Having problem with my Esp32
Hello, I am reaching out for assistance regarding an issue with my ESP32. Despite having purchased the ESP32 and installed the necessary drivers, I am unable to establish an internet connection and its keep repeating. I am using the ESP32 to test my connection for my projects. Could you please help me troubleshoot this issue?
If you would like to review the code for this project, please let me know, and I would be happy to share it with you.
A 105 error has nothing to do with the internet. You either did not specify the correct camera in your code, or the camera connector is making poor contact. It sounds more like the camera is not properly specified in the source code given the PSRAM error. Post all your code in code tags.
Thank you for your response. I appreciate the clarification regarding the 105 error.I will post my complete code . Please let me know if you need any additional details.
#include <WiFi.h>'
#include <WiFiClientSecure.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
// Replace with your network credentials
const char* ssid = "Hans";
const char* password = "Hans12345";
String chatId = "XXXXXXXXXXX";
// Initialize Telegram BOT
String BOTtoken = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
bool sendPhoto = false;
WiFiClientSecure clientTCP;
UniversalTelegramBot bot(BOTtoken, clientTCP);
// clientTCP.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
// Adding root certificate in Setup()
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#define FLASH_LED_PIN 4
bool flashState = LOW;
// Motion Sensor
const byte motionSensor = 13;
bool motionDetected = false;
bool motionDetectEnable = false;
// Door Sensor
const byte door1 = 12;
const byte door2 = 2;
bool door1stat = true;
bool door2stat = true;
bool doorLockMonitor = false;
// fire sensor
bool fireDetectMonitor = false;
const byte firePin = 14;
bool fire = false;
// MQ6 Smoke LPG gas leak Detector
bool smokeDetectMonitor = false;
const byte smokePin = 15;
bool smoke = false;
int botRequestDelay = 1000;   // mean time between scan messages
long lastTimeBotRan;     // last time messages' scan has been done
void handleNewMessages(int numNewMessages);
String sendPhotoTelegram();
// ISR (Interrupt Service Routine) Indicates when motion is detected
static void IRAM_ATTR detectsMovement(void * arg){
  //Serial.println("MOTION DETECTED!!!");
  motionDetected = true;
void setup(){
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  // Set All Sensors Pin As INPUT
  pinMode(door1, INPUT);
  pinMode(door2, INPUT);
  pinMode(firePin, INPUT);
  pinMode(smokePin, INPUT);
  // Camera Flash
  pinMode(FLASH_LED_PIN, OUTPUT);
  digitalWrite(FLASH_LED_PIN, flashState);
  // Initialize WiFi
  WiFi.mode(WIFI_STA);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.print("ESP32-CAM IP Address: ");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  // Drop down frame size for higher initial frame rate
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_CIF);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  // PIR Motion Sensor mode INPUT_PULLUP
  //err = gpio_install_isr_service(0);
  err = gpio_isr_handler_add(GPIO_NUM_13, &detectsMovement, (void *) 13);
  if (err != ESP_OK){
    Serial.printf("handler add failed with error 0x%x \r\n", err);
  err = gpio_set_intr_type(GPIO_NUM_13, GPIO_INTR_POSEDGE);
  if (err != ESP_OK){
    Serial.printf("set intr type failed with error 0x%x \r\n", err);
  delay(40000); // Give time for PIR and MQ6 Gas Sensor to get Stable
  Serial.printf("PIR Sensor Initilized!! \n");
void loop(){
  if (sendPhoto){
    Serial.println("Preparing photo");
    sendPhoto = false;
  // If Door 1 is got Opened
  door1stat = digitalRead(door1);
  if(!door1stat && doorLockMonitor){
    bot.sendMessage(chatId, "Alert - Door1 Opened !!", "");
    Serial.println("Door1 Opened");
    door1stat = true;
  // If Door 2 is got Opened
  door2stat = digitalRead(door2);
  if(!door2stat && doorLockMonitor){
    bot.sendMessage(chatId, "Alert - Door2 Opened !!", "");
    Serial.println("Door2 Opened");
    door2stat = true;
  // If Fire got detected in house
  fire = digitalRead(firePin);
  if(!fire && fireDetectMonitor){
    bot.sendMessage(chatId, "Alert - Fire at house !!", "");
    Serial.println("Fire Detected");
    fire = false;
  // If Smoke got detected in house
  smoke = digitalRead(smokePin);
  if(!smoke && smokeDetectMonitor){
    bot.sendMessage(chatId, "Alert - Something is Burning !!", "");
    Serial.println("Smoke Detected");
    smoke = false;
  // If Intruder Motion got detected in house
  if(motionDetected && motionDetectEnable){
    bot.sendMessage(chatId, "Motion detected!!", "");
    Serial.println("Motion Detected");
    delay(2000);
  if (millis() > lastTimeBotRan + botRequestDelay){
    int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
    while (numNewMessages){
      Serial.println("got response");
      handleNewMessages(numNewMessages);
    lastTimeBotRan = millis();
String sendPhotoTelegram(){
  const char* myDomain = "api.telegram.org";
  String getAll = "";
  String getBody = "";
  camera_fb_t * fb = NULL;
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    ESP.restart();
    return "Camera capture failed";
  Serial.println("Connect to " + String(myDomain));
  if (clientTCP.connect(myDomain, 443)) {
    Serial.println("Connection successful");
    String head = "--Hans\r\nContent-Disposition: form-data; name=\"chat_id\"; \r\n\r\n" + chatId + "\r\n--Hans\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"esp32-cam.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String tail = "\r\n--make2explore--\r\n";
    uint16_t imageLen = fb->len;
    uint16_t extraLen = head.length() + tail.length();
    uint16_t totalLen = imageLen + extraLen;
    clientTCP.println("POST /bot"+BOTtoken+"/sendPhoto HTTP/1.1");
    clientTCP.println("Host: " + String(myDomain));
    clientTCP.println("Content-Length: " + String(totalLen));
    clientTCP.println("Content-Type: multipart/form-data; boundary=Hans");
    clientTCP.println();
    clientTCP.print(head);
    uint8_t *fbBuf = fb->buf;
    size_t fbLen = fb->len;
    for (size_t n=0;n<fbLen;n=n+1024) {
      if (n+1024<fbLen) {
        clientTCP.write(fbBuf, 1024);
        fbBuf += 1024;
      else if (fbLen%1024>0) {
        size_t remainder = fbLen%1024;
        clientTCP.write(fbBuf, remainder);
    clientTCP.print(tail);
    esp_camera_fb_return(fb);
    int waitTime = 10000;   // timeout 10 seconds
    long startTimer = millis();
    boolean state = false;
    while ((startTimer + waitTime) > millis()){
      Serial.print(".");
      delay(100);
      while (clientTCP.available()) {
        char c = clientTCP.read();
        if (state==true) getBody += String(c);
        if (c == '\n') {
          if (getAll.length()==0) state=true;
          getAll = "";
        else if (c != '\r')
          getAll += String(c);
      if (getBody.length()>0) break;
    clientTCP.stop();
    Serial.println(getBody);
  else {
    getBody="Connected to api.telegram.org failed.";
    Serial.println("Connected to api.telegram.org failed.");
  return getBody;
void handleNewMessages(int numNewMessages){
  Serial.print("Handle New Messages: ");
  Serial.println(numNewMessages);
  for (int i = 0; i < numNewMessages; i++){
    // Chat id of the requester
    String chat_id = String(bot.messages[i].chat_id);
    if (chat_id != chatId){
      bot.sendMessage(chat_id, "Unauthorized user", "");
      continue;
    // Print the received message
    String text = bot.messages[i].text;
    Serial.println(text);
    String fromName = bot.messages[i].from_name;
    // Implementation of all the Commands from START
    if (text == "/flashOn") {
      flashState = true;
      bot.sendMessage(chat_id, "Flash is set to ON", "");
    if (text == "/flashOff") {
      flashState = false;
      bot.sendMessage(chat_id, "Flash is set to OFF", "");
    if (text == "/photo") {
      sendPhoto = true;
      bot.sendMessage(chat_id, "Capturing Photo...", "");
      Serial.println("New photo request");
    if (text == "/EnableMotionAlert") {
       motionDetectEnable = true;
       bot.sendMessage(chat_id, "Motion Alert - Enabled", "");
       Serial.println("Enable the Motion alert");
    if (text == "/DisableMotionAlert") {
       bot.sendMessage(chat_id, "Motion Alert - Disabled", "");
       Serial.println("Disable the Motion alert");
    if (text == "/EnableDoorAlert") {
       doorLockMonitor = true;
       bot.sendMessage(chat_id, "Monitor Doors - Enabled", "");
       Serial.println("Enable the Monitor Doors");
    if (text == "/DisableDoorAlert") {
       bot.sendMessage(chat_id, "Monitor Doors - Disabled", "");
       Serial.println("Disable the Monitor Doors");
    if (text == "/EnableFireAlert") {
       fireDetectMonitor = true;
       bot.sendMessage(chat_id, "Fire Detector - Enabled", "");
       Serial.println("Enable the Fire Detector");
    if (text == "/DisableFireAlert") {
       bot.sendMessage(chat_id, "Fire Detector - Disabled", "");
       Serial.println("Disable the Fire Detector");
    if (text == "/EnableSmokeAlert") {
       smokeDetectMonitor = true;
       bot.sendMessage(chat_id, "Smoke Detector - Enabled", "");
       Serial.println("Enable the Smoke Detector");
    if (text == "/DisableSmokeAlert") {
       bot.sendMessage(chat_id, "Smoke Detector - Disabled", "");
       Serial.println("Disable the Smoke Detector");
    if (text == "/start"){
      String welcome = "Welcome to the make2explore ESP32-CAM Telegram bot.\n\n";
      welcome += "Use the following command to Setup the ESPCAM.\n\n";
      welcome += "/flashOn : Turn on the flash LED\n";
      welcome += "/flashOff : Turn off the flash LED\n";
      welcome += "/photo : takes a new photo\n\n";
      welcome += "/EnableMotionAlert : enables the motion Alert System\n";
      welcome += "/DisableMotionAlert : disables the motion Alert System\n\n";
      welcome += "/EnableDoorAlert : enables the door Open Alert System\n";
      welcome += "/DisableDoorAlert : disables the door Open Alert System\n\n";
      welcome += "/EnableSmokeAlert : enables the Smoke Alert System\n";
      welcome += "/DisableSmokeAlert : disables the Smoke Alert System\n\n";
      welcome += "/EnableFireAlert : enables the Fire Alert System\n";
      welcome += "/DisableFireAlert : disables the Fire Alert System\n\n";
      welcome += "You'll receive a photo whenever motion is detected.\n";
      bot.sendMessage(chatId, welcome, "Hans");
I don't see case 1, so the cable is not properly seated. Take it out and when you pout it back, there should be a small but noticeable click as it FULLY seats.
Thank you! I'll try it now and see if that works.
Update:
its working now thank you very much sonofcy
Ok, my post as the solution then.
