Hc05 Bluetooth communication got 2 second delay
Hi All
I havent touch arduino for ages but im back at it again, giving me problems :rofl:, i got two arduinos, got 64 inputs on one arduino so my data to send will be from 1 to 64 bytes?, and then 64 outputs on the other arduino, anyway im just on breadboard now testing the hc 05 module when i serial write a 1 the other arduino takes about 2 seconds to respond, ive never really work with serial or bluetooth so not sure what the right way is to code it?
Please any help?
Thanks
int state = 0;
const int ledPin = 6;
const int buttonPin = 13;
int buttonState = 1;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  pinMode(buttonPin, INPUT);
  digitalWrite(buttonPin, HIGH);
 buttonState = digitalRead(buttonPin);
 if (buttonState == LOW)
  Serial.write('1');
  digitalWrite(ledPin, HIGH);
  Serial.write('0');
delay(10);
int incomingByte = 0; // for incoming serial data
const int led = 4;
Serial.begin(115200); // opens serial port, sets data rate to 9600 bps
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
// reply only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
//Serial.print(incomingByte);
if (incomingByte == '1')
digitalWrite(led, HIGH); // LED ON
else if (incomingByte == '0')
digitalWrite(led, LOW); // LED ON
delay(10);
You're sending furiously.
(And you should use Software Serial.)
Compose your loop() to send a '1', delay(1000), send a '0', delay(1000)
or delay(500),
See how that goes (no pushbutton stuff for now).
Try INPUT_PULLUP instead and wire the button between buttonPin and GND. A pressed button give a low in reading it.
Hey, how about reading the instructions then? :thinking:
No, 64 bits or 8 bytes.
Bluetooth has some latency (delay) in transmission. You just have to live with it.
Clearly not true.
Have you actually configured Bluetooth to operate at 115200?
