i have a development board.
i want use DCMI (camera interface) with this board.
unfortunately there is an AT24C02 E2prom mounted on board which its SDA pin is connected to the same pin used in DCMI-connection (VSYNC).
i checked datasheet but i am not very perfect in reading datasheet's analog sections.
i am to write this question as a double check to be sure there is no problem with connecting my camera like this.
i guess AT24C02's SDA does not shorted to GND and will not drain current (less than 5μA) when VSYNC line is high
