Hi people,
I'm having a small issue regarding an HC-SR04 sensor. When converting my data to MIDI CC, it comes up correct in Hairless MIDI, but with every read, there is a "0" reading as well.
Below is the written code and a screenshot from Hairless MIDI. Any help would be much appreciated!
#include <MIDI.h>
#include <NewPing.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#define SONAR_NUM 2 // Number of sensors.
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
NewPing sonar[SONAR_NUM] = { // Sensor object array.
NewPing(A0, A1, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
NewPing(A2, A3, MAX_DISTANCE)
int midiCState = 0;
int midiPState = 0;
int sonarCState = 0;
int sonarPState = 0;
int sonarVar = 5;
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through each sensor and display results.
delay(100); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
sonarCState = sonar[i].ping_cm();
midiCState = map(sonarCState, 0, 200, 0, 127);
sonarVar = abs(sonarCState - sonarPState);
if (sonarVar > 5) {
if (midiPState != midiCState) {
MIDI.sendControlChange (1, midiCState, 1);
midiPState = midiCState;
sonarPState = sonarCState;
