HC-SR04P (NOT HC-SR04) Ultrasonic Sensor Distance Return Zero
I having issue when using HC-SR04P (not HC-SR04)
The sensor will always return 0 then the true distance.
Below is the code:
#define echoPin 7
#define trigPin A2
// defines variables
long duration; // variable for the duration of sound wave travel
int distance; // variable for the distance measurement
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an OUTPUT
  pinMode(echoPin, INPUT);
  // Clears the trigPin condition
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin HIGH (ACTIVE) for 10 microseconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
  // Displays the distance on the Serial Monitor
  Serial.print("Distance: ");
  Serial.print(distance);
  Serial.println(" cm");
Below is the output:
10:46:42.344 -> Distance: 8 cm
10:46:43.020 -> Distance: 0 cm
10:46:43.020 -> Distance: 8 cm
10:46:43.687 -> Distance: 0 cm
10:46:43.731 -> Distance: 8 cm
10:46:44.412 -> Distance: 0 cm
10:46:44.412 -> Distance: 8 cm
10:46:45.100 -> Distance: 0 cm
10:46:45.100 -> Distance: 8 cm
10:46:45.804 -> Distance: 0 cm
10:46:45.804 -> Distance: 8 cm
10:46:46.501 -> Distance: 0 cm
By looking at the documentation, you seem to be hitting the sensor way to often. Try waiting for a second or longer before triggering again.
Hi, thanks for the reply.
But one second is too long for me as I'm trying to detect objects in front while it was moving. :sweat_smile:
It might be wise to try a delay of x time. I'd start with delay(10) and work up from there till a good delay time has been reached.
A delay using millis() would not stop the rest of loop() from running.
unsigned long sr04Interval = 10;
unsigned long pastsro4Time;
if( (millis() - pastsro4Time) >= sro4Interval )
  pastsro4Time = millis();
} //if( (millis() - pastsro4Time) >= sro4Interval )
distance=0; // something to do when not pinging
something like that, not tested.
the op might want to consider setting a timeout value for pulse in of less than a second pulseIn(pin, value, timeout)
The OP might consider the mixed data types used to determine distance and the possibility of error introduction.
Here the OP declares int distance; // variable for the distance measurement an int.
Here the OP declared long duration; a long int.
Here the OP does mixed data type math distance = duration * 0.034 / 2; The OP might benefit from making distance into a float and doing distance = (float)duration * 0.034 / 2.0;
