I've been having some trouble using the MPU-6050 with an Atmega328P chip which is using its internal 8Mhz clock. I suspect that it could be Wire.h library but I am not sure and any help making the two work would be great.
Here is my set-up:
MPU-6050 to Atmega328p
VCC -- 5V
Gnd -- Gnd
SCL -- Pin 25 (A5)
SDA -- Pin 24 (A4)
Here is the code (Written by Joop Brokking):
SETUP:
void setup_mpu_6050_registers(){
//Activate the MPU-6050
Wire.beginTransmission(0x68); //Start communicating with the MPU-6050
Wire.write(0x6B); //Send the requested starting register
Wire.write(0x00); //Set the requested starting register
Wire.endTransmission(); //End the transmission
//Configure the accelerometer (+/-8g)
Wire.write(0x1C); //Send the requested starting register
Wire.write(0x10); //Set the requested starting register
//Configure the gyro (500dps full scale)
Wire.write(0x1B); //Send the requested starting register
Wire.write(0x08); //Set the requested starting register
GATHER DATA:
void read_mpu_6050_data(){ //Subroutine for reading the raw gyro and accelerometer data
Wire.write(0x3B); //Send the requested starting register
Wire.requestFrom(0x68,14); //Request 14 bytes from the MPU-6050
while(Wire.available() < 14); //Wait until all the bytes are received
acc_x = Wire.read()<<8|Wire.read(); //Add the low and high byte to the acc_x variable
acc_y = Wire.read()<<8|Wire.read(); //Add the low and high byte to the acc_y variable
acc_z = Wire.read()<<8|Wire.read(); //Add the low and high byte to the acc_z variable
temperature = Wire.read()<<8|Wire.read(); //Add the low and high byte to the temperature variable
gyro_x = Wire.read()<<8|Wire.read(); //Add the low and high byte to the gyro_x variable
gyro_y = Wire.read()<<8|Wire.read(); //Add the low and high byte to the gyro_y variable
gyro_z = Wire.read()<<8|Wire.read(); //Add the low and high byte to the gyro_z variable
I am not sure why my set-up isn't working. I think it has something to do with the use of the internal clock because when I do this same setup with an external 16 Mhz clock then it will work with no other changes.
Anyone have any ideas on how I could use the MPU 6050 with the Atmega328p with internal 8mhz clock???
