Hi...here I'm finishing a project. In this project I made a server room monitoring system using 2 slaves (slave 1 sent 1 sensor data and slave 2 sent 3 sensor data) using Arduino Nano to the master (Wemos D1 ESP8266). Here I use the max485 ttl to rs485 converter module and the modbusRtu Library from GitHub - smarmengol/Modbus-Master-Slave-for-Arduino: Modbus Master-Slave library for Arduino.
Here I have 2 examples of the master code that I made, the first slave code only sends data and the master prints data on the serial monitor. In this first code all slaves can be read by sensors. (results can be seen in the image below)
Then I developed the feature on the master by connecting to Telegram. Here I managed to connect the system to Telegram and Telegram was able to send messages as requested, but in this 2nd code, data from slave 2 could not be read and data that was successfully read when sent to Telegram still had a value of 0. (as shown below)
Here is the code for the master and each slave.
MASTER (Code 1)
// arduino mega master testing code
// modbus RS485 read and write register
// V1.1
// 1 master 2 slave,
// 1 slave : 1 input 1 output
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <Wire.h>
#include <ModbusRtu.h>
#define slaveNumber 5
#define delayCom 15
#define maxQuery 2*2//slaveNumer*2
#define RX D3
#define TX D4
#define RTS D8
#include <SoftwareSerial.h>
//#include <LiquidCrystal_I2C.h>
SoftwareSerial mySerial(RX, TX);
//LiquidCrystal_I2C lcd(0x27,16,2);
char ssid[] = "BATU"; // diisi nama wifi
char password[] = "estehmanis";
WiFiClientSecure client;
uint8_t u8state; //!< machine state
uint8_t u8query; //!< pointer to message query
uint16_t dataBus[7];
uint16_t lastPrint = 100;
int slaveID[slaveNumber] = {11, 12, 13, 14, 15};
Modbus object declaration
u8id : node id = 0 for master, = 1..247 for slave
port : Serial1 port
u8txenpin : 0 for RS-232 and USB-FTDI
or any pin number > 1 for RS-485
Modbus master(0, mySerial, RTS); // ID, seriapNumber, enablePin
This is an structe which contains a query to an slave device
modbus_t telegram[slaveNumber * 2];
unsigned long u32wait;
void init_modBus() {
int num = 0;
int addr = 0;
////SLAVE 1
// Read 1 data from Slave 11
telegram[num].u8id = slaveID[0]; // slave address
telegram[num].u8fct = 3; // function code (this one is registers read)
telegram[num].u16RegAdd = 0; // start address in slave
telegram[num].u16CoilsNo = 2; // number of elements (coils or registers) to read
telegram[num].au16reg = dataBus; // pointer to a memory array in the Arduino
num += 1;
addr += 2;
//SLAVE 2
// Read 1 data from Slave 2
telegram[num].u8id = slaveID[1]; // slave address
telegram[num].u16CoilsNo = 5; // number of elements (coils or registers) to read
telegram[num].au16reg = dataBus + 3; // pointer to a memory array in the Arduino
num += 1;
addr += 2;
master.start();
master.setTimeOut( 100 ); // if there is no answer in 100 ms, roll over
u32wait = millis() + 40;
u8state = u8query = 0;
void rtuState() {
switch ( u8state ) {
case 0:
if (millis() >= u32wait) u8state++; // wait state
case 1:
master.query( telegram[u8query] ); // send query (only once)
u8state++;
u8query++;
if (u8query >= maxQuery)
u8query = 0;
case 2:
master.poll(); // check incoming messages if communication in idle state
if (master.getState() == COM_IDLE) {
u8state = 0;
u32wait = millis() + delayCom; //delay for next state
void printData() {
if (millis() - lastPrint > 200) {
//print data to validate
// Serial.print("Slave:");Serial.println(dataBus[0]);
// Serial.print("Arus:");Serial.println(dataBus[1]);
// Serial.print("Slave:");Serial.println(dataBus[3]);
// Serial.print("Suhu:");Serial.println(dataBus[4]);
// Serial.print("Kelembapan:");Serial.println(dataBus[5]);
// Serial.print("Getaran:");Serial.println(dataBus[6]);
Serial.print(dataBus[0]); Serial.print(":");
Serial.print(dataBus[1]); Serial.print(":");
Serial.print(dataBus[2]); Serial.print("\t:\t");
Serial.print(dataBus[3]); Serial.print(":");
Serial.print(dataBus[4]); Serial.print(":");
Serial.print(dataBus[5]); Serial.print(":");
Serial.print(dataBus[6]);
Serial.begin (9600); //baud rate of Serial PC
mySerial.begin( 19200 ); // baud-rate of RS485
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi terhubung");
Serial.print("IP address: ");
init_modBus();
rtuState();
printData();
//processData();
MASTER (Code 2 with Telegram)
// V1.1
#include <Wire.h>
#define delayCom 15
#define RX D3
#define TX D4
#define RTS D8
const long utcOffsetInSeconds = 3600 * 7; //timer
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", utcOffsetInSeconds);
char daysOfTheWeek[7][12] = {"Minggu", "Senin", "Selasa", "Rabu", "Kamis", "Jumat", "Sabtu"};
#define BOTtoken "5404730433:AAFjsIjfVkY9IdEfhi2wOK59J_pFTAbMNKo" // diisi Token Bot (Dapat dari Telegram Botfather)
#define idChat "-1001841459091" //idbot
//int botRequestDelay = 1000;
unsigned long lastTimeBotRan;
UniversalTelegramBot bot(BOTtoken, client);
port : Serial1 port
int num = 0;
int addr = 0;
////SLAVE 1
num += 1;
addr += 2;
//SLAVE 2
telegram[num].u16CoilsNo = 4; // number of elements (coils or registers) to read
num += 1;
addr += 2;
master.start();
void rtuState() {
case 0:
case 1:
u8state++;
u8query++;
u8query = 0;
case 2:
u8state = 0;
void printData() {
client.setInsecure();
uint32_t notConnectedCounter = 0;
WiFi.disconnect();
delay(100);
Serial.print(".");
Serial.println("");
init_modBus();
rtuState();
printData();
peringatan();
//processData();
void peringatan() {
timeClient.update();
Serial.print("Suhu saat ini : ");
Serial.println(" *C\n");
Serial.print("Kelembapan saat ini : ");
Serial.println("%");
Serial.print("Getaran saat ini : ");
// if (timeClient.getHours() <= 9) {lcd.print("0");}
// if (timeClient.getMinutes() <= 9) {lcd.print("0");}
// if (timeClient.getSeconds() <= 9) {lcd.print("0");}
if (timeClient.getHours() == 20 and timeClient.getMinutes() == 50 and timeClient.getSeconds() <= 15) {
bot.sendChatAction(idChat, "Sedang mengetik...");
String suhu = "KONDISI SUHU DAN KELEMBAPAN SAAT INI\n";
suhu += "\nHari : ";
suhu += daysOfTheWeek[timeClient.getDay()];
suhu += "\nPukul : ";
suhu += timeClient.getHours();
suhu += ":";
suhu += timeClient.getMinutes();
suhu += ":";
suhu += timeClient.getSeconds();
suhu += " WIB";
suhu += "\nSuhu : ";
suhu += int(dataBus[2]);
suhu += " *C\n";
suhu += "Kelembapan : ";
suhu += int(dataBus[5]);
suhu += " %\n";
suhu += "Getaran : ";
suhu += int(dataBus[6]);
bot.sendMessage(idChat, suhu, "");
Serial.print("Mengirim data sensor ke telegram\n");
if (timeClient.getHours() == 21 and timeClient.getMinutes() == 00 and timeClient.getSeconds() <= 15) {
suhu += ":";
suhu += ":";
suhu += " WIB";
suhu += " *C\n";
suhu += " %\n";
if (dataBus[2] < 18) {
if (timeClient.getMinutes() == 30 or timeClient.getMinutes() == 0) {
String suhu = "SUHU RUANGAN RENDAH\n";
suhu += "\n Pukul : ";
suhu += ":";
suhu += ":";
suhu += " WIB";
suhu += "Suhu : ";
suhu += " *C\n";
if (dataBus[5] < 40) {
String suhu = "KELEMBAPAN RUANGAN RENDAH\n";
suhu += ":";
suhu += ":";
suhu += " WIB";
suhu += " %\n";
if (dataBus[2] > 27) {
if (timeClient.getMinutes() == 5 or timeClient.getMinutes() == 10 or timeClient.getMinutes() == 15 or timeClient.getMinutes() == 20 or timeClient.getMinutes() == 25 or timeClient.getMinutes() == 30 or timeClient.getMinutes() == 35 or timeClient.getMinutes() == 40 or timeClient.getMinutes() == 45 or timeClient.getMinutes() == 50 or timeClient.getMinutes() == 55 or timeClient.getMinutes() == 0) {
if (timeClient.getSeconds() <= 15) {
String suhu = "SUHU RUANGAN TINGGI\n";
suhu += ":";
suhu += ":";
suhu += " WIB";
suhu += " *C\n";
if (dataBus[5] > 60) {
String suhu = "KELEMBAPAN RUANGAN TINGGI\n";
suhu += ":";
suhu += ":";
suhu += " WIB";
suhu += "\nKelembapan : ";
suhu += " %\n";
SLAVE 1 (send 1 data)
SoftwareSerial mySerial(2, 3);
#include <DHT.h>
#define slaveID 11
#define DHTPIN 7
#define DHTTYPE DHT11
int SWPIN=8;
DHT dht(DHTPIN,DHTTYPE);
int t;
int h;
int g;
uint16_t Suhu = 0;
uint16_t Lembab = 0;
uint16_t Getar = 0;
unsigned long lastPrint = 0;
// data array for modbus network sharing
uint16_t au16data[4] = {
slaveID, 225, 8888, 9999};
Modbus slave(slaveID, mySerial, 4); // this is slave @1 and RS-232 or USB-FTDI
mySerial.begin( 19200 ); // baud-rate at 19200
dht.begin();
pinMode (SWPIN, INPUT);
slave.start();
delay(10);
slave.poll( au16data, 4 );
if (millis() - lastPrint>200){
Serial.print(au16data[0]); Serial.print(":");
Serial.print(au16data[1]); Serial.print(":");
Serial.print(au16data[2]); Serial.println();
lastPrint = millis();
readSensor(); //for ultrasonic sensor
//long vibration(){
// long g=pulseIn (SWPIN, HIGH);
// return g;
void readSensor() {
t = dht.readTemperature();
h = dht.readHumidity();
if (isnan(h) || isnan (t)){
au16data[1] = 0;
Suhu = t;
au16data[1] = Suhu; //data to be sent to slave device
SLAVE 2 (Send 3 data to master)
#include <DHT.h>
#define slaveID 12
#define DHTPIN 7
int SWPIN=8;
int t;
int h;
int g;
uint16_t Suhu = 0;
uint16_t Getar = 0;
uint16_t au16data[5] = {
slaveID, 225, 255,255, 9999
dht.begin();
slave.start();
delay(10);
slave.poll( au16data, 5 );
Serial.print(au16data[2]); Serial.print(":");
Serial.print(au16data[3]); Serial.println();
long vibration(){
return g;
void readSensor() {
g = vibration();
cekGetar();
au16data[1] = 0;
au16data[2] = 0;
Suhu = t;
Lembab = h;
au16data[2] = Lembab;
au16data[3] = Getar;
void cekGetar(){
if (g==0){
Getar = 0;
if (g>0 && g<=1000){
Getar = 1;
if (g>1000 && g<=10000){
Getar = 2;
if (g>10000){
Getar = 3;
return Getar;
I hope someone can help me because I'm being chased by having a deadline of 3 days :(.
Thanks,
Fatwatul
