(1) + "\" "+ relayStateValue +"><span class=\"slider\"></span></label>";
//Serial.println (String(1));
Serial.println ("Paint Room");
Rui Santos
//My Edits
String buttons ="";
int i;
int relayValue;
String relayState;
#define RELAY_NO truetype or paste code here
<head>
<style>
</style>
</head>
<body>
%BUTTONPLACEHOLDER%
xhr.send();
}</script>
</body>
</html>
)rawliteral";
String buttons ="";
if(i==5)
PaintRoom();
return buttons;
return String();
if(RELAY_NO){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
//My Edit
if(RELAY_NO){
else{
// Connect to Wi-Fi
String inputParam;
String inputParam2;
if(RELAY_NO){
else{
else {
// Start server
server.begin();
void PaintRoom()
Show errors for one attempt it will make it a bit faster?
Hello
I want to add a "void Paint Room()" to this script so that the if else statement " if (i==1) //1 = Paint Room" can call the void Paint Room() where the word Paint Room is added.
Thanks
Rui Santos
<head>
<style>
</style>
</head>
<body>
%BUTTONPLACEHOLDER%
xhr.send();
}</script>
</body>
</html>
)rawliteral";
String buttons ="";
//My Edit if i = 1
return buttons;
return String();
if(RELAY_NO){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
if(RELAY_NO){
else{
// Connect to Wi-Fi
String inputParam;
String inputParam2;
if(RELAY_NO){
else{
else {
// Start server
server.begin();
void paintRoom(){
//your code here.....
Is this supposed to be in the function?
All the code in this section won't work because it is not in the setup or loop.
Paint Room isn’t a word, it’s TWO words ?
The C languages are predicated on ‘white space’ hence the (space) between the words is important to the language.
it could be a (tab), or (newline), but that air between the words is meaningful.
Try replacing Paint Room with Paint_Room.
Hello,
Thanks for your reply,
See the second script, it is void paintroom()
that which you call a void() is a function. this was mentioned but not explained above
your function name is paintroom. it is traditional to capitalize the first letter of words after the first word, so a function named lockandload would be lockAndLoad. this enhances readability for others
It is also traditional to capitalize the first word in a sentence.
but you do you. we can read it anyway.
a7
Hello All,
**Please search for //My Edit if i = 1 in both scripts**
I am writing this Script that I found, and I am editing it for my use, for a ESP8266 NodeMCU Board
I want to add a "void PaintRoom()" to this script called from the if else statement "if (i==1) call the void PaintRoom()
I tried it and keep getting failed compiles and even making some global vaiables I can't find a way to fix the problems.
**THE FIST SCRIPT WORKS. THE SECOND SCRIPT FAILS WHEN I ADD THE VOIR PAINTROOM()**
Please help if you can.
Thanks
Rui Santos
<head>
<style>
</style>
</head>
<body>
%BUTTONPLACEHOLDER%
xhr.send();
}</script>
</body>
</html>
)rawliteral";
String buttons ="";
//My Edit if i = 1
return buttons;
return String();
if(RELAY_NO){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
if(RELAY_NO){
else{
// Connect to Wi-Fi
String inputParam;
String inputParam2;
if(RELAY_NO){
else{
else {
// Start server
server.begin();
**//THIS IS THE FAILED SCRIPT WHERE I TRIED ADDING THE void PaintRoom()**
Rui Santos
//My Edits
String buttons ="";
int i;
int relayValue;
String relayState;
const char* ssid = "xxxxxxxx";
const char* password = "xxxxxxxxxxx";
<head>
<style>
</style>
</head>
<body>
%BUTTONPLACEHOLDER%
xhr.send();
}</script>
</body>
</html>
)rawliteral";
String buttons ="";
//My Edit if i = 1
//My Edit if i = 1
if (i==1)
PaintRoom()
return buttons;
return String();
if(RELAY_NO){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
//My Edit
if(RELAY_NO){
else{
// Connect to Wi-Fi
String inputParam;
String inputParam2;
if(RELAY_NO){
else{
else {
// Start server
server.begin();
void PaintRoom()
Rui Santos
//My Edits
String buttons ="";
int i;
int relayValue;
String relayState;
<head>
<style>
</style>
</head>
<body>
%BUTTONPLACEHOLDER%
xhr.send();
}</script>
</body>
</html>
)rawliteral";
String buttons ="";
if(i==5)
PaintRoom();
return buttons;
return String();
if(RELAY_NO){
return "";
else {
return "checked";
else {
return "checked";
else {
return "";
return "";
void setup(){
//My Edit
if(RELAY_NO){
else{
// Connect to Wi-Fi
String inputParam;
String inputParam2;
if(RELAY_NO){
else{
else {
// Start server
server.begin();
void PaintRoom()
Please do not insert your message text into code tags, it make it difficult to read.
Show this error.
Proofread all your work. You probably misspelled or mis-pasted something (or many things). Why? You haven't made one post without a spelling or copy/paste error.
Hello All,
Please see my PasteBin of my two scripts. I hope this is clearer.
Thank you for your help
It is still not clear for me what kind of help do you expect from the community.
Could you please take an effort to explain in detail, what is your problem.
I would recommended you to read a forum guidelines about how to ask a question properly.
Hello,
I was hoping someone would run my script and would be able to figure out how to add the void PaintRoom() to my script that would not give me the error I keep getting which is 1. 'String relayState(int)' redeclared as different kind of entity
What are you unclear about?
Thanks
Isn't it too much ?
It is a first time when you show anything clear about your code issues.
Please insert your final code(not a two unedited sketches) in the message to make it visible to helpers.
Please learn how to use code tags.
Each separate sketch should have its chance of turning up here readable.
First use the IDE Autoformat tool.
Then Copy the entire sketch, come back here and in a new post use the <CODE/> tool in message composition window tool bar and
where it says. Replace 'type or paste code here' with your code.
One code block for each sketch.
Replace 'type or paste code here' by, well, pasting your code there.
Most prefer not to go off to Psatebin or Tinkercod or whatever.
If all you are trying to do is add one function you found one palace to another sketch you found somewhere else, use a third code block ('type or paste code here') and paste just that function there.
a7
Hello alto777,
I will try again. I will post just the one script, the one that doesn't work with the void PaintRoom()
I was hoping a member of the forum who has an ESP8266 module to copy my code and run it to see the errors. I would think that would be the easiest way to figure out the problem.
Do you think it is too much to ask if someone has the ESP8266 module to copy and paste the script? There is no setting up breadboards or LED's to test this script.
Please post the three things I asked for. Your problem is in borrowing and mixing code you have few clues about; it is necessary to see what you are working with and where the pieces came from and the context from which you ruthlessly ripped them.
Clearly now with code tags late in the thread. Like a frash start. A new day. :-|
Also, here's a simulator that is superior to Tinkercod, and it would be work you could do once instead of asking everyone to do to move your code there and wire up the circuit and hit the share button.
No account needed, free.
a7
If you cannot compile your code we cannot compile your code.
So no one will need an esp to try to run your code (executable code is produced during compiling....) or more precise after linking.
First your code needs to compile...
Look for this bit in your code: String relayState(int).
You will probably find it two (or three?) times. One if them needs to be removed.
Following this line...@stspringer - have you installed the ESP8266WiFi library? When I try to compile your sketches, I immediately see a failure that I do not have all the files I need to fully compile your sketches. Let us know where you installed ESP8266WiFi... via the IDE or via the repository (manually downloading the library).
This is your PaintRoom() function... You could put it into a test HTML file and see if it shows any errors (HTML is very forgiving and will ignore syntax errors, usually showing as blank screens or empty spaces):
void PaintRoom()
