HC-SR04 Ultrasonic sensor with DMX shield to control a spotlight
Hi!
I'm creating an interactive art installation but I'm not a programmer, so I need help. I have to use an HC-SR04 ultrasonic sensor to control a spotlight.
I tried the ultrasonic sensor without the spotlight and it works.
I bought a DMX shield (CQRobot DMX Shield MAX485) to control the spotlight with my Arduino Uno, I used the DMX library without the ultrasonic sensor, which works too.
Now I have to use them together, but I don't know how to write the code. When I tried to unite the code of the ultrasonic sensor and the DMX one, there was this error:
HardwareSerial0.cpp.o (symbol from plugin): In function Serial': (.text+0x0): multiple definition of __vector_18'
C:\Users\giada\AppData\Local\Temp\arduino\sketches\56EE4BF8C1043E7874A58BAAA57B454D\libraries\Conceptinetics\Conceptinetics.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
It seems that serial is the problem. I've tried not to write the serial, but obviously it didn't work. Can anyone help me?
This is my code at this moment:
#include <Conceptinetics.h>
const int echo = 13;
const int trig = 12;
const int LED1 = 3;
const int LED2 = 2;
int duration = 0;
int distance = 0;
DMX_Master dmx_master(4,1);
// the setup routine runs once when you press reset:
  pinMode (trig, OUTPUT);
  pinMode (echo, INPUT);
  dmx_master.enable();
 //Serial.begin(9600);
digitalWrite (trig, HIGH);
delayMicroseconds (10000);
digitalWrite (trig, LOW);
duration = pulseIn(echo, HIGH);
distance = (duration/2) / 28.5;
//Serial.println(distance);
// dmx_master.setChannelValue(1,255);
if (distance <= 6)
  dmx_master.setChannelValue(2,255); // Rosso
  dmx_master.setChannelValue(3,0); // Verde
  dmx_master.setChannelValue(4,0); // Blu
  dmx_master.setChannelValue(2,0); // Rosso
  dmx_master.setChannelValue(3,255); // Verde
DMX_Master dmx_master(4, 2);
  dmx_master.setChannelValue(4, 0); // Blu
  dmx_master.setChannelValue(1, 255);
  static long duration = 0;
  delayMicroseconds (2);
  delayMicroseconds (5);
  int distance = duration / 57;
  if (distance <= 6)
    dmx_master.setChannelValue(2, 255); // Rosso
    dmx_master.setChannelValue(3, 0); // Verde
    dmx_master.setChannelValue(2, 0); // Rosso
    dmx_master.setChannelValue(3, 255); // Verde
don't use pins 0 and 1, they need for DMX.
Enable pin is now 2
Hi! I've used your code and it works. Thanks!
Now I have another problem. The spotlight has to work in this way:
when no one is in the range of the ultrasensor, the intensity of the light has to be 20. Then, when someone is in the range of the ultrasensor, the intensity of the light has to be 90. I also need a fade from 20 to 100. And, of course, when someone stands in the range, the intensity of 100 has to remain.
The problem is that now, when I use my code, at first the light is off, when someone is in the range it lights on, and then it remains on. I don't know why.
This is my code:
int i = 20;
  if (distance <= 100 && i == 20) // se l'oggetto e' sotto i 200mt e la luce NON e' gia' al massimo, cioe' 100...
  { // FADE IN
    for (i = 20; i <= 100; i++) {
      // se non funziona, commenta da qui...
      if(i <= 90) {
        dmx_master.setChannelRange(1,4,i); // Brightness has to be max 90
        dmx_master.setChannelRange(2,4,i); // RGB channels are max 100
      delay(10);
      // ...a qui
      e decommenta questo
      dmx_master.setChannelValue(2, i); // Rosso
      dmx_master.setChannelValue(3, i); // Verde
      dmx_master.setChannelValue(4, i); // Blu
      if(i <= 90) {
        dmx_master.setChannelValue(1, i); // luminosita
  else // se l'oggetto e' piu' lontano di 200mt e la luce e' gia' al massimo...
  { // FADE OUT
    if (distance > 100 && i == 100) { // se nessuno e' ancora passato davanti al sensore (i == 20), l'intensita' NON va sfumata
      for (i = 100; i >= 20; i--) {
        if(i <= 90){
          dmx_master.setChannelRange(1,4,i); // It fades brightness ch too (1) because it starts from 90
          dmx_master.setChannelRange(2,4,i); // RGB channels start from 100
        delay(10);
        // ...a qui
        e decommenta questo
        if(i <= 90){
          dmx_master.setChannelValue(1, 0);
bc of this
better so
  if (distance > 100 && i > 20)
Ok, now it lights off, but then it doesn't light on again.
Anyway, there's also the problem that it doesn't have to switch on/off, but it has to change the intensity from 20 to 90.
  static int distance = 0;
  static bool isDimmed = true;
  if (duration)distance = duration / 57;
  if (isDimmed) {
    if (distance <= 100) // se l'oggetto e' sotto i 200mt e la luce NON e' gia' al massimo, cioe' 100...
    { // FADE IN
      for (byte i = 20; i <= 100; i++) {
        if (i <= 90)dmx_master.setChannelRange(1, 4, i); // Brightness has to be max 90
        else dmx_master.setChannelRange(2, 4, i); // RGB channels are max 100
        delay(10);
      isDimmed = false;
  { // FADE OUT
    if (distance > 100 ) { // se nessuno e' ancora passato davanti al sensore (i == 20), l'intensita' NON va sfumata
      for (byte i = 100; i >= 20; i--) {// se non funziona, commenta da qui...
        if (i > 90)dmx_master.setChannelRange(2, 4, i); // RGB channels start from 100
        else dmx_master.setChannelRange(1, 4, i); // It fades brightness ch too (1) because it starts from 90
        delay(10);
    isDimmed = true;
There's an error:
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino:4:1: error: 'DMX_Master' does not name a type
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino: In function 'void setup()':
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino:9:3: error: 'dmx_master' was not declared in this scope
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino: In function 'void loop()':
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino:29:21: error: 'dmx_master' was not declared in this scope
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino:30:14: error: 'dmx_master' was not declared in this scope
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino:40:20: error: 'dmx_master' was not declared in this scope
C:\Users\giada\AppData\Local\Temp.arduinoIDE-unsaved202485-2192-1ii95ui.a6ee\sketch_sep5a\sketch_sep5a.ino:41:14: error: 'dmx_master' was not declared in this scope
exit status 1
Compilation error: 'DMX_Master' does not name a type
you forgot
