Hello dear Arduino community!
I'm working on a science project that requires a 3d-printed gear to turn when a sensor box looks up at the sky and then turns the gear back the way it came when it looks at or below the horizon (kept simple and vague for the purposes of the arduino-focused situation).
Board: Nano 33 BLE Sense
Servo: Hitec HS-318 (not continuous rotation)
Degree of movement: from 0 (start) to 65 degrees (when box is tilted up) and then back to 0 (when box is pointing at or below the horizon).
Level of experience: beginner/intermediate (limited arduino programming, lots of hardware experience)
The Nano 33 BLE Sense was chosen to substitute our cheap, sensorless Nanos that don't work due to unfortunate software/firmware compatibility issues...
Anyways, our hope is that the accelerometer/gyro (LSM9DS1) will suffice.
After many hours of trying to cobble together some code based on forums and blog posts, I produced the code below. At first I tried IF/ELSE IF statements, but that didn't seem to work well, so I tried IF &&, then finally ended up with the Boolean "switch" since the IF statements did not work properly (servo would react to tilt-up, but then would immediately revert back to original position without the device being tilted below the stated threshold).
#include <Arduino_LSM9DS1.h>
#include <Servo.h>
Servo myservo;
int pos = 0;
bool diffuser = false;
while (!Serial);
Serial.println("Started");
myservo.attach(PIN_A6);
myservo.write(0)
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.accelerationSampleRate());
Serial.println(" Hz");
Serial.println("Acceleration in G's");
Serial.println("XtYtZ");
float x, y, z, delta = 0.35;
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(x, y, z);
Serial.print(x);
Serial.print('\t');
Serial.print(y);
Serial.print('\t');
Serial.println(z);
if ((x >= delta) && (diffuser = false)){
//for (pos = 0; pos == 65; pos += 1) {
myservo.write(65);
diffuser = !diffuser;
Serial.println(diffuser); // for the sake of identifying whether or not the boolean value changes (no luck)
delay(1000);} // arbitrary value - up for suggestions
else if ((x < delta) && (diffuser = !diffuser)) {
//for (pos = 65; pos == 0; pos -= 1) {
myservo.write(0);
delay(1000);}
else delay(1000);
delay(3000);
Since I'm unfamiliar with servo actuation and the servo position for loop, I decided to try the more direct route with the servo.write function, but that didn't work either.
Any and all help would be much appreciated
I thought this would be straightforward and simple, but I'm having such a hard time getting accelerometer data to actuate a servo... I'm hoping there will be a quick fix and a beautiful "aha!" moment.
Thanks for your time and support!
- bobthebobster
