I have very little knowledge about arduino and electronics generally. I have 5v addressable rgb fans and they are controlled by its own box.
You can connect the box to motherboard if motherboard has 5v argb port and press the mb sync button to control lights but my motherboard doesn't have that.
So i tought if i can plug ardunio to my computer and box's sync cable to ardunio and program it. Vdg cable is for gigabyte motherboards and only D(data) cable is conected. Control box is plugged to pc power supply unit via molex cable do i need to ground ardunio too ?
System will look like this is this doable ?
If you want help you need to help people in the forum to help you. Please read the following post on how to post in this forum.
https://forum.arduino.cc/index.php?topic=148850.0
Make sure images are visible inside the post. People do not like to download stuff if not necessary. You need to modify the post after you uploaded the images so you can embed the link and the image will appear inside the post.
Also structure your post so people can see what you have done and what questions you have. There are many helpful people here, but they help faster and more often when the questions are clear and necessary information is available e.g. by using code tags, linking data sheets, embedding images, clear subject line ...
The Arduino can easily be used to replicate IR remote controller signals, using the IRRemote library, and could also replicate signals on a 5V control cable.
The latter requires careful study of the device documentation and advanced programming skills.
cengo12:
Did you bother Googling?
https://www.akison.com/2019/03/arduino-argb-computer-case-controller/
ieee488:
I saw this in the first place but i couldnt understand it.
jremington:
I was thinking using fastled library since arduino acts like motherboard i don't need remote. Can i use fastled
What would you use "fastled" for?
To control lights of fans and maybe i can add ws2812b led strips later
Maybe the following video could be useful for you. Its almost an hour long but seems to have a lot of information about ARGB and Arduino.
Arduino ARGB Corsair Lighting Protocol Corsair Lighting Node Pro Corsair iCUE
