HB-25 Motor: Fwd. & Rev. Functionality
Greetings!
Recently, I have been working on a robotics project that involves the use of an HB-25 Parallax Motor Controller. The specifications for this component can be found here.
The main problem I have been running into is the inability to reverse the polarity of the controller.
In order for my robot to function properly, I require the ability to spin the motor forward and reverse, via the controller. The following video shows a successful attempt at programming the Arduino for this functionality:
The HB-25 and Arduino - drbrono
Please note that the HB-25 is being used due to the 6-volt requirement of the DC motor I am using.
Does anyone have the code that would make this work, or would know how to write a program for this task?
I have search countless hours for a solution, but to no avail.
Thank you! :smiley:
EDIT:
Attached, you will find a circuit diagram and the current program I was testing today.
Please note that the following in the image correspond with each other:
  • OUT 1A corresponds with M1 on the HB-25 spec
  • OUT 1B corresponds with M2
  • GND (-) on the right corresponds with the Servo Ground
  • VIN (+) on the right corresponds with the "R", labeled "Not Connected" on the spec
  • OUT 2A corresponds with the Servo pulse input
  • +5V (IN) on the left corresponds with the 6V input from the external battery to the HB-25
  • The black wire from the battery represents ground
Feb06DCMotorTest.ino (1.83 KB)
Can you please post a copy of your sketch, using code tags?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
http://forum.arduino.cc/index.php?topic=187545.0
That will help us answer your questions.
Tom..... :slight_smile:
Hello Tom,
Thank you for the response. I will prepare the necessary items. :slight_smile:
Thank you!
First line of the key features in the link you provided........
Pulse Input: 1.0ms Full Reverse, 1.5ms Neutral (off), 2.0ms Full Forward
Looks like the controller takes a servo signal. Try the servo library that comes with the IDE.
bluejets:
Hello,
Please note that I am new to working with Arduino programming. I am fully aware of the specs, and I have tried multiple methods for the HB-25 controller, including writeMicroseconds(), which did not work. This caused the motors to constantly pulse at a high rate, rather than move in a clockwise/counterclockwise motion. There was practically no motion.
Thank you.
groundfungus:
Thank you for your response! I have already tried that, but it has not worked. I will share the code I have written shortly, along with the circuit's setup.
TomGeorge:
HB-25 Motor Controller will not work - Motors, Mechanics, Power and CNC - Arduino Forum
Hello again, Tom. I have added the sketch code and a diagram of the circuit. Please reference the bullet points I added with regards to what corresponds with what on the HB-25. :slight_smile:
Sane pulse duration as used by servos. Basic servo test code you can use for testing. Try sending values between 45 and 135 from the serial monitor. This uses pin 9 for the servo signal.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.attach(9);
  Serial.println("servo-test"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the String readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured String
    int n = readString.toInt();  //convert readString into a number
    myservo.write(n);
    readString="";
zoomkat:
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
  myservo.attach(9);
    myservo.write(n);
    readString="";
Thank you for your assistance! I will have to test out the code tomorrow. I will make an additional reply and/or edit this post if it works.
Thanks again. :slight_smile:
Hi, when you add information, can you do it in a new message, editing an old message can confuse anyone who has just read the thread.
Your "diag" is a fritzy which is not a circuit diagram, the board in the diag is not the controller.
Please a picture of your project, and a pic of a hand drawn circuit if possible, showing how you have connected the three wires from the arduino to the driver connector.
Tom... :slight_smile:
TomGeorge:
Sorry about that, I will take note of that for next time. I will see to taking a picture when I'm in the shop. :slight_smile:
Thanks to the basic Servo code that zoomkat provided, I was able to get the motors working!
I first ran some tests by sending input through the Serial Monitor, then I used the same logic to expand my program.
Thank you to all who helped, and a very special thank you to zoomkat! :slight_smile:
Hi, good to hear, did you get your code to work as well and what did you find?
TomGeorge:
Hello,
Yes, I got the code to work by replacing all of the digitalWrite() methods with <servo_name>.write() and entering integer values to control direction and speed.
The following are the results I gathered for integer values entered in the .write():
Clockwise:
50 - max speed
60
70
80 - low speed
Counter-clockwise:
135 - max speed
125
115
105 - low speed
stop:
0
