THE PROBLEM:
Somehow I can't find any working code or sketch for the Yun to program (or pair) the HC-05... Also the IDE of the Yun seems to be not supported... (Would be great if we could solve this issue with a Mac, but I can use a PC too, if necessary)
What I want to do:
I bought two HC-05 Bluetooth-Modules (presoldered) and want to use them to connect two arduinos (YUN with UNO r3).
The UNO shall measure temperature data and send it over to the YUN ( I need the temperature as a variable on the yun).
Here are some websites I already was looking into, but non helped... seems like nobody ever tried to make Bluetooth work on the Yun ...
http://forum.arduino.cc/index.php/topic,177125.0.html
http://forum.arduino.cc/index.php?topic=212373.0
http://arduino-hannover.de/2013/07/20/bluetooth-kochbuch-fur-arduino/#more-267
I currently connected the HC-05 with the Yun this way
(and my Mac already paired with it once, but now the module is only blinking fastly):
[HC-05] : [YUN]
VCC : 3,3 V
GND : GND
TXD : RX
RXD : TX
I currently didn't connect KEY and LED/STATE with the Yun,
as I first wanted to look for a sketch and a solution for the IDE-Problem
and I'm not sure if they need to be connected all the time (or only during programming)
