About me: Industrial Engineer who is interested in building stuff. Absolute N00bie to Arduino and all things electrical.
I recently came across an idea for a mini conveyor using chain drive. The objective is to run 3 chains at 3 really slow(~0.1,0.1 and 0.01 rpm) but different speeds. I can't drive it to rotate once every 10 minutes though. In order to achieve such low speeds, the chains will be driven by stepper motors as I do not have space to use gearing. The load is very low too.
My question #1: In order to drive the 3 stepper motors, what kind of driver should be used? I was thinking of going with the Arduino Uno R3 and have it connected to 3 different drivers to start. Will I be able to connect 3 drivers and control 3 motors on a single Arduino Uno R3?
Question #2: Is there a way to use just one driver to save space ? The speed of the stepper motors is not going to be altered.
Too little information. Is this a hand held device, or for something used in a factory?
Gear wheels are often a tiny fraction of the size of the motor driving them.
You could try looking at hardware sold for making your own 3d printer - they have to drive multiple stepper motors - you might get a ready made solution to your problem.
mikb55:
Hey Mikb65, this will be used in a factory setting but I'm not sure why this matters.
JohnLincoln:
and for such a size, I don't think it would be possible to reduce the speed by gear wheels at the desired ratio.
The camera-size stepper motors require very low voltage & current. Most common stepper drivers (even RAMPS plug-in types that have adjustable-current) will deliver way too much current for such a tiny motor.
Pololu makes a stepper driver board with the DRV8834 chip that I would suggest.
Alternately, you could look into what chips are used to drive those motors in camera lenses.
