Thanks trialex,
I had a dig around and came up with this:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define STRLEN 20
int updateLCD = 1;
char buffer[STRLEN];
int bufferIndex = 0;
int charCount = 0;
int timeCount = 0;
// set up the LCD's number of rows and columns:
lcd.begin(16, 2);
// initialize the serial communications:
if( Serial.available())
char ch = Serial.read();
charCount ++; // count characters coming through serial
// delay(1);
if( ch == '^') // is this the terminating carriage return
buffer[ bufferIndex ] = 0; // terminate the string with a 0
bufferIndex = 0; // reset the index ready for another string
updateLCD = 1;
if (updateLCD == 1 && buffer[0] == '1') {
lcd.setCursor(0,0);
for(int i = 0; i < STRLEN; i++) {
lcd.write(32); // erase row by writing spaces into all colls.
lcd.setCursor(0,0);
for(int i = 2; i < charCount - 2; i++) {
lcd.write(buffer[i]); // write from buffer into first row of LCD
if (updateLCD == 1 && buffer[0] == '2') {
lcd.setCursor(0,1);
lcd.setCursor(0,1);
lcd.write(buffer[i]); // write from buffer into second row of LCD
charCount = 0;
updateLCD = 0;
buffer[ bufferIndex++ ] = ch; // add the character into the buffer
So sending the message '1 hello ^' prints 'hello' into the first row of the LCD and sending '2 goodbye ^' prints 'goodbye' into the second row of the LCD. You can use the serial monitor to test or use the following Max/Msp patch.
max v2;
#N vpatcher 304 60 1564 916;
#P origin 0 -103;
#P toggle 92 58 15 0;
#P window setfont "Sans Serif" 9.;
#P window linecount 1;
#P newex 92 80 58 196617 metro 100;
#N counter 2 0 127;
#X flags 0 0;
#P newobj 197 121 83 196617 counter 2 0 127;
#N counter 0 0 127;
#X flags 0 0;
#P newobj 92 121 83 196617 counter 0 0 127;
#P newex 197 290 95 196617 prepend slider_2 =;
#P newex 197 313 54 196617 prepend 2;
#P slider 197 147 15 128 0 1;
#P newex 92 291 95 196617 prepend slider_1 =;
#P newex 92 349 64 196617 speedlim 50;
#P newex 92 314 54 196617 prepend 1;
#P slider 92 148 15 128 0 1;
#P newex 92 385 47 196617 append ^;
#P newex 92 409 51 196617 tosymbol;
#P newex 92 432 166 196617 spell;
#P newex 92 457 71 196617 serial a 9600;
#P connect 14 0 13 0;
#P connect 13 0 11 0;
#P connect 11 0 4 0;
#P connect 4 0 7 0;
#P connect 7 0 5 0;
#P connect 5 0 6 0;
#P fasten 9 0 6 0 202 344 97 344;
#P connect 6 0 3 0;
#P connect 3 0 2 0;
#P connect 2 0 1 0;
#P connect 1 0 0 0;
#P fasten 13 0 12 0 97 106 202 106;
#P connect 12 0 8 0;
#P connect 8 0 10 0;
#P connect 10 0 9 0;
#P pop;
It all seems to work well, but as it's my first bit of Arduino code I'm sure there are some things I could do better - Any advice?
I also came across a really strange problem with running the LCD and using 'Serial.println' in the same program. I've boiled it down to the following:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // get rid of this line and it works?!?
void loop(){
Serial.println("Hello World!");
I would expect this to print out 'Hello World!' but it does not. I get 'Hello Wo
ld!' (misses out the letter 'r') in the serial monitor.
If i get rid of the 'LiquidCrystal lcd(12, 11, 5, 4, 3, 2);' line I get the expected output, but of course I cant use my LCD display then.
Can anyone tell me what is going on here?
Arduino 0017 w/Roboduino Duemilanove board.
Cheers,
John.
