HC-SR04 Ultrasonic Sensor Parking Sensor With LCD Display
Hello
I am working on a project for creating a car parking sensor. I have set up a project in which the LCD will detect the distance between the object and the sensor and print it on an LCD. However when an object is too close (less than 2cm), the LCD will print random numbers above 3000cm. This also happens when the object is out of range.
I have posted my code below, can anyone help me amend this.
Any help will be much appreciated :slight_smile:
#include <NewPing.h>
#include <LiquidCrystal.h>
LiquidCrystal LCD(12, 11, 5, 4, 3, 2); //create lcd object
#define trigPin 7 //Sensor Trip to pin 7
#define echoPin 6 //sensor echo to pin 6
int maximumRange = 20; //Maximum range needed
int minimumRange = 0; //Minimum range needed
long duration, distance;
byte customChar[8] = {
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
LCD.begin(16,2);// start 16 column 2 row
LCD.setCursor(0,0); // LCD cursor to top left
LCD.print("Distance:"); //Print message to first row
digitalWrite(trigPin, LOW); //set triger pin low
delayMicroseconds(2); // let signal settle
digitalWrite(trigPin, HIGH);//set trigpin high
delayMicroseconds(15); // delay in high state
digitalWrite(trigPin, LOW); //ping has now been sent
delayMicroseconds(10); // Delay in high state
duration = pulseIn(echoPin, HIGH); //duration in microseconds
distance = duration/58.2;
Serial.print (distance);
LCD.setCursor(10,0); //set cursor to first column of second row
LCD.print(" "); //prints blanks to clear the row
LCD.setCursor(10,0); //Set Cursor again to first column of second row
LCD.print(distance); //print distance
LCD.print("cm");// units
delay(250); //pause
if (distance<64)
// create a new custom character
LCD.createChar(0, customChar);
// set up number of columns and rows
LCD.setCursor(0, 1);
// print the custom char to the lcd
LCD.write((uint8_t)0);
LCD.setCursor(0,1);
LCD.print(" ");
if (distance<60)
LCD.setCursor(1, 1);
LCD.setCursor(1,1);
LCD.print(" ");
if (distance<56)
LCD.setCursor(2, 1);
LCD.setCursor(2,1);
LCD.print(" ");
if (distance<52)
LCD.setCursor(3, 1);
// why typecast? see: http://arduino.cc/forum/index.php?topic=74666.0
LCD.setCursor(3,1);
LCD.print(" ");
if (distance<48)
LCD.setCursor(4, 1);
LCD.setCursor(4,1);
LCD.print(" ");
if (distance<44)
LCD.setCursor(5, 1);
LCD.setCursor(5,1);
LCD.print(" ");
if (distance<40)
LCD.setCursor(6, 1);
LCD.setCursor(6,1);
LCD.print(" ");
if (distance<36)
LCD.setCursor(7, 1);
LCD.setCursor(7,1);
LCD.print(" ");
if (distance<32)
LCD.setCursor(8, 1);
LCD.setCursor(8,1);
LCD.print(" ");
if (distance<28)
LCD.setCursor(9, 1);
LCD.setCursor(9,1);
LCD.print(" ");
if (distance<24)
LCD.setCursor(10, 1);
LCD.setCursor(10,1);
LCD.print(" ");
if (distance<20)
LCD.setCursor(11, 1);
LCD.setCursor(11,1);
LCD.print(" ");
if (distance<16)
LCD.setCursor(12, 1);
LCD.setCursor(12,1);
LCD.print(" ");
if (distance<12)
LCD.setCursor(13, 1);
LCD.setCursor(13,1);
LCD.print(" ");
if (distance<8)
LCD.setCursor(14, 1);
LCD.setCursor(14,1);
LCD.print(" ");
Use code tags to post your code (makes it much easier to read). I would suspect (since you don't say what sensor you are using) that you are under the minimum distance for the sensor to work. If the outgoing pulse is still being sent when the echo comes back, you don't get a valid detect so it appears to be "not there"
gpsmikey:
That's true.
I'm assuming that you're using the sr04 since your thread heading says that you're using an HC-Sr04.
That sensor has a working envelope of 3cm - 400cm. Check the datasheets.
So any objects closer/beyond those distances will give off erroneous readings.
