Hello
I would like to done a project domotic with a old Lcd shield 1602 and a Esp12F
I have followed this video :
I have test the two files INO of this video I have succeed for a Arduino file here :
#include <LiquidCrystal.h>
const int rs=D1, en=D2, d4=D4, d5=D5, d6=D6, d7=D7;
LiquidCrystal lcd(rs,en,d4,d5,d6,d7); //select the pins used on the LCD panel
void setup(){
lcd.begin(16, 2);
lcd.clear();
void loop(){
lcd.setCursor(0,1);
lcd.clear();
lcd.print(analogRead(A0)); //read anolog pin A0
delay(100);
Serial.println("Moniteur Série prêt");
Serial.println(analogRead(A0));
For the second file INO here I have error :
#define SELECT_KEY 1
#define LEFT_KEY 2
#define DOWN_KEY 3
#define UP_KEY 4
#define RIGHT_KEY 5
int menuPos = 0;
String menuLines[6] =
"Settings",
"Reset",
"Main Site",
"Server IP",
"Get Data",
"Return"
lcd.begin( 16, 2 );
lcd.clear();
lcd.print(">"); lcd.print( menuLines[ menuPos ] );
lcd.setCursor(0, 1); lcd.print( menuLines[ menuPos + 1] );
if( getKeyID() == UP_KEY ) menuPos--;
if( getKeyID() == DOWN_KEY ) menuPos++;
if( menuPos < 0 ) menuPos = 0;
if( menuPos > 5 ) menuPos = 5;
delay(100);
int getKeyID()
int aRead = analogRead( A0 );
if( aRead > 500 ) return 0; //no key is pressed
if( aRead > 420 ) return SELECT_KEY; //select key
if( aRead > 350 ) return LEFT_KEY; //left key
if( aRead > 300 ) return DOWN_KEY; //right key
if( aRead > 150 ) return UP_KEY; //up key
if( aRead < 30 ) return RIGHT_KEY; //right key
Here the error I have at the compilation :
C:\Users\Claude\Documents\Sketchs Arduino\nodemcu-lcd-shield-main\shield_ENG\shield_ENG.ino: In function 'int getKeyID()':
C:\Users\Claude\Documents\Sketchs Arduino\nodemcu-lcd-shield-main\shield_ENG\shield_ENG.ino:56:1: error: control reaches end of non-void function [-Werror=return-type]
56 | }
cc1plus.exe: some warnings being treated as errors
exit status 1
Compilation error: control reaches end of non-void function [-Werror=return-type]
Does anyone has an explanation, sorry I'am newbee with arduino
