I just started using the Lilypad. I have hooked up my Arduino Diecimilia before and gotten the "hello world" (blink) code running perfectly. However, I have tried a million times to get the Lilypad to do the same thing and it won't.
I have the Lilypad Arduino setup with the Sparkfun Lilypad USB link. GND to GND, RX to RX, TX to TX, + to +. I have tried with and without an additional power source. Everytime I try to upload even the simpliest code it responds:
I have no idea what this means or how to fix it. I saw a bunch of stuff about the bootloader, but I'd need a lot of help on how to do this.
I have already tried this too, several times. I have reset then tried to upload, hold reset and clicked upload and released when the led blinks.... still the same message... I have two lilypad board, and two USB links, I have tried them in all combinations with no luck.
I am using Arduino 00012 and a MacBook Pro running Mac OSX 10.4.
try hitting the reset button over & over quickly as your program is being uploaded. Try this a few times, with slightly different timings. Post back here w/ results, am curious to hear.
If it consistently requires reset acrobatics to get your program to load, or if you never get your program to load you should get in touch w/ Sparkfun. This is probably a bootloader issue...
I'm having the same problem as fmmw. I've got a G5 tower running OS X 10.5.5 and the Lilypad is a 6 pin board with USB link. I've tried all of the suggestions mentioned and nothing has worked. I've contacted Spark Fun, but I thought I would see if anyone else had an idea in the meantime. Thanks everybody.
If you have one of the newest 6pin LilyPads, you need the 6 pin basic FTDI board to program it. The LilyPad USB Link won't work.
We're making this change so that the LilyPad will be compatible with most other Arduinos. Sorry for any confusion this transition causes! Sparkfun may be able to help. Contact them with your problem & I believe they will be happy to swap your USB Link for an basic FTDI board.
I've tried using the reset button to upload in many different ways with no luck.
I have both a 4-pin and a 6-pin Lilypad. I also have 2 different USB links, one is the Arduino USB link and the other is the Sparkfun USB link for the Lilypad. I've tried all combinations of this with no luck, along with the reset, along with trying an outside power supply. Still no luck. But my Decemilia works fine...
When I plug the lilypad into the computer, the light comes on and the USB link lights blink.
