Help Needed: Servo Oscillating Issue with ESP32 and IRF520 MOSFET Control
Hello everyone,
I'm currently working on a project using an ESP32 to control an MG995 servo motor through a IRF520 MOSFET as a switch. I've encountered a persistent issue where the servo oscillates erratically when it's supposed to move to a specific position or hold its position. I've checked the hardware setup multiple times, and the issue seems to persist, which suggests it might be something in my software setup or perhaps a deeper electronic issue I'm not aware of. I'm reaching out to see if anyone could help diagnose or solve this problem.
Project Details:
  • Microcontroller: ESP32
  • Servo Motor: MG995
  • Transistor: IRF520 MOSFET
  • Purpose: The servo is supposed to receive position data via MQTT and move accordingly.
Wiring Setup:
  • Servo Control Signal (Yellow Wire): Connected to GPIO 18 of the ESP32.
  • Servo Power (Red Wire): Connected directly to the positive terminal of a 6V power supply.
  • Servo Ground (Brown Wire): Connected to the common ground.
  • Transistor Setup:
    • Gate: Connected to GPIO 16 via a 220 ohm resistor.
    • Drain: Connected to the ground wire of the servo.
    • Source: Connected to the common ground.
Code Overview:
I'm including the relevant parts of my code setup here for review:
// MQTT message callback function
void callback(char* topic, byte* payload, unsigned int length) {
  payload[length] = '\0'; // Null-terminate the payload data
  String message = String((char *)payload); // Convert payload to string for easier manipulation
  if (String(topic) == mqtt_receive_topic) { // Check if the message is from the expected topic
    int newPosition = message.toInt(); // Convert the message to an integer value representing the new position
    if (newPosition >= 0 && newPosition <= 100) { // Ensure the position is within the valid range
      if (!isAttached) {
        digitalWrite(Transistor_Pin, HIGH);  // Ensure the transistor is on when moving the servo
        myservo.attach(Servo_Pin); // Attach the servo to its pin
        bool isAttached = true;
      servoPosition = map(newPosition, 0, 100, 0, 180); // Map the position from 0-100 scale to 0-180 degrees for the servo
      myservo.write(servoPosition); // Command the servo to move to the calculated position
      encoder.setCount(newPosition); // Synchronize the encoder's count to this new position
      char msg[50];
      sprintf(msg, "%d", newPosition); // Prepare a message to send back confirming the new position
      client.publish(mqtt_topic, msg); // Publish the new position to MQTT
      oldPosition = newPosition; // Update the old position tracker
      lastMovementTime = millis(); // Reset the movement timer
// Initial setup function
  encoder.attachHalfQuad(DT, CLK); // Setup the encoder in half quadrature mode
  pinMode(Transistor_Pin, OUTPUT);  // Set the transistor control pin as an output
  digitalWrite(Transistor_Pin, LOW);  // Start with the transistor turned off
  bool isAttached = false;
  Serial.begin(115200); // Start serial communication at 115200 baud rate
  setupWiFi(); // Call the Wi-Fi setup function
  client.setServer(mqtt_broker, 1883); // Set the MQTT server
  client.setCallback(callback); // Assign the callback function to handle incoming messages
// Main loop function
  if (!client.connected()) { // If not connected to MQTT
    reconnect(); // Attempt to reconnect
    client.loop(); // Handle incoming messages and maintain MQTT connection
  int newPosition = encoder.getCount(); // Read the current position from the encoder
  if (newPosition > 100) { // Constrain the position to 100 if it exceeds
    newPosition = 100;
    encoder.setCount(100); // Reset encoder's count to the maximum
  } else if (newPosition < 0) { // Constrain the position to 0 if it falls below
    newPosition = 0;
    encoder.setCount(0); // Reset encoder's count to the minimum
  if (newPosition != oldPosition) { // If the position has changed
    if (!isAttached) {
    servoPosition = map(newPosition, 0, 100, 0, 180); // Map the new position to servo scale
    myservo.write(servoPosition); // Command the servo to move to the new position
    char msg[50];
    sprintf(msg, "%d", newPosition); // Format a message to publish the new position
    Serial.println(msg); // Output the new position to the serial monitor
  // Detach servo if no movement for more than the specified delay time
  if (millis() - lastMovementTime >= delayTime) {
    myservo.detach(); // Detach the servo to reduce power consumption
    digitalWrite(Transistor_Pin, LOW);  // Turn off the transistor to cut power to the servo
  delay(10);
Symptoms:
  • When instructed to move, the servo does not smoothly transition to the set angles. Instead, it jerks back and forth around the desired position.
  • A gif showing the erratic movement is attached here.
servo_oscillating (3)
Attempts to Fix:
  • I have ensured that the wiring is correct and that there are no loose connections.
  • I’ve tried adding delays and even smoothing algorithms without any significant improvement.
  • I've confirmed that the power supply is stable and sufficient.
Questions:
  1. Could this issue be related to how I'm using the IRF520 MOSFET with the ESP32?
  2. Is there an issue with the PWM signal from the ESP32 to the servo?
  3. Are there any suggestions on how to better stabilize the servo's movement?
Any help or suggestions would be greatly appreciated as I'm quite stuck on how to resolve this and ensure smooth operation of the servo.
Thank you in advance!
  • When asking for help you need to supply all pertinent information.
Always show us a good schematic of your proposed circuit. Show us good images of your ‘actual’ wiring. Give links to components.
  • BTW, an IRF520 MOSFET married to an ESP32 will end in divorce !
A logic level MOSFET is required, kind of IRL...
Do you have any recommendations for a transistor that would work with both the high torque servo and esp32. Here is a wiring diagram, and picture of the physical wiring job. For the online diagram, just assume the transistor shown would be the IRF520 on the correct pins (They didn't have the IRF520 or ESP32).
Sorry @LarryD , reply was to go to OP. Not sure how I screwed it up.
When asking hardware questions, a schematic is much preferred over written description. Otherwise good job on your first question.
Servo jitter can most often be traced to inadequate power to the servo.
The IRF520 is not a "logic level" MOSFET, meaning that it takes more than a logic level voltage to the gate to turn it on fully.
The 520 MOSFET comes in 2 flavors. IRF20 and IRL520, the L designates a logic level part.
The first thing to look at (except the L) is the Rds(on) specification. That spec says at what gate voltage the MOSFET will turn on.
The Rds(on) from the IRF520 sheet.
Note that Vgs is speced at 10V. it will pass current at lower levels of Vgs but will not be fully turned on. 3.3V is not going to allow much current to pass (consult the graphs).
Rds(on) from the IRL520 data sheet
Here you see that the Vgs specs are much lower and your 3.3V gate voltage will turn the MOSFET on much harder (pass more power).
I got the new recommended transistors in and switched them into the design. The same problem is occurring. Does anyone have any other thoughts on ways to fix it?
  • Time to show us a complete schematic showing all components in your circuit.
  • Better images are needed too.
What might they be?
I did not see anyone recommend a part number.
It's the IRL520N
Do you have any recommendations for schematic drawing tools?
  • Pencil and paper works for now.
The esp32 is plugged into a 5v 1a micro-usb
And here is the complete codeset
// Include necessary libraries for encoder, servo, Wi-Fi and MQTT functionalities
#include <ESP32Encoder.h>
#include <ESP32Servo.h>
#include <WiFi.h>
#include <PubSubClient.h>
// Pin definitions for the encoder and servo
#define CLK 22
#define DT 23
#define Servo_Pin 18
#define Transistor_Pin 16
// WiFi credentials
const char* ssid = "Username";
const char* password = "Password";
// MQTT Broker settings
const char* mqtt_broker = "homeassistant.local";
const char* mqtt_username = "mqtt-user";
const char* mqtt_password = "Password";
const char* mqtt_topic = "home/esp32/livingroom/right/servo_position";
const char* mqtt_receive_topic = "home/esp32/livingroom/right/set_servo";
// Initialize WiFi and MQTT clients
WiFiClient espClient;
PubSubClient client(espClient);
// Encoder and servo objects
ESP32Encoder encoder;
Servo myservo;
int oldPosition = 0;
int servoPosition;
unsigned long lastMovementTime = 0;
const long delayTime = 5000;
// Function to setup Wi-Fi connection
void setupWiFi() {
  WiFi.begin(ssid, password); // Begin connection attempt to the specified Wi-Fi network
    delay(500); // Wait 500ms between checks
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
// Function to manage MQTT reconnection
void reconnect() {
  if (!client.connected()) { // If the client is not connected to the MQTT broker
    Serial.println("Attempting MQTT connection...");
    // Attempt to connect
    String clientId = "ESP32Client-";
    clientId += String(random(0xffff), HEX); // Generate a random client ID for connection
    if (client.connect(clientId.c_str(), mqtt_username, mqtt_password)) {
      Serial.println("Connected to MQTT Broker!");
      client.subscribe(mqtt_receive_topic); // Subscribe to the MQTT topic for receiving commands
      Serial.print("Failed to connect to MQTT Broker. rc=");
      Serial.println(client.state());
      delay(2000); // Wait 2 seconds before attempting reconnection
      if (!isAttached) {
      char msg[50];
    newPosition = 100;
    newPosition = 0;
    if (!isAttached) {
    char msg[50];
  delay(10);
  • Revisit your schematic and confirm how the MOSFET Drain and encoder/ESP32 (GND) is wired, not correct.
  • When the MOSFET is turned ON, what is the voltage across the servo ?
  • Write a short diagnostic sketch which moves the servo back and forth every 3 seconds.
  • Write a short diagnostic sketch to check the encoder.
  • It is not recommended to control the GND of loads like servos and similar devices with internal electronics.
    It’s best to control the positive side for your servo.
Whoever recommended that part did not know what they were doing.
It won't work with a 3.3V gate drive.
This tiny little board has all the parts soldered on it.
You connect it in the posiive lead (red wire ) to the servo
  • Did you read Post #14 ?
  • MOSFETS I use, select one for 3v3 use.
Example:
