Help me decode this 434mhz signal...?
Hi Riva,
Sure, I can give as many examples as you'd like.
I've attached several raw wav files of a bit stream with values fairly close together to be able to hopefully find the difference between them. I can give more broad ranged values too if you'd like.
Sample B: transmitter read 71.2F and 39% humidity
Sample C: transmitter read 70.3F/21.3C and 40% humidity
Sample E: transmitter read 70.0F/21.1C and 41% humidity
Sample F: transmitter read 70.2F/21.2C and 41% humidity
The transmitter sends the burst of new data approximately every 75 seconds.
Thanks for any insights whatsoever, no matter how small!
sampleC.wav (88.2 KB)
sampleE.wav (87.1 KB)
sampleF.wav (80.6 KB)
sampleB.wav (96.9 KB)
