Hi, so I am having problems with my new LCD Display. I haven't ever used one before, but I got some sample code:
#include "LiquidCrystal.h"
// initialize the library by providing the nuber of pins to it
LiquidCrystal lcd(8,9,4,5,6,7);
lcd.begin(16,2);
// set cursor position to start of first line on the LCD
lcd.setCursor(0,0);
//text to print
lcd.print(" COUNTER");
delay(100);
int a=0;
lcd.setCursor(0,1);
lcd.print(" ");
lcd.print(a);
while(a<=100)
a=a+1;
lcd.setCursor(0,1);
lcd.print(" ");
lcd.print(a);
lcd.clear();
I meant the Potentiometer Do you mean a link to where I bought the LCD? I thought they were all the same. Here is the link to where I bought it: Amazon.com
lcd.begin(16,2);
lcd.setCursor(0,1);
lcd.print("Hello World");
I then turned the pot slowly back and forth and nothing happened.
Ok, so as I was messing around with it, I accidentally bumped it, and then stuff flickered on. I figured out that if I bend it around, then I can get it to work a little. At one point, I got it just right so that it said the right words and everything. However, I can't get it in just the right bend again. I have it on some male pins out from my breadboard, but I don't know how to get it to connect better.
There is an old saying - it works better when you plug it in.
I guess my comment about NOT running ANY code and then adjusting the pot did not sink in.
Just connect the + and grounds to BOTH LCD supply and backlight LED and do you intensity adjustment after
the device goes thru its power-on sequence - automatically.
It is possible that your is also controlling the backlight so you are better off not running code until you have working hardware.
Not to worry about how much power you drawing - these LCD been around for few yeas and are not that
hungry by itself - its the backlight LED that takes few mA.
Okay guys, thanks for all the question helps, I think I got it mostly figured. So, I was just using some straight male to male pins from my breadboard to each hole in the LCD, and when I gently bent/tipped the lcd display backward or forward, it would sometimes work. So then I knew that it was a problem of bad connectivity. And then, yes, I soldered the pins to the LCD, and now it works great. Will it work to use my IR Remote to change the text on the LCD?
Vulcan666:
Never use loose connections; recipe for problems (as you have figured).
Vulcan666:
Okay, thanks so much, it works now. However, now it says howdyhowdyhowdyhowdy without end, how do I make it say it once? I put it on those pins because I looked up a diagram and that was how it was wired. Guess they didn't have ir remote plans in mind:)
