So im using a newping example code to get 4 sensors running. My issue is, Whenever something is within lets say 40cm, I want it to turn on led 1 and 2 and do a tone,
Heres the code so far
#include <NewPing.h>
#define led1 11 //Right LED
#define led2 10 // Left LED
#define SONAR_NUM 4 // Number or sensors.
#define MAX_DISTANCE 20 // Max distance in cm.
#define PING_INTERVAL 33 // Milliseconds between pings.
unsigned long pingTimer[SONAR_NUM]; // When each pings.
unsigned int cm[SONAR_NUM]; // Store ping distances.
uint8_t currentSensor = 0; // Which sensor is active.
NewPing sonar[SONAR_NUM] = { // Sensor object array.
NewPing(13, 12, MAX_DISTANCE),
NewPing(9, 8, MAX_DISTANCE),
NewPing(7, 6, MAX_DISTANCE),
NewPing(5, 4, MAX_DISTANCE),
pingTimer[0] = millis() + 75; // First ping start in ms.
for (uint8_t i = 1; i < SONAR_NUM; i++)
pingTimer[i] = pingTimer[i - 1] + PING_INTERVAL;
for (uint8_t i = 0; i < SONAR_NUM; i++) {
if (millis() >= pingTimer[i]) {
pingTimer[i] += PING_INTERVAL * SONAR_NUM;
if (i == 0 && currentSensor == SONAR_NUM - 1)
oneSensorCycle(); // Do something with results.
sonar[currentSensor].timer_stop();
currentSensor = i;
cm[currentSensor] = 0;
sonar[currentSensor].ping_timer(echoCheck);
// The rest of your code would go here.
void echoCheck() { // If ping echo, set distance to array.
if (sonar[currentSensor].check_timer())
cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
void oneSensorCycle() { // Do something with the results.
Serial.print(i);
Serial.print("=");
Serial.print(cm[i]);
Serial.print("cm ");
So my question is, what the heck do I do, Ive tried an if statement with a few different things and I just can't get it to work.
