Hi everyone
I am using a Arduino Duemilanove and a Ultrasonic ranger to hold the altitude of an Quad-copter. I can use transmitter's switch to switch between altitude hold mode and manual throttle control mode. Once I switch to altitude mode, the Arduino will send a pwm to throttle dut to the range to the ground. It is working only when it connected to my computer. If it is not connect to computer, the manual control mode is good. If I switch to altitude hold mode, the motor will be out of control. Is there any problem in the software?
Test video: - YouTube
The test video just show you how it works. The arduino has been connected to the computer. So it works well.
here is my software:
#include <Servo.h>
Servo myservo;
const int echo = 12;
const int trig = 13;
const int sw = 3;
const int th = 4;
pinMode(echo,INPUT);
pinMode(trig,OUTPUT);
int sensorValue = digitalRead(echo);
int swValue = digitalRead(sw);
int thValue = digitalRead(th);
myservo.attach(9);
long duration, hold ,power;
hold = pulseIn(sw,HIGH);
if (hold>1500)
digitalWrite(trig,LOW);
delayMicroseconds(2);
digitalWrite(trig,HIGH);
delayMicroseconds(12);
duration = pulseIn(echo,HIGH);
duration = map(duration, 0, 1000, 135, 45);
myservo.write(duration);
else {
power = pulseIn(th,HIGH);
power = map (power, 1000, 2000, 135, 45);
myservo.write(power);
delay(15);
