Code Here:
// constants won't change. Used here to set a pin number:
const int ledPin = LED_BUILTIN; // the number of the LED pin
const int relay_1 = 2;
const int relay_2 = 3;
const int relay_3 = 4;
const int relay_4 = 5;
#include <EEPROM.h>
#include <DHT.h>
#define DHTPIN 12 // Pin connected to the DHT11 sensor
#define DHTTYPE DHT22 // DHT11 sensor model
DHT dht(DHTPIN, DHTTYPE);
int addr = 0; //set address
#define BUTTON_PIN1 8//push button
#define BUTTON_PIN2 9//push button
#define BUTTON_PIN3 10//push button
#define BUTTON_PIN4 11//push button
// Variables will change:
int ledState = HIGH; // ledState used to set the LED
int relayState_1 = LOW; // ledState used to set the LED
int relayState_2 = LOW; // ledState used to set the LED
int relayState_3 = LOW; // ledState used to set the LED
int relayState_4 = LOW; // ledState used to set the LED
int relay_selector = 1;
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis_1 = 0; // will store last time LED was updated
unsigned long previousMillis_2 = 0; // will store last time LED was updated
unsigned long previousMillis_3 = 0; // will store last time LED was updated
unsigned long previousMillis_4 = 0; // will store last time LED was updated
unsigned long previousMillis_temp_record = 0; //will store last time temp was recorded
// constants won't change:
// const long interval_1_Run = 20000; // interval at which to blink (milliseconds)
//20000
//36000000
long interval_1_Run = 3000; // interval at which to blink (milliseconds)
long interval_1_Wait = 18000000; // interval at which to blink (milliseconds)
long interval_2_Run = 3000; // interval at which to blink (milliseconds)
long interval_2_Wait = 18000000; // interval at which to blink (milliseconds)
long interval_3_Run = 3000; // interval at which to blink (milliseconds)
long interval_3_Wait = 18000000; // interval at which to blink (milliseconds)
long interval_4_Run = 3000; // interval at which to blink (milliseconds)
long interval_4_Wait = 18000000; // interval at which to blink (milliseconds)
// const long interval_1_Wait = 8000; // Test only
long interval_temp_record = 1800000;
bool Relay_On = false;
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
pinMode(relay_1, OUTPUT);
pinMode(relay_2, OUTPUT);
pinMode(relay_3, OUTPUT);
pinMode(relay_4, OUTPUT);
digitalWrite(ledPin, HIGH);
digitalWrite(relay_1, HIGH);
digitalWrite(relay_2, HIGH);
digitalWrite(relay_3, HIGH);
digitalWrite(relay_4, HIGH);
Serial.begin(9600); //to communicate
pinMode(BUTTON_PIN1, INPUT_PULLUP); //push button
pinMode(BUTTON_PIN2, INPUT_PULLUP); //push button
pinMode(BUTTON_PIN3, INPUT_PULLUP); //push button
pinMode(BUTTON_PIN4, INPUT_PULLUP); //push button
dht.begin(); // for dht humidity & temp sensor
Serial.println(EEPROM.read(0)*1000);
//interval_1_Run = min(30000,max(5000,(EEPROM.read(0)*1000)));
byte buttonState1 = digitalRead(BUTTON_PIN1); //read button state - HIGH if not pressed due to InputPullUp
byte buttonState2 = digitalRead(BUTTON_PIN2); //read button state - HIGH if not pressed due to InputPullUp
byte buttonState3 = digitalRead(BUTTON_PIN3); //read button state - HIGH if not pressed due to InputPullUp
byte buttonState4 = digitalRead(BUTTON_PIN4); //read button state - HIGH if not pressed due to InputPullUp
//logic for button state change of state
if (buttonState1 == LOW) {
relay_selector = relay_selector +1;
if (relay_selector>4){
relay_selector=1;
Serial.println("Button 1 is pressed : relay selected is :");
Serial.println(relay_selector);
// Serial.println(interval_1_Run/1000,DEC);
blinkyBlinky(relay_selector, 250); // 5 is number of blinks, blinkTime is the milliseconds in each state from above: int blinkTime = 500;
//EEPROM.write(0,interval_1_Run/1000);
if (buttonState2 == LOW) {
switch (relay_selector) {
case 1: interval_1_Wait = interval_1_Wait+10800000;if (interval_1_Wait>82800000){interval_1_Wait=18000000;}break;
case 2: interval_2_Wait = interval_2_Wait+10800000;if (interval_2_Wait>82800000){interval_2_Wait=18000000;}break;
case 3: interval_3_Wait = interval_3_Wait+10800000;if (interval_3_Wait>82800000){interval_3_Wait=18000000;}break;
case 4: interval_4_Wait = interval_4_Wait+10800000;if (interval_4_Wait>82800000){interval_4_Wait=18000000;}break;
default:Serial.println("Invalid option.");break;
Serial.println("Button 2 is pressed");
// Serial.println("length of pump run:");
//blinkyBlinky(interval_1_Run/1000/5, 250); // 5 is number of blinks, blinkTime is the milliseconds in each state from above: int blinkTime = 500;
if (buttonState3 == LOW) {
case 1: interval_1_Run = interval_1_Run+5000;if (interval_1_Run>30000){interval_1_Run=5000;}break;
case 2: interval_2_Run = interval_2_Run+5000;if (interval_2_Run>30000){interval_2_Run=5000;}break;
case 3: interval_3_Run = interval_3_Run+5000;if (interval_3_Run>30000){interval_3_Run=5000;}break;
case 4: interval_4_Run = interval_4_Run+5000;if (interval_4_Run>30000){interval_4_Run=5000;}break;
Serial.println("Button 3 is pressed");
//Serial.println("length of pump run:");
//Serial.println(interval_1_Run+interval_2_Run+interval_3_Run+interval_4_Run);
// blinkyBlinky(interval_1_Run/1000/5, 250); // 5 is number of blinks, blinkTime is the milliseconds in each state from above: int blinkTime = 500;
if (buttonState4 == LOW) {
//interval_1_Run = interval_1_Run + 5000 ;
case 1:digitalWrite(relay_1, LOW);relayState_1 = LOW;previousMillis_1 = currentMillis; break;
case 2:digitalWrite(relay_2, LOW);relayState_2 = LOW;previousMillis_2 = currentMillis; break;
case 3:digitalWrite(relay_3, LOW);relayState_3 = LOW;previousMillis_3 = currentMillis; break;
case 4:digitalWrite(relay_4, LOW);relayState_4 = LOW;previousMillis_4 = currentMillis; break;
//if (interval_1_Run>30000){
// interval_1_Run=10000;
Serial.println("Button 4 is pressed : turning on relay :");
// Serial.println(buttonState4);
if (currentMillis - previousMillis_temp_record >= interval_temp_record) {
previousMillis_temp_record = currentMillis; //reset last time stamp
int temperature = dht.readTemperature(); // Read temperature and humidity
int humidity = dht.readHumidity(); // Read temperature and humidity
EEPROM.write(addr, temperature*9/5+32); //write temp
// EEPROM.write(addr+1, humidity); //write humidity
Serial.print("Temperature: ");
Serial.print(temperature*9/5+32);
Serial.print(" °F\t");
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println(" %");
Serial.println("run times:");
Serial.println(interval_1_Run);
Serial.println(interval_2_Run);
Serial.println(interval_3_Run);
Serial.println(interval_4_Run);
Serial.println("wait times:");
Serial.println(interval_1_Wait);
Serial.println(interval_2_Wait);
Serial.println(interval_3_Wait);
Serial.println(interval_4_Wait);
addr=addr+1; //next i & addr
} //end if interval passed
//logic for when LED is lit and pump is on - how long to run for
//relay = LOW means its ON
if(relayState_1 == LOW){
Relay_On = true;
if (currentMillis - previousMillis_1 >= interval_1_Run) {
Serial.println(currentMillis/1000/60/60); // how many minutes into program
Serial.println("Min since start: Pump just finished running"); // tell user that pump is running
previousMillis_1 = currentMillis; // save the last time you blinked the LED
//ledState = LOW;
relayState_1 = HIGH;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
digitalWrite(relay_1, relayState_1);
Relay_On = false;}
if(relayState_2 == LOW){
Relay_On = true;
if (currentMillis - previousMillis_2 >= interval_2_Run) {
previousMillis_2 = currentMillis; // save the last time you blinked the LED
//ledState = LOW;
relayState_2 = HIGH;
digitalWrite(relay_2, relayState_2);
Relay_On = false;}
if(relayState_3 == LOW){
Relay_On = true;
if (currentMillis - previousMillis_3 >= interval_3_Run) {
previousMillis_3 = currentMillis; // save the last time you blinked the LED
//ledState = LOW;
relayState_3 = HIGH;
digitalWrite(relay_3, relayState_3);
Relay_On = false;}
if(relayState_4 == LOW){
Relay_On = true;
if (currentMillis - previousMillis_4 >= interval_4_Run) {
previousMillis_4 = currentMillis; // save the last time you blinked the LED
//ledState = LOW;
relayState_4 = HIGH;
digitalWrite(relay_4, relayState_4);
Relay_On = false;}
//logic to wait for next interval
//relaystate = HIGH means its off
if(relayState_1 == HIGH){
if (currentMillis - previousMillis_1 >= interval_1_Wait) {
if (Relay_On == false){
Relay_On = true;
// if the LED is off turn it on and vice-versa:
//ledState = HIGH;
relayState_1 = LOW;
digitalWrite(relay_1, relayState_1);}}}
if(relayState_2 == HIGH){
if (currentMillis - previousMillis_2 >= interval_2_Wait) {
Relay_On = true;
//ledState = HIGH;
relayState_2 = LOW;
digitalWrite(relay_2, relayState_2);}}
if(relayState_3 == HIGH){
if (currentMillis - previousMillis_3 >= interval_3_Wait) {
Relay_On = true;
//ledState = HIGH;
relayState_3 = LOW;
digitalWrite(relay_3, relayState_3);}}
if(relayState_4 == HIGH){
if (currentMillis - previousMillis_4 >= interval_4_Wait) {
Relay_On = true;
//ledState = HIGH;
relayState_4 = LOW;
digitalWrite(relay_4, relayState_4);}}
void blinkyBlinky(int repeats, int time)
for (int i = 0; i < repeats; i++)
delay(time);
digitalWrite(ledPin, LOW);
delay(time);
