Having problems in Combining multiple codeblocks to a Single Arduino code for a System having multiple section of works
We are finalizing the total source code of our "Smart pet care system", there are 2 servo motors, 1 Ultrasonic sensor, 1 water level sensor, 1 water pump, and 1 LED...
following is the connection pins on the Arduino Uno,
"0-
1-
2- trigger
3- echo
4- Servo2
5- LED1
6-
7- Water Pump
8- Servo1
9- RST
10- SDA
11- MOSI
12- MISO
13- SCK"
we have did our code by 4 parts which are working fine individually, following will explain those 4 types of codes,
Code 1: This code is to control the maingate of our system, it uses Servo1 to control the system according to the following code,
#include <Servo.h>
#include <MFRC522.h>
#include <SPI.h>
// Pin definitions
#define SS_PIN 10
#define RST_PIN 9
// Create instances for Servo and RFID reader
Servo myServo1;
MFRC522 mfrc522(SS_PIN, RST_PIN);
// RFID UID
byte targetUID[] = {0xA0, 0x84, 0x2C, 0x0E};
  // Attach the servo to pin 8
  myServo1.attach(8);
  // Initialize SPI bus and MFRC522 RFID reader
  SPI.begin();
  mfrc522.PCD_Init();
  // Start with the gate closed
  myServo1.write(90);  // 90 degrees = closed position
  // Look for new RFID cards
  if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()) {
    // Check if the detected UID matches the target UID
    if (checkUID(mfrc522.uid.uidByte)) {
      // Open the gate (move servo to 0 degrees)
      for (int angle = 90; angle >= 0; angle--) {
        myServo1.write(angle);
        delay(15);  // Adjust delay for smooth movement
      delay(5000);  // Keep the gate open for 5 seconds
      // Close the gate (move servo back to 90 degrees)
      for (int angle = 0; angle <= 90; angle++) {
    // Halt PICC so it stops reading
    mfrc522.PICC_HaltA();
// Function to check if the UID matches the target UID
bool checkUID(byte *uid) {
  for (byte i = 0; i < 4; i++) {
    if (uid[i] != targetUID[i]) {
      return false;
  return true;
Code2: this code is for controlling the food dispenser, which will open the door of the hole of the food chamber for 2 seconds for every 1 min by using Servo2. which shows the following code,
#include <Servo.h>
// Create servo objects
Servo myServo2; // Servo2 for food dispensing
  // Attach the servos to their respective pins
  myServo2.attach(4);  // Servo2 on pin 4
// Control Servo2 (food dispensing)
  myServo2.write(0);  // Move servo2 to 0 degrees (initial position)
  delay(60000);        // Wait for 2 seconds
  myServo2.write(45); // Move servo2 to 45 degrees
  delay(2000);        // Wait for 2 seconds
Code 3: this code is to check the level of the food, my container's length is 27cm(Vertically). if the empty space exceeds 20cms the LED will blink, which shows the following code,
const int trigPin = 2;  // Trig pin connected to pin 2
const int echoPin = 3;  // Echo pin connected to pin 3
const int ledPin = 5;   // LED connected to pin 5
long duration;
int distance;
  // Initialize the serial communication
  // Set the trigPin as an output and the echoPin as an input
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // Set the ledPin as an output
  pinMode(ledPin, OUTPUT);
  // Clear the trigPin by setting it LOW
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Trigger the sensor by setting the trigPin HIGH for 10 microseconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the echoPin, which returns the duration of the pulse in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculate the distance in centimeters
  distance = duration * 0.034 / 2; // Speed of sound is 343 m/s or 0.034 cm/µs
  // Print the distance to the Serial Monitor
  Serial.print("Distance: ");
  Serial.print(distance);
  Serial.println(" cm");
  // Check if the distance is 20 cm or less
  if (distance >= 20) {
    // Blink the LED
    digitalWrite(ledPin, HIGH);  // Turn on the LED
    delay(250);                  // Wait for 250 milliseconds
    digitalWrite(ledPin, LOW);   // Turn off the LED
    // Ensure the LED is off when the distance is greater than 20 cm
  // Wait before the next measurement
Code 4: This is for managing the water level using the water level sensor. the following code shows that,
// Constants for the pins used
const int analogInPin = A0;  // Analog input pin for the water level sensor
const int pumpPin = 7;       // Digital output pin for the water pump
int sensorValue = 0;  // Value read from the water level sensor
  // Initialize serial communication at 9600 bps
  // Set the pumpPin as an output
  pinMode(pumpPin, OUTPUT);
  // Read the analog value from the water level sensor
  sensorValue = analogRead(analogInPin);
  // Print the sensor value to the Serial Monitor
  Serial.print("Water level sensor value = ");
  Serial.println(sensorValue);
  // Check if the sensor value is less than 280
  if (sensorValue < 280) {
    // Turn on the water pump
    digitalWrite(pumpPin, HIGH);
    // Keep the pump on for 5 seconds
    delay(5000);
    // Turn off the water pump
    digitalWrite(pumpPin, LOW);
  // Wait 2 milliseconds before the next loop for the analog-to-digital
  // converter to settle after the last reading
  delay(2);
Finally, I want to combine the whole code into one Arduino code for to work the whole system. without changing any meaning of the codes... I have tried some ways, but they didn't resolve my problem.. please help me to find the solution
in general, you could just rename our 4 setup() and loop() as setup1(), setup2(), ... and call each in a new setup() and loop() such as
void setup ()
    setup1 ();
    setup2 ();
    setup3 ();
    setup4 ();
of course they don't need to be in separate functions, just the code in each needs to be in setup(), less any redundant code. and similarly for the loop() functions.
give it a try
Well, the first thing I would do is get rid of all those delays and use millis() instead. You have a lot of blocking code.
as already mentioned:
First step is to write 4 "non blocking" codes.
Without any delays or blocking while loops waiting for an event.
As I just spotted a delay to slow down servo movement, ... here I have an short example of a smooth servo:
just in case you were would copy paste any code - please credit the author.
This short hint has a high danger of making it extra hard to understand how non-blocking timing works.
Such a short sentence can create the totally wrong picture of
replace delay() with millis() and you are done.
If this totally wrong picture is created in the head of a newcomer this newcomer will have extra confusion caused by this wrong picture if she/he starts to read this classical blink without delay-example-code from the IDE
This classical blink without delay-example does not:
  • explain the fundamental difference between delay() and non-blocking timing
  • has non-intuitive variable-names
  • where a part of these variables are distributed over multiple lines of code
Trying to understand this bwd-code with a picture in mind "just replace delay() with millis() causes extra-confusion because the code is totally different from "just replace delay() with millis()
In my opinion this BWD-example must be heavily revised or at least no longer recommended to understand how non-blocking timing works.
A much better explanation is this video
Right!
For that step I'd suggest the use of TaskMacros which allow to simply replace blocking delay() by the non-blocking taskDelay(). Make each loop() a distinct task and you're almost done.
I would not attempt to merge the individual files into a single .ino file
have separate .cpp files with associated .h header files containing extern declarations and function prototypes
Hi @foreverknight0416,
your separate sketches do the following (simplified):
Code 1: Gate Control
  • Set the gate to closed (90 degrees)
  • LOOP
    • Checks for a RFID tags
    • In case a new tag was found and it has the targetUID:
      • The gate opens (moves from 90 degrees to 0)
      • The sketch waits for 5 sec
      • The gate closes again
    • goto LOOP
Code 2: Food Dispenser
  • LOOP
    • Move servo to 0 degrees
    • Wait for 60 sec
    • Move servo to 45 degrees
    • Wait for 2 sec
    • goto LOOP
Code 3: Distance Measurement with LED signal
  • LOOP
    • Measure and print distance
    • If distance >= 20 cm switch LED on for 250 ms
    • Else switch LED off
    • Wait for 500 ms
    • goto LOOP
Code 4: Pump Controlled by Water Level
  • LOOP
    • Read and print an anlog value that represents the water level
    • If the sensor value < 280 then switch the pump on for 5 sec
    • goto LOOP
To my understanding:
  • Codes 1 and 4 may generally work as intended.
  • Code 2 does not seem to work properly unless "Food dispensing" is only time controlled.
  • Code 3 does not match its comments.
I might be wrong ...
Can you provide a link to a tutorial that explains that?
I have analysed the traffic-light demo-code. (multiple tasks ehm sorry two tasks).
I have read the macros.
Well I highly doubt that a real beginner will be able to apply the taskmacros for his own code.
You would have to explain the pattern in much more detail than just presenting code.
There are some things you must pay attention to which should be explicitly explained to beginners. Otherwise beginners are in danger to not understand these limiting conditions.
Most important you have to divide your code into multiple sequences
each of these sequences must be in their own function.
For each sequence executing code further down the function is only executed if all more upper taskDelay()'s are over.
Which means if something shall be done non-blocking it must be placed inside its own function because your first function does not execute further down writte code before all upper taskDelay() have their waiting time passed by.
If my explanation is wrong this witnesses that everything is really tricky and needs even more explanation to get it working.
Isn't that just the starting point with the 4 distinct loop()s of the TO? So far it's clear which are the task functions which have to be made non-blocking by using taskDelay() instead of delay().
Are you sure that you want the food dispenser beeing active
24 hours each day 7 days a week?
Which means once every 62 seconds of each day which is 1393 times each day
food will be dispensed.
Here is the code
#include <ALib0.h>
#include <Servo.h>
#include <SPI.h>
// Pin definitions
#define SS_PIN 10
#define RST_PIN 9
Servo myServo1;
// RFID UID
long duration;
int distance;
  setup1();
  setup2();
  setup3();
  setup4();
  loop1();
  loop2();
  loop3();
  loop4();
void setup1() {
  myServo1.attach(8);
  SPI.begin();
  mfrc522.PCD_Init();
void loop1() {
        taskDelay(15);  // Adjust delay for smooth movement
      taskDelay(5000);  // Keep the gate open for 5 seconds
      return false;
  return true;
void setup2() {
void loop2() {
  taskDelay(60000);        // Wait for 2 seconds
  taskDelay(2000);        // Wait for 2 seconds
void setup3() {
void loop3() {
    // Blink the LED
    taskDelay(250);                  // Wait for 250 milliseconds
  taskDelay(500);
void setup4() {
  //Serial.begin(9600);
void loop4() {
    taskDelay(5000);
  taskDelay(2);
and here is the compiler-error-message:
Arduino: 1.8.19 (Windows 10), TD: 1.58, Board: "Arduino Uno"
C:\Arduino-Pure-Portable\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\hardware -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -tools C:\Arduino-Pure-Portable\arduino-1.8.19\tools-builder -tools C:\Arduino-Pure-Portable\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -libraries C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_211490 -warnings=all -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_750915 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino
C:\Arduino-Pure-Portable\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\hardware -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -tools C:\Arduino-Pure-Portable\arduino-1.8.19\tools-builder -tools C:\Arduino-Pure-Portable\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -libraries C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_211490 -warnings=all -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_750915 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino
Using board 'uno' from platform in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o nul
Alternatives for ALib0.h: [ALib0@1.0]
ResolveLibrary(ALib0.h)
  -> candidates: [ALib0@1.0]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o nul
Alternatives for Servo.h: [Servo@1.2.0]
ResolveLibrary(Servo.h)
  -> candidates: [Servo@1.2.0]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o nul
Alternatives for MFRC522.h: [MFRC522@1.4.10]
ResolveLibrary(MFRC522.h)
  -> candidates: [MFRC522@1.4.10]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src\\AButton.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\avr\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\mbed\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\megaavr\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\nrf52\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\renesas\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\sam\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\samd\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src\\stm32f4\\Servo.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src\\MFRC522.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src\\MFRC522Extended.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\ALib0\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Servo\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MFRC522\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_211490\\sketch\\taskMacros-loop1-4-001.ino.cpp.o"
In file included from C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:1:0:
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino: In function 'void loop1()':
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:14:30: error: 'time_Stamp' was not declared in this scope
  #define taskDelay(interval) time_Stamp = millis(); taskSwitch(); if ((millis() - time_Stamp) < (interval)) return;
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:71:9: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:25: error: '_mark' was not declared in this scope
  #define taskSwitch() { _mark = __LINE__; return; case __LINE__: ; }
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:14:53: note: in expansion of macro 'taskSwitch'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '71' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:74:7: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '74' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:79:9: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '79' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino: In function 'void loop2()':
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:107:3: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '107' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:109:3: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '109' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino: In function 'void loop3()':
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:150:5: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '150' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:152:5: note: in expansion of macro 'taskDelay'
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '152' not within a switch statement
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:159:3: note: in expansion of macro 'taskDelay'
   taskDelay(500);
   taskDelay(500);
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '159' not within a switch statement
   taskDelay(500);
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino: In function 'void loop4()':
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:185:5: note: in expansion of macro 'taskDelay'
     taskDelay(5000);
     taskDelay(5000);
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '185' not within a switch statement
     taskDelay(5000);
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\taskMacros-loop1-4-001\taskMacros-loop1-4-001.ino:193:3: note: in expansion of macro 'taskDelay'
   taskDelay(2);
   taskDelay(2);
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0\src/ALib0.h:13:51: error: case label '193' not within a switch statement
   taskDelay(2);
Using library ALib0 at version 1.0 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\ALib0
Using library Servo at version 1.2.0 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\Servo
Using library MFRC522 at version 1.4.10 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MFRC522
Using library SPI at version 1.0 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\libraries\SPI
exit status 1
Error compiling for board Arduino Uno.
And I guess
not really waiting here
  taskDelay(500);
  taskEnd();
before triggering the ultra-sonic sensor might cause trouble
void loop3() {
  taskBegin();
    // Blink the LED
  taskDelay(500);
  taskEnd();
Of course taskDelay() can not be used outside of a task function.
What makes a function a task-function?
So what has to be changed to make it work?
You have seen the example?
Yes. And this means your description
could be more detailed by writing:
At the begin of each task-function which in case of user @foreverknight0416 is the renamed functions loop() to
loop1()
loop2()
loop3()
loop4()
Need a function-call taskBegin(); as the first line
and
a function-call taskEnd(); as the very last line
basic structure:
void loop1() {
  taskBegin();
  // all code that shall be delayed by using taskDelay()
  taskEnd();
} // closing curly brace of void loop1()
So this means beside replacing delay() with taskDelay() the function-calls
taskBegin(); and taskEnd();
must be added to make a function a task-function.
IMHO it would be very good if you add this information in each example-code
But I am pretty sure adding this information is seen as "newcomers won't learn and do just copy & paste if this information is added".
Or maybe "if this information is added it will be too easy for newcomers to climb up the learning curve"
IMHO this forum is for sharing information.
hello Sir, this is a project that we need to demonstrate. Actually, we need to distribute the food once every 6 hours. But for the sake of demonstration, I have made it once in every minute
It sounds like each of the group of you wrote A separate test code for one element of the process. Do you understand that the problem is that delay() is very greedy and prevents sharing the computing with other routines? The solution is to change the codes so they don’t greedily trap the processor within their own code and instead quickly check a clock and if they don’t need to do anything “right now”, pass control of the processor to do the other things.
Here’s a test simulation showing several ways of periodically printing a character, some that share with other routines better than others:
rateLimitingToy.ino code
// Toy for comparing rate limiting schemes
// Wokwi simulation: https://wokwi.com/projects/406476811823126529
// Slide the pot back and forth to change between schemes
// read how many times the code goes through loop() and gets
// a chance to do other things.
// See https://forum.arduino.cc/t/best-first-5-topics-to-read-to-reach-trust-level-1/1287592
// in particular the
//  https://forum.arduino.cc/t/demonstration-code-for-several-things-at-the-same-time/217158
// attach a potentiometer wiper pin to A0/modePin and the potentiometer extremes to GND and +
const byte modePin = A0;
const unsigned long delayIntervalMs = 30; //
int choice = 0;
unsigned long currentMillis;
  Serial.begin(115200); // Baud rate can limit loop speed too.
  // Try 115200 vs 9600 vs 300 to see baud rate effects
  Serial.print("rateLimitingToy -- https://wokwi.com/projects/406476811823126529\n"
  "Slide the pot to change between modes:\n"
  "while(..); , delay(), millis()/BWOD, unlimited\n"
  Input(); // Read sensors //  Input of IPO programming model https://en.wikipedia.org/wiki/IPO_model
  // Processing
  switch (choice) { // choose a method of rate limiting to use for this cycle of loop()
    case 0: // stop while(waiting for something to end)
      Serial.print("while(something);");
      while (analogRead(modePin) / 256 == 0) {
      Serial.print("...done\n");
      report();
    case 1: // slow down iterations with delay()
      Serial.print("d");
      delay(delayIntervalMs);
    case 2: // rate limited by testing time
      rateLimitedThing();
    case 3: // unlimited
      Serial.print("u");
    default:
      Serial.print("unexpected choice value");
      Serial.println(choice);
  // Output
  report(); // count loop() cycles/second and print
void rateLimitedThing() {
  // Check the millis() clock to see if it is time to do a Thing.
  const unsigned long interval = delayIntervalMs;
  static unsigned long lastMs = 0;
  unsigned long now = millis();
  if (now - lastMs >= interval) {
    lastMs = now; // or lastMs += interval;
    Serial.print("r");
void Input() { // Input of the IPO model https://en.wikipedia.org/wiki/IPO_model
  // this separates the input from the other bits of the program so the rest of it is
  // all working with the same data
  //This rate-limits the analogRead because we don't need to respond instantly
  const unsigned long interval = 50;
  currentMillis = millis();
  if (currentMillis - lastMs >= interval) {
    lastMs = currentMillis; // or lastMs += interval;
    choice = analogRead(modePin) / 256; // recode range as 0-3
void report() {
  // this routine cooperatively counts how many opportunities it
  // was given to run in a second
  static unsigned long loopcount = 0; // remember count
  const unsigned long interval = 1000;
  if (now - lastMs >= interval) { //
    Serial.print("\nLoopCount: ");
    Serial.print(loopcount);
    Serial.print("/sec\n");
    loopcount = 0;
  ++loopcount; // count this cycle
To be clear: If you write your codes to cooperate and share processor time, (like the rateLimitedThing() and report() in that toy, they are easier to combine into a single system.
