Hello guys, can anyone help me about additional 8 relay without delay in my code. The relay activates alternately every few minutes.
This my code :
#include <Arduino.h>
#include <ModbusMaster.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include "Update.h"
#include <ThingsBoard.h>
#define PIN_RS485_TXEN 5 // D5
#define PIN_WATER_PUMP 4 // D4
#define TIMER_SEND_DATA_INTERVAL 2000
#define SOIL_MOISTURE_THRESHOLD_LOW 50.0f
#define SOIL_MOISTURE_THRESHOLD_HIGH 80.0f
/*const int relay1 = 34; //Output Relay 1 ke Arnuino Pin D0
const int relay2 = 35; //Output Relay 2 ke Arnuino Pin D1
const int relay3 = 32; //Output Relay 3 ke Arnuino Pin D2
const int relay4 = 33; //Output Relay 4 ke Arnuino Pin D3
const int relay5 = 25; //Output Relay 5 ke Arnuino Pin D4
const int relay6 = 26; //Output Relay 6 ke Arnuino Pin D5
const int relay7 = 27; //Output Relay 7 ke Arnuino Pin D6
const int relay8 = 14; //Output Relay 8 ke Arnuino Pin D7*/
constexpr uint16_t MAX_MESSAGE_SIZE = 128U;
constexpr char WIFI_SSID[] = "....";
constexpr char WIFI_PASSWORD[] = "....";
constexpr char THINGSBOARD_SERVER[] = "....";
constexpr char THINGSBOARD_TOKEN[] = "....";
constexpr uint16_t THINGSBOARD_PORT = 80U;
constexpr char TEMPERATURE_KEY[] = "temperature";
constexpr char HUMIDITY_KEY[] = "moisture";
ModbusMaster mbus;
WiFiClient espClient;
ThingsBoard tb(espClient);
void preTransmission()
digitalWrite(PIN_RS485_TXEN, HIGH);
void postTransmission()
digitalWrite(PIN_RS485_TXEN, LOW);
void OnReadSensor()
uint8_t result = mbus.readHoldingRegisters(0x00, 8);
if (result == mbus.ku8MBSuccess)
digitalWrite(LED_BUILTIN, HIGH);
// printf("Data: ");
// for (int i=0; i<8; i++)
// Serial.printf("%d ", mbus.getResponseBuffer(i));
// Serial.println();
int nData0 = mbus.getResponseBuffer(0);
int nData1 = mbus.getResponseBuffer(1);
float fSoilMoisture = (float(mbus.getResponseBuffer(2))/10.0f);
float fTemperature = (float(mbus.getResponseBuffer(3))/10.0f);
Serial.printf("SoilSensor Data: %d %d Moisture: %2.1f %% Temp: %2.1f C\r\n",
nData0, nData1, fSoilMoisture, fTemperature);
if (tb.connected())
Serial.println("Sending data to thingsboard");
tb.sendTelemetryData("Temperature", fTemperature);
tb.sendTelemetryData("SoilMoisture", fSoilMoisture);
Serial.println("Thingsboard not connected");
if (fSoilMoisture<=SOIL_MOISTURE_THRESHOLD_LOW)
Serial.println("Soil moisture is low, turn on water pump");
if (fSoilMoisture>=SOIL_MOISTURE_THRESHOLD_HIGH)
Serial.println("Soil moisture is high, turn off water pump");
digitalWrite(LED_BUILTIN, LOW);
Serial.printf("Read failed, result: 0x%02X\r\n", result);
Serial2.begin(9600);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(PIN_RS485_TXEN, OUTPUT);
pinMode(PIN_WATER_PUMP, OUTPUT);
digitalWrite(PIN_WATER_PUMP, LOW);
mbus.begin(1, Serial2);
// pakai ini jika modul RS585 bukan mode AutoDirection (memiliki pin DE dan RE)
mbus.preTransmission(preTransmission);
mbus.postTransmission(postTransmission);
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("WiFi Connection Failed! Rebooting...");
delay(4500);
ESP.restart();
Serial.print("System connected with IP Address: ");
if (tb.connect(THINGSBOARD_SERVER, THINGSBOARD_TOKEN)){
Serial.println("Connected to thingsboard.");
Serial.println("Failed to connect thingsBoard");
unsigned long lastMillis = 0;
unsigned long nNow = millis();
if (nNow-lastMillis >= TIMER_SEND_DATA_INTERVAL)
lastMillis = nNow;
OnReadSensor();
tb.loop();
I used platformIO to code and run it.
