Hey guys, I am trying to interface my SIM800 gsm module with my arduino MEGA to send or receive a text using hardware serial ports. Connected Tx of modem to Rx1 and Rx of modem to Tx1. checked my serial monitor and tried to send a text to my phone number but then it wouldnt send it. i don't want to use SoftwareSerial since I am already using a fingerprint sensor to interface that. What should I do?
here's my code:
Serial.begin(9600); // Setting the baud rate of Serial1Monitor (Arduino)
Serial1.begin(38400); // Setting the baud rate of GSM Module
delay(100);
if (Serial.available()>0)
switch(Serial.read())
case 's':
SendMessage();
case 'r':
RecieveMessage();
if (Serial1.available()>0)
Serial.write(Serial1.read());
void SendMessage()
Serial1.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
Serial1.println("AT+CMGS=\"+91xxxxxxxxxx\"\r"); // Replace x with mobile number
Serial1.println("I am SMS from GSM");// The SMS text you want to send
delay(100);
Serial1.println((char)26);// ASCII code of CTRL+Z
void RecieveMessage()
Serial1.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
pylon:
Yes. But try first with above sketch and typing the commands on the Serial Monitor to see if you get errors from your GSM modem.
You mean the AT commands?
I tried that but there is no response in the serial window.
Should I type the commands as
AT+CMGF=1
"AT+CMGS="+91xxxxxxxxxx"\r" ?
AT+CMGF=1
Yes, and the modem should answer with OK or something similar. Keep in mind that I chose 38400 for the baud rate to the PC too. So you have to configure your Serial Monitor to that.
I tried it. there was no OK or error but whatever I typed appeared on the serial monitor
