Help in GSM SMS receiving
Hi so I was trying to make an Arduino project using Arduino Uno and a Sim800 GSM module. Basically, when the user would send "Hello" to the GSM, the arduino would reply with "Hello to you too". But I get no response.
 #include <SoftwareSerial.h>
SoftwareSerial mySerial(9,10); //RX, TX (respectively) pins of programmed Serial Port
char inchar;
  Serial.begin(9600);// Set Baud Rate of PUSB Serial Port to 9600 (standard)
  mySerial.begin(9600); // Set Baud Rate of Programmed Serial Port to 9600 (standard)
  sms(); // Triggers the SMS function
         // Can be triggered in the loop by using this same command
  if(mySerial.available() >0)
    inchar=mySerial.read();
    if(inchar=='H')
      if(mySerial.find("ello"))
        reply();
        Serial.print(inchar);
        delay(100);
void sms()
  mySerial.println("AT+CMGF=1");
  mySerial.println("AT+CMGS=\"+63XXXXXXX\"\r");  // Insert number with country code here
  mySerial.println("Hello World\x1A"); // Message that will send
  delay(100);
  mySerial.println((char)26);
void reply()
  mySerial.println("AT+CMGS=\"+63XXXXX\"\r");  // Insert number with country code here
  mySerial.println("Hello to you too."); // Message that will send
  delay(100);
In addition, I tried printing the message into the Serial Monitor and all I get is "H".
You tried printing what message? When you read an 'H', you then look for "ello" in the stream. If it is there, you do NOT get those characters anywhere. If it is not there, you have no clue what was there.
Bottom line: DO NOT USE find() UNLESS YOU KNOW FOR CERTAIN THAT THE STRING CAN BE FOUND, or you don't give a s**t what was in the stream.
