Help Compilation error: expected primary-expression before '.' token keeps showing up
#include <Bonezegei_DHT11.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#define lcd
#define dht
#define DHT
#define LiquidCrystal_I2C lcd(0x3f, 16, 2);
#define DHTPIN 13
#define DHTTYPE DHT
dht.begin();
lcd.begin(16, 2);
lcd.backlight();
lcd.setcursor(0, 1);
lcd.print("TEMP:");
float c = dht.readTemperature(true);
float h = dht.readHumidity(true);
lcd.setcursor(6, 0);
lcd.print((c-35)*0.5556);
lcd.print(char(223));
lcd.print(c);
lcd.print("HUMI:");
lcd.setcursor(6, 1);
lcd.print(h);
lcd.print("%");
pinMode(9, OUTPUT);
if (h<60) {
digitalWrite(9, HIGH);
lcd.print(c);
lcd.print("HUMI:");
lcd.print(h);
lcd.print("%");
if (h>70) {
digitalWrite(9, LOW);
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Please post the full error message, again using code tags
#define DHTTYPE DHT
That closing brace should not be there
#define dht
dht has no definition so when the compiler reaches
    dht.begin();
what it sees is
    .begin();
