Help needed to display external RTC date and time on DWIN display using ESP32
Hello everyone,
I am a university student working on a project using an ESP32, DWIN display, MAX6675 temperature sensor, and an external RTC module to make a temperature recorder.
I am facing a problem with displaying the date and time from the external RTC on the DWIN display.
I have already tried several methods and also took help from the internet and other people, but unfortunately I have still not been able to get the required result, in result I am getting dots,nothing else.
Thanks in advance.
Regards,
Dino
Welcome to the forum
Can you print anything such as "Hello World" on the display ?
#include <Arduino.h>
#include <Wire.h>
#include <max6675.h>
#include <RTClib.h>
// HARDWARE PINS
// MAX6675 Thermocouple
#define MAX6675_SCK 18
#define MAX6675_CS 5
#define MAX6675_SO 19
MAX6675 thermocouple(MAX6675_SCK, MAX6675_CS, MAX6675_SO);
// DWIN UART2
#define DWIN_RX 25
#define DWIN_TX 26
#define DWIN_SERIAL Serial2
// External Real-Time Clock
RTC_DS3231 rtc;
bool rtcFound = false;
// DWIN VARIABLE POINTERS (VPs)
const uint16_t TEMP_VP = 0x1000; // Temperature Display (Numeric 2 Digits)
const uint16_t DATE_VP = 0x1010; // Date Display (Text Display, Length 12)
const uint16_t TIME_VP = 0x1020; // Time Display (Text Display, Length 10)
// Update timing
unsigned long lastUpdate = 0;
const unsigned long UPDATE_INTERVAL = 1000; // Update display every 1 second
// Software Clock Fallback (used if physical RTC is disconnected)
uint16_t softYear = 2026;
uint8_t softMonth = 10;
uint8_t softDay = 2;
uint8_t softHour = 20;
uint8_t softMinute = 20;
uint8_t softSecond = 0;
// DWIN PROTOCOL HELPERS
// Send 16-bit integer to DWIN numeric VP
void sendDwinWord(uint16_t address, uint16_t value) {
byte pkt[8];
pkt[0] = 0x5A;
pkt[1] = 0xA5;
pkt[2] = 0x05;
pkt[3] = 0x82; // Write Command
pkt[4] = highByte(address);
pkt[5] = lowByte(address);
pkt[6] = highByte(value);
pkt[7] = lowByte(value);
DWIN_SERIAL.write(pkt, 8);
DWIN_SERIAL.flush();
// Send ASCII text string to DWIN Text Display with dual 0xFF terminator
void sendDwinString(uint16_t address, String text, int maxLen = 12) {
byte pkt[36];
byte payloadLen = 3 + maxLen; // 0x82 + vpH + vpL + maxLen
pkt[0] = 0x5A;
pkt[1] = 0xA5;
pkt[2] = payloadLen;
int textLen = text.length();
for (int i = 0; i < maxLen; i++) {
if (i < textLen) {
  pkt\[6 + i\] = (byte)text\[i\];
} else if (i == textLen || i == textLen + 1) {
  pkt\[6 + i\] = 0xFF; // DWIN standard string terminator
  pkt\[6 + i\] = 0x00;
DWIN_SERIAL.write(pkt, 3 + payloadLen);
// SOFTWARE CLOCK TICKER (Fallback if physical RTC disconnects)
void tickSoftwareClock() {
softSecond++;
if (softSecond >= 60) {
softSecond = 0;
softMinute++;
if (softMinute >= 60) {
  softMinute = 0;
  softHour++;
  if (softHour >= 24) {
    softHour = 0;
    softDay++;
// SETUP
// Initialize I2C for External RTC (SDA=21, SCL=22)
Wire.begin(21, 22);
// Start DWIN hardware serial communication (UART2)
DWIN_SERIAL.begin(115200, SERIAL_8N1, DWIN_RX, DWIN_TX);
// Cold-boot delay: Give DWIN screen 2 seconds to complete power-on self-test
delay(2000);
Serial.println("\n=======================================================");
Serial.println(" ESP32 TEMPERATURE, DATE & TIME RECORDER CONTROLLER ");
Serial.println("=======================================================");
// Initialize External RTC
if (rtc.begin()) {
rtcFound = true;
Serial.println("\[RTC\] External Hardware RTC detected on I2C (GPIO 21/22)!");
if (rtc.lostPower()) {
  Serial.println("\[RTC\] Battery was disconnected, setting to compile time.");
  rtc.adjust(DateTime(F(\__DATE_\_), F(\__TIME_\_)));
rtcFound = false;
Serial.println("\[RTC\] Warning: No external RTC detected. Running software clock.");
// MAIN LOOP
unsigned long now = millis();
// Execute update every 1 second
if (now - lastUpdate >= UPDATE_INTERVAL) {
lastUpdate = now;
// 1. READ & DISPLAY TEMPERATURE (MAX6675)
float tempC = thermocouple.readCelsius();
if (isnan(tempC)) {
  Serial.println("\[ERROR\] Thermocouple disconnected or reading failed!");
  sendDwinWord(TEMP_VP, 0);
  Serial.printf("\[TEMP\] Sensor Output: %.1f °C\\n", tempC);
  // Warning diagnostic for reversed thermocouple polarity
  if (tempC >= 5.0 && tempC <= 16.0) {
    Serial.println(">>> \[NOTICE\] Reading 8-13°C at room temperature indicates REVERSED WIRES!");
    Serial.println(">>> Please swap the (+) and (-) wires on the MAX6675 screw terminal.");
  // Send whole integer (e.g. 26 °C) to fit 2-digit display
  uint16_t dwinIntVal = (uint16_t)round(tempC);
  sendDwinWord(TEMP_VP, dwinIntVal);
// 2. READ & FORMAT DATE AND TIME FROM EXTERNAL RTC
uint16_t year;
uint8_t month, day, hour, minute, second;
if (rtcFound) {
  DateTime dt = rtc.now();
  year   = dt.year();
  month  = dt.month();
  day    = dt.day();
  hour   = dt.hour();
  minute = dt.minute();
  second = dt.second();
  tickSoftwareClock();
  year   = softYear;
  month  = softMonth;
  day    = softDay;
  hour   = softHour;
  minute = softMinute;
  second = softSecond;
// Format Date String: "DD-MM-YYYY" (10 chars, fits 12-byte VP 0x1010)
char dateBuf\[12\];
snprintf(dateBuf, sizeof(dateBuf), "%02d-%02d-%04d", day, month, year);
// Format Time String: "HH:MM:SS" (8 chars, fits 10-byte VP 0x1020)
char timeBuf\[10\];
snprintf(timeBuf, sizeof(timeBuf), "%02d:%02d:%02d", hour, minute, second);
Serial.printf("\[CLOCK\] Date: %s | Time: %s\\n", dateBuf, timeBuf);
// 3. SEND DATE & TIME TO DWIN SCREEN
sendDwinString(DATE_VP, String(dateBuf), 12);
delay(5);
sendDwinString(TIME_VP, String(timeBuf), 10);
}Use code tags to format code for the forum
Note this message
Please post your sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Sir, I am very new in this forum, so forbid my mistakes
#include <Wire.h>
#include <RTClib.h>
// HARDWARE PINS
// DWIN UART2
#define DWIN_RX 25
#define DWIN_TX 26
RTC_DS3231 rtc;
// Update timing
  byte pkt[8];
  pkt[0] = 0x5A;
  pkt[1] = 0xA5;
  pkt[2] = 0x05;
  byte pkt[36];
  pkt[0] = 0x5A;
  pkt[1] = 0xA5;
    if (i < textLen) {
      pkt[6 + i] = (byte)text[i];
      pkt[6 + i] = 0xFF; // DWIN standard string terminator
      pkt[6 + i] = 0x00;
  softSecond++;
    softSecond = 0;
    softMinute++;
      softMinute = 0;
      softHour++;
        softHour = 0;
        softDay++;
// SETUP
  Wire.begin(21, 22);
  delay(2000);
  if (rtc.begin()) {
    rtcFound = true;
    Serial.println("[RTC] External Hardware RTC detected on I2C (GPIO 21/22)!");
      Serial.println("[RTC] Battery was disconnected, setting to compile time.");
      rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    rtcFound = false;
    Serial.println("[RTC] Warning: No external RTC detected. Running software clock.");
// MAIN LOOP
    lastUpdate = now;
    if (isnan(tempC)) {
      Serial.println("[ERROR] Thermocouple disconnected or reading failed!");
      Serial.printf("[TEMP] Sensor Output: %.1f °C\n", tempC);
        Serial.println(">>> [NOTICE] Reading 8-13°C at room temperature indicates REVERSED WIRES!");
    uint16_t year;
    if (rtcFound) {
      year   = dt.year();
      month  = dt.month();
      day    = dt.day();
      hour   = dt.hour();
      year   = softYear;
      month  = softMonth;
      day    = softDay;
      hour   = softHour;
    char dateBuf[12];
    char timeBuf[10];
    Serial.printf("[CLOCK] Date: %s | Time: %s\n", dateBuf, timeBuf);
    delay(5);
I see a lot of AI written code in there (the hallmarks aren't hard to see). Have you asked the AI to critique its own writing?
Failing that, you might investigate the routine that the code is using to display the date and time. Nothing else uses it. So how do you know it works?
Sir, As I said in the beginning I took help all around resources, to complete my project... people, internet etc
Your code does not stop if "no RTC found"
To stop the code (because the RTC is not responding), place this after the Serial.println()
    while (true) {}
... and correct the RTC problem.
it may be a good idea to give some more details of the project aims and objectives, e.g. temperature range, accuracy required, etc
also links to the specific DWIN display and ESP32 module being used
have you tested each device in a separate program before attempting to implement the complete project?
And yet you avoided answering both questions I asked you. When asking for help, answer questions you are asked. Otherwise you're just wasting everyone's time.
Well, I'm not going to ask you twice. You had your chance. I will tell you this much before I leave you to it: even a cursory examination of that routine you're using to display the date and time would have told you that it's not correct. Your packets are malformed. But since you can't manage to be forthcoming, so be it. Good luck figuring it out!
What does your serial output tell you about the time/date character buffers you have created and filled?
Can you fill the time/date fields on the DWIN when you use the software clock?
That was an unfortunate "markdown" inclusion. The code block in Post #6 does not have those "escape" characters...
The Serial Monitor is happy with the "non-escaped" line... if sprintf() is correct and the buffer size is correct.
const char dateBuf[] = "20261002";  // 8 char
const char timeBuf[] = "20:35.00";  // 8 char
char buffer[41];                    // must contain the full buffer
  Serial.begin(115200);  // start Serial comm
  sprintf(buffer, "[CLOCK] Date: %s | Time: %s\n", dateBuf, timeBuf);
  Serial.print(buffer);
void loop() {}
Result of my example, above:
[CLOCK] Date: 20261002 | Time: 20:35.00
The code "works" (I do not have a thermometer, hence the error)
[CLOCK] Date: 02-10-2026 | Time: 16:17:39
It appears the DWIN display is a Serial device, using VCC, GND, TXD, RXD. The other peripherals are connected to (available pins) and communicated with (via library) the ESP32 normally.
Drawing from: Smart Home Controller using DWIN HMI Display & ESP32
Thank you Sirs, 5A A5 0B 82 00 10 [YY] [MM] [DD] [WW] [HH] [MM] [SS] 00" this solved my issue,now I am getting perfect display.
