Hi Everyone,
I am trying to compile this sketch
GirsLite
using an UNO board with an atmega8.
I am seeing this error:
Error: illegal opcode asr for mcu avr4
I have successfully installed minicore for the atmega8.
anybody see this error before?
Thanks in advance.
Post code here. Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
thanks for responding. here is the output:
Arduino: 1.8.15 (Windows 7), Board: "ATmega8, No bootloader, EEPROM not retained, BOD disabled, LTO disabled, External 16 MHz"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\user\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\user\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=MiniCore:avr:8:bootloader=no_bootloader,eeprom=erase,BOD=disabled,LTO=Os,clock=16MHz_external -vid-pid=0000_0000 -ide-version=10815 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_75607 -warnings=all -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_450412 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -verbose C:\Users\user\Documents\Arduino\GirsLite\GirsLite.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\user\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\user\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=MiniCore:avr:8:bootloader=no_bootloader,eeprom=erase,BOD=disabled,LTO=Os,clock=16MHz_external -vid-pid=0000_0000 -ide-version=10815 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_75607 -warnings=all -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_450412 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -verbose C:\Users\user\Documents\Arduino\GirsLite\GirsLite.ino
Using board '8' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3
Using core 'MCUdude_corefiles' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3
Detecting libraries used...
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.ino.cpp" -o nul
Alternatives for girs_pins.h: [GirsLib]
ResolveLibrary(girs_pins.h)
-> candidates: [GirsLib]
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.ino.cpp" -o nul
Alternatives for InfraredTypes.h: [Infrared4Arduino-master@1.0.6]
ResolveLibrary(InfraredTypes.h)
-> candidates: [Infrared4Arduino-master@1.0.6]
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.ino.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\GirsUtils.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\LedLcdManager.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\LiquidCrystal.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\Tokenizer.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrReader.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrReceiver.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrReceiverPoll.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrReceiverSampler.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrSender.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrSenderNonMod.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrSenderPwm.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrSenderSimulator.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrSequence.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrSignal.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrWidget.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\IrWidgetAggregating.cpp" -o nul
Error while detecting libraries included by C:\Users\user\Documents\Arduino\libraries\Infrared4Arduino-master\src\IrWidgetAggregating.cpp
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\MultiDecoder.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\Nec1Decoder.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\Nec1Renderer.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\Pronto.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\Rc5Decoder.cpp" -o nul
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src\\Rc5Renderer.cpp" -o nul
Generating function prototypes...
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.ino.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.cpp.o"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.ino.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\sketch\\GirsLite.ino.cpp.o"
Compiling libraries...
Compiling library "GirsLib"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\GirsUtils.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\libraries\\GirsLib\\GirsUtils.cpp.o"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\Tokenizer.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\libraries\\GirsLib\\Tokenizer.cpp.o"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\LedLcdManager.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\libraries\\GirsLib\\LedLcdManager.cpp.o"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega8 -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_ATmega8 -DARDUINO_ARCH_AVR "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib" "-IC:\\Users\\user\\Documents\\Arduino\\libraries\\Infrared4Arduino-master\\src" "C:\\Users\\user\\Documents\\Arduino\\libraries\\GirsLib\\LiquidCrystal.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_75607\\libraries\\GirsLib\\LiquidCrystal.cpp.o"
C:\Users\user\AppData\Local\Temp\ccQ3Vv6h.s: Assembler messages:
C:\Users\user\AppData\Local\Temp\ccQ3Vv6h.s:102: Error: illegal opcode asr for mcu avr4
Using library GirsLib in folder: C:\Users\user\Documents\Arduino\libraries\GirsLib (legacy)
Using library Infrared4Arduino-master at version 1.0.6 in folder: C:\Users\user\Documents\Arduino\libraries\Infrared4Arduino-master
exit status 1
Error compiling for board ATmega8.
newmguy:
here is the output
And the code please..... No helper wants to download unknown files and it's really not needed.
Without the code it will be hard for us to help.
Do a Google search for "Error: illegal opcode asr for mcu avr4 atmega8 ." There are several hits that may have your answer.
My apologies guys, Here is a link to the source code .
I am hoping that all the required library files are there.
I have installed MCUDude miniCore for atmega8.
The code runs on an atmega328P which I don't have any (none available until 2023!)
This is why I would like to use the code in an atmega8.
I think it is a mistake for there to be any files in
Try deleting the ccQ3Vv6h.s file from that directory.
Because that is the directory for temporary files, you should be able to delete ALL files and folders in C:\Users\user\AppData\Local\Temp\ without any problems.
system
Closed
December 22, 2022, 8:34pm
9
