MAX7219 x 4 Day and Time Clock
A user on Reddit has a time clock connected to WIFI to control date and time See Reddit - The heart of the internet
I have reduced the code to work only as a standalone clock. The code uses a stripped down version of LEDControl.h which will not compile on and ESP32. The code I use will.
I run my clock on a nano with a separate DS3107 to reduce volume of the clock body. Here is the code
Max7219 Display (4 0ff)
by Rod McMahon
22/7/2025
/*The Hours and Minutes are displayed after a clock read
from the DS1307.
The DOW is a cycling number from 0 - 6 which increments
at midnight. The DOW cannot be read from the DS1307 as
there is no mechanism to manually set the actual date in Y/M/DOM.
At first programming the DS137 is time set and would hold
time by the battery through power outages.
There are three adjust time push buttons, DOW, Hours and Min.
I have stripped the library LEDControl.h file and not used a
a library to reduce code and to remove the additional items
used in LEDControl for 8 bit displays.
Also this code will compile on ESP32 etc. The library will not.
Arrangement of devices
From Left (connector is far right)
Device Address 3,2,1,0 as you look at display
Arrangement of LEDs per device
Top LH Corner is (0,0) in all cases
0,1,2,3,4,5,6,7   Row
1,
2,
3,
4,
5,
6,
7
Col
Set Row and Col commands
Set Row  0b11100011 will give XXX---XX from Left  to Right
Set Col  0b11100011 will give XXX---XX from top to bottom
(Note that the code sends a row directly but activates LED by LED
for a column)
Layout of Banner, letters and numbers on device
Banner  - Device 3 Row 0 cols 0/8 and Device 2 Row 0 Col 0/3
DOW       Device 3 Row 3 Col 1/7 and then to Device 2 Col 0/3
Hour Ten  Device 2 Col 7 and Device 2 Col 1/2 (split)
Hour Unit Device 1 Col 3/4/5
Min Ten   Device 0 Col 1/2/3
Min Unit  Device 0 Col 5/6/7
Sec       Device 2 Col 7 Row 2 and 5
Numbers
Each number (0-9)represented as by 3 columns
[10][3] array
DOW
Each DOW (7 in total) represented by 3 letters
SUN,MON,TUE,WED,THU,FRI,SAT,SUN and each letter
by 3 columns
The combination of letters and spaces gives an
[7][12] array
The banner has been added into each column
to give the 8 column values (6 for the letters)
#include <RTClib.h>
#include <Wire.h>
// Max7219 register locations
#define OP_DECODEMODE  9
#define OP_INTENSITY   10
#define OP_SCANLIMIT   11
#define OP_SHUTDOWN    12
#define OP_DISPLAYTEST 15
// Coms IO allocation   UNO
//int  SPI_MOSI = 11;
//int  SPI_CS = 7;    // Any one
//int  SPI_CLK = 13;
//Hardwired to DS3107
//SDA   A4
//SCL   A5
// Coms IO allocation   ESP32
//int  SPI_MOSI = 23;
//int  SPI_CS = 19;    // Any one
//int  SPI_CLK = 18;
// SDA    21
// SCL    22
// Coms IO allocation   Nano
int  SPI_MOSI = 11;
int  SPI_CS = 10;     // Any one
int  SPI_CLK = 13;
//SDA   A4
//SCL   A5
//IO Allocations Time Adjust push buttons
// Assign IO as required
int DOWAdj   = 3;      // adjust DOW
int HourAdj  = 4;      // Adjust Hour
int MinAdj   = 5;      // Adjust Minute
// Variables
int devices = 4;               // Number on series MAX7219
byte spidata[16];
byte status[64];
//Numbers
// These are column entries
// Numbers are each 3 x 8
int Numbers[10][3] =
  {0x7e, 0x81, 0x7e},    //0
  {0x40, 0xff, 0x0},     //1
  {0x43, 0x8d, 0x71},    //2
  {0x42, 0x91, 0x6e},    //3
  {0xf0, 0x10, 0xff},    //4
  {0xf1, 0x91, 0x9f},    //5
  {0x7e, 0x91, 0x4e},    //6
  {0x80, 0x80, 0xff},    //7
  {0x6e, 0x91, 0x6e},    //8
  {0x70, 0x90, 0x7f},    //9
// Days of Week with banner
// Banner and space takes two leds, letters are 3 x 6 each
int DOW[7][12] =
  {0x0,0x99,0xa9,0xae,0x80,0xbf,0x81,0xbf,0x0,0xbf,0xb0,0x9f},   // SUN
  {0x0,0xbf,0x90,0xbf,0x80,0x9e,0xa1,0x9e,0x80,0xbf,0xb0,0x9f},  // MON
  {0x0,0xa0,0xbf,0xa0,0x80,0xbf,0x81,0xbf,0x80,0xbf,0xa9,0xa1},  // TUE
  {0x0,0xbe,0x87,0xbe,0x80,0xbf,0xa9,0xa1,0x80,0xbf,0xa1,0x9e},  // WED
  {0x0,0xa0,0xbf,0xa0,0x80,0xbf,0x88,0xbf,0x80,0xbf,0x81,0xbf},  // THU
  {0x0,0xbf,0xa8,0xa0,0x80,0xbf,0xa4,0x9b,0x80,0x80,0xbf,0x80},  // FRI
  {0x0,0x99,0xa9,0xae,0x80,0x9f,0xa8,0x9f,0x80,0xa0,0xbf,0xa0},  // SAT
// Clock Variables
int NowHour;          // From clock read
int NowMin;
int NowSec;
int HourTen ;            // For display
int HourUnit;
int MinTen ;
int MinUnit;
int OldMinute;          // for display updates
int OldSec;
RTC_DS1307 RTC;         // clock item
DateTime now;
int DOWCount;           // Counter for DOW
// Set DOW 12 Columns split over
// two devices
void setDOW( int no)
  for (int i=0;i<12;i++)
    if (i>7)
      setColumn(2,i-8,DOW[no][i]);
      setColumn(3,i,DOW[no][i]);
// Set Time
// Hour Ten split between two devices
// so done as columns
void setTime()
  setColumn(2, 7,Numbers[HourTen][0]);  // Hour Ten
  setColumn(1, 0,Numbers[HourTen][1]);
  setColumn(1, 1,Numbers[HourTen][2]);
  setNumber(1,3,HourUnit);  // Hour Unit
  setNumber(0,1,MinTen);    // Min Ten
  setNumber(0,5,MinUnit);   // Min Unit
// Set Second Pulse
// Controlled by RTC
void setSecond(bool On)
  if (On==true)
    setLed(1, 2, 7, true);
    setLed(1, 5, 7, true);
    setLed(1, 2, 7, false);
    setLed(1, 5, 7, false);
// Set a Number
void setNumber(int addr, int col, int no)
    for (int i=0;i<3;i++)
     setColumn(addr, col+i,Numbers[no][i]);
// Clear Status Register
void ClearStatus()
   for(int i=0;i<64;i++)
        status[i]=0x00;
// LED setup
void LedControlSetUp(int numDevices)
  ClearStatus();
  // First Setup each
  for(int i=0;i<numDevices;i++)
    spiTransfer(i,OP_DISPLAYTEST,0);
    setScanLimit(i,7);                //scanlimit is set to max on startup
    spiTransfer(i,OP_DECODEMODE,0);   //decode is done in source
    clearDisplay(i);
    shutdown(i,true);                 //we go into shutdown-mode on startup
 // then initialized each
  for(int address=0;address<devices;address++)
    shutdown(address,false);  /*The MAX72XX is in power-saving mode on startup*/
    setIntensity(address,3); /* Set the brightness to a medium values */
    clearDisplay(address);/* and clear the display */
//ShutDown
void shutdown(int addr, bool b)
  if(b)
    spiTransfer(addr, OP_SHUTDOWN,0);
    spiTransfer(addr, OP_SHUTDOWN,1);
//Set Scan Limit
void setScanLimit(int addr, int limit)
  if(limit>=0 && limit<8)
    spiTransfer(addr, OP_SCANLIMIT,limit);
//Set Intensity
void setIntensity(int addr, int intensity)
  if(intensity>=0 && intensity<16)
    spiTransfer(addr, OP_INTENSITY,intensity);
//Clear Display
void clearDisplay(int addr)
  int offset;
  offset=addr*8;
  for(int i=0;i<8;i++)
    status[offset+i]=0;
    spiTransfer(addr, i+1,status[offset+i]);
//Set an individual LED
void setLed(int addr, int row, int column, boolean state)
  int offset;
  byte val=0x00;
  if(row<0 || row>7 || column<0 || column>7)
    return;
  offset=addr*8;
  val=B10000000 >> column;
  if(state)
    status[offset+row]=status[offset+row]|val;
    val=~val;
    status[offset+row]=status[offset+row]&val;
  spiTransfer(addr, row+1,status[offset+row]);
//Set a Row
// Value is byte representation
void setRow(int addr, int row, byte value)
  if(row<0 || row>7)
    return;
  spiTransfer(addr, row+1,value);
//Set a Column
void setColumn(int addr, int col, byte value)
  byte val;
  if(col<0 || col>7)
    return;
  for(int row=0;row<8;row++)
    val=value >> (7-row);
    val=val & 0x01;
    setLed(addr,row,col,val);
//SPI Transfer
void spiTransfer(int addr, volatile byte opcode, volatile byte data)
  int offset=addr*2;
  int maxbytes=devices*2;
  for(int i=0;i<maxbytes;i++)       //Create an array with the data to shift out
    spidata[i]=(byte)0;
  spidata[offset+1]=opcode;         //put our device data into the array
  spidata[offset]=data;
  digitalWrite(SPI_CS,LOW);         //enable the line
  for(int i=maxbytes;i>0;i--)       //Now shift out the data
    shiftOut(SPI_MOSI,SPI_CLK,MSBFIRST,spidata[i-1]);
  digitalWrite(SPI_CS,HIGH);        //latch the data onto the display
// Forces a start
void ResetClock()
  GetClock();
  setDOW(DOWCount);
  setTime();
  OldMinute=NowMin;
  OldSec=NowSec;
// Get Clock info
// Separates the Tens and Units
void GetClock()
  now = RTC.now();              // Reads the Clock
  NowHour = now.hour();
  NowMin  = now.minute();
  NowSec  = now.second();
  HourTen  =  NowHour/10;       // Extracts the digits
  HourUnit =  NowHour%10;
  MinTen   =  NowMin/10;
  MinUnit  =  NowMin%10;
// Runs clock
// The DOW just cycles 0 to 6 at
// midnight. Display not taken from
// clock
void RunClock()
   GetClock();
   if ((NowHour==0)&&(NowMin==0)&&(NowSec==0))  // Midnight
      DOWCount++;
      if (DOWCount>6)
        DOWCount=0;
      setDOW(DOWCount);
      delay(1000);             // get past the second or will advance
   if (OldMinute!=NowMin)     //Display at each minute change
      setTime();
      OldMinute=NowMin;
    if (OldSec!=NowSec)    // pulses the second leds
      setSecond(true);
      OldSec=NowSec;
      setSecond(false);
// Adjusts day of week, hour and min
void AdjustClock()
    if (digitalRead(DOWAdj) == LOW)
      DOWCount++;
      if (DOWCount>6)
        DOWCount=0;
      setDOW(DOWCount);
      delay(200);
    if (digitalRead(HourAdj)==LOW)
      int HourCount = NowHour;
      HourCount++;
      if (HourCount>23)
        HourCount=0;
      RTC.adjust(DateTime(now.year(),now.month(),now.day(),HourCount,NowMin,NowSec));
      delay(100);
      ResetClock();
    if (digitalRead(MinAdj)==LOW)
      int MinCount = NowMin;
      MinCount++;
      if (MinCount>59)
        MinCount=0;
      RTC.adjust(DateTime(now.year(),now.month(),now.day(),NowHour,MinCount,NowSec));
      delay(100);
      ResetClock();
//Setup
  pinMode(SPI_MOSI,OUTPUT);
  pinMode(SPI_CLK,OUTPUT);
  pinMode(SPI_CS,OUTPUT);
  pinMode(DOWAdj,INPUT_PULLUP);
  pinMode(HourAdj,INPUT_PULLUP);
  pinMode(MinAdj,INPUT_PULLUP);
  digitalWrite(SPI_CS,HIGH);        // set up LED
  LedControlSetUp(devices);
  Wire.begin();
  RTC.begin();
  RTC.adjust(DateTime(__DATE__, __TIME__));       // sets to date of sketch
 // RTC.adjust(DateTime(25,7,23,11,12,40));
  ResetClock();                                   // starts the clock on startup
  Serial.println("Setup Finished");
// Loop
    AdjustClock();                  // looks to see if adjusting
    RunClock();                     // runs the clock
(post deleted by user)
Post link of original code.
If you are showcasing your project, sharing the code is not enough. Those who would like to follow your design will need a schematic, at least, and maybe a wiring diagram, parts list etc.
They would probably also have certain questions such as why you are using an RTC with an ESP32, which needs no RTC, or why your code has binary digit patterns when max7219 has these already. So a FAQ section could also be useful.
If you had followed the link then u would see the actual project. All I did was make simple code so it could be emulated on simple platforms (uno, nano) with the added benefit that it also compiles on WSP32 The ESP32 does not have battery backup like DS3107 modules. The MAX does not have 6 x 3 letters or 8 x 3 numbers
I can't speak for everyone, but in my case, to see the project, I think I need to register on the "reddit" website.
But since I don't want to create an account on that site, then I can't see the information.
If (you post the schematic and code here) {
I'll try to help you.
else{
end my task
Note that the Reddit link is to a different person's project, on which @RodMcM based their own project.
You should definitely be able to see it. Reddit is one of the only social networks where the content is fully accessible even without being signed into an account.
There isn't much to see at the link @RodMcM shared. It is only a one sentence description and picture of the original project and some discussion on it.
It looks like details on the original project are available here:
Yes Thanks for posting that. You beat me to it. its in the commments in the reddit site
I don't see that link anywhere in the comments on the Reddit post you linked. I found it from a different Reddit post made by the same user:
https://www.reddit.com/r/ArduinoProjects/comments/1ltst10/wifi_clock_with_weather_display_web_config_and/
@ptillisch, Thanks for the link, but this code version uses multiple libraries,
and the OP's version doesn't use any, except the DS1307.
It would be nice if the OP posted the link to where he got this code.
But it seems he doesn't want to post it: so:
if(@RodMcM post code == true) {
Help OP;
else{
See you in another post;
